    ps4-waker command
    6 Posts 2 Posters 1.3k Views 1 Watching
    • Marcelouw GamePlayM Offline
      Marcelouw GamePlay
      Hello,
      I would like to help, as I am unable to make the ps4-waker command run on triggercmd!
      I did all the procedures correctly, the command works by cmd of windows, but by Trigger nothing happens. I even tried to create a .bat file with the command and it still doesn't work.
      Does anyone know why? I'm a new user of the app.
      Thank you!
        Russ @Marcelouw GamePlay
        @Marcelouw-GamePlay, please post your .bat file. You might need to specify the full path to the ps4waker.exe file when you run it.
          Marcelouw GamePlay
          I created the command with the path of the .bat file
          the file itself, i just put the command "ps4-waker" (because only the command in cmd worked normally)
          sorry for the ignorance, but I'm new to all this!
            @Marcelouw-GamePlay, thanks.
            It actually worked for me when I put it in the Command field directly. I didn't need a .bat file.
            If that doesn't work for you you could also try this command:
            node %APPDATA%\npm\node_modules\ps4-waker\dist\cli.js
            If you use a batch file I suggest you remove the start line. It's not needed and just opened a cmd window for me when I tried it.
            BTW, for anyone reading this, I installed ps4-waker with this command (I already had nodejs installed):
            npm i -g ps4-waker
            Marcelouw GamePlayM 1 Reply Last reply Reply Quote 0
              Marcelouw GamePlay @Russ
              Hello!
              I managed to make it work!
              I don't know if it was when I changed the name of the trigger or when I used the first command you passed.
              but now it's working as it should!
              Thank you!
                @Marcelouw-GamePlay, awesome. I'm glad it's working.
