    2. Marcelouw GamePlay
    Marcelouw GamePlayM Offline
    • RE: ps4-waker command
      Hello!
      I managed to make it work!
      I don't know if it was when I changed the name of the trigger or when I used the first command you passed.
      but now it's working as it should!
      Thank you!
      Marcelouw GamePlayM
      Marcelouw GamePlay
      I created the command with the path of the .bat file
      the file itself, i just put the command "ps4-waker" (because only the command in cmd worked normally)
      sorry for the ignorance, but I'm new to all this!
      Marcelouw GamePlayM
      Marcelouw GamePlay
    • ps4-waker command
      Hello,
      I would like to help, as I am unable to make the ps4-waker command run on triggercmd!
      I did all the procedures correctly, the command works by cmd of windows, but by Trigger nothing happens. I even tried to create a .bat file with the command and it still doesn't work.
      Does anyone know why? I'm a new user of the app.
      Thank you!
      Marcelouw GamePlayM
      Marcelouw GamePlay
