    Token login failed
    7 Posts 3 Posters 1.6k Views 1 Watching
    • T Offline
      truedarkness
      Hi, this application has been working great for me until today. It would no longer stay open and close out within seconds after reopening the application. I tried reinstalling which also didn't help, so decided to remove the contents of my .TRIGGERcmdData folder so I could start fresh. Once I deleted the content, I ran the application and it successfully launched, prompting me to enter my token. I received the token from the Instructions page and entered it, but nothing happens when I click Sign In. The debug file just shows this:
      Attempting to log in with token
      (token removed)
      Token login failed.
      I also did a search and found a user had a similar issue, but it was never resolved:
      https://www.triggercmd.com/forum/topic/461/unable-to-access-to-the-aplication
      I even went as far as to clone the package mentioned in that thread and follow the same steps, but that didn't help.
      I tried starting fresh and installing on a separate computer to test and was successful in getting everything set up, so I've managed to localize the issue to my machine.
      I don't know what is preventing the data from being sent through. I disabled all my anti virus software and windows defender processes but it didn't help. Hoping someone might have some idea of what would be preventing the token from being sent/authenticated, or if there's any tests I can run to help debug the issue.
      Thanks
      • T Offline
        truedarkness
        I went in and added console.log(error) into the agent.js where the "Token login failed" is being thrown and this is what got sent back:
        { Error: tunneling socket could not be established, cause=getaddrinfo ENOTFOUND 8888 8888:80
        at ClientRequest.onError (C:\Users\David\AppData\Local\TRIGGERcmdAgent\app-1.0.23\resources\app\node_modules\tunnel-agent\index.js:177:17)
        at ClientRequest.g (events.js:291:16)
        at emitOne (events.js:96:13)
        at ClientRequest.emit (events.js:188:7)
        at Socket.socketErrorListener (_http_client.js:310:9)
        at Socket.emit (events.js:188:7)
        at connectErrorNT (net.js:1022:8)
        at _combinedTickCallback (internal/process/next_tick.js:74:11)
        at process._tickCallback (internal/process/next_tick.js:98:9) code: 'ECONNRESET' }
          Russ @truedarkness
          @truedarkness, that getaddrinfo ENOTFOUND error seems like a DNS resolution problem. Can you verify you can ping www.triggercmd.com and it resolves to this IP address?
          Pinging www.triggercmd.com [75.75.214.51] with 32 bytes of data:
          Reply from 75.75.214.51: bytes=32 time=110ms TTL=54
          The agent is programmed to connect to www.triggercmd.com.
          Also, you deleted your .TRIGGERcmdData folder, so when you get it to work, it will create a second computer in your account. I'm assuming you're subscribed so you can add more than one computer.
          • T Offline
            truedarkness
            Hey Russ,
            Thanks for responding so quickly. Really hoping to get this back up and working soon.
            Can confirm that I can ping www.triggercmd.com, see screenshot below:
            I also tried flushing my DNS with no luck.
            I deleted my existing computer in an effort to get this working, so I shouldn't have any conflicts on that front.
              Russ @truedarkness
              @truedarkness, something is blocking your outbound traffic to www.triggercmd.com on port 443. It could be a VPN or some software on your computer, or your network firewall. Was the other computer you got working on the same network? If so, then your network firewall is fine, which leaves maybe your local Windows firewall. You want to try temporarily disabling the Windows firewall to confirm whether that's it?
              • T Offline
                truedarkness
                Hey @Russ,
                Temporarily disabled Windows Firewall, unfortunately that did not work either. The other computer I got it to work on was connected to the same network. I have disabled all other background services and applications that could possibly be causing a connection block. Can't for the life of me figure out what it could be. Here is my current tasklist... Maybe you will find something suspicious or out of the ordinary:
                System Idle Process              0 Services                   0          8 K
                System                           4 Services                   0      2,584 K
                Registry                       148 Services                   0    115,316 K
                smss.exe                       520 Services                   0      1,264 K
                csrss.exe                      704 Services                   0      5,340 K
                wininit.exe                    796 Services                   0      6,636 K
                csrss.exe                      804 Console                    1      5,276 K
                services.exe                   868 Services                   0     10,996 K
                lsass.exe                      888 Services                   0     23,832 K
                svchost.exe                   1000 Services                   0      3,280 K
                svchost.exe                    308 Services                   0     26,812 K
                fontdrvhost.exe                620 Services                   0      3,712 K
                svchost.exe                    668 Services                   0     15,072 K
                svchost.exe                    576 Services                   0      8,384 K
                winlogon.exe                  1048 Console                    1     11,740 K
                fontdrvhost.exe               1108 Console                    1      7,996 K
                dwm.exe                       1196 Console                    1     77,852 K
                svchost.exe                   1264 Services                   0      9,868 K
                svchost.exe                   1272 Services                   0     11,564 K
                svchost.exe                   1396 Services                   0      6,248 K
                svchost.exe                   1476 Services                   0     16,124 K
                svchost.exe                   1572 Services                   0     13,568 K
                svchost.exe                   1580 Services                   0     17,352 K
                svchost.exe                   1672 Services                   0      9,848 K
                WUDFHost.exe                  1680 Services                   0      8,276 K
                svchost.exe                   1736 Services                   0      8,624 K
                svchost.exe                   1800 Services                   0      7,664 K
                NVDisplay.Container.exe       1840 Services                   0     12,480 K
                svchost.exe                   1920 Services                   0      6,008 K
                svchost.exe                   2024 Services                   0     12,364 K
                svchost.exe                   1516 Services                   0     13,472 K
                svchost.exe                   1568 Services                   0      5,636 K
                svchost.exe                   1944 Services                   0      7,596 K
                Memory Compression            2188 Services                   0     12,556 K
                svchost.exe                   2216 Services                   0      9,468 K
                svchost.exe                   2236 Services                   0      8,288 K
                svchost.exe                   2280 Services                   0     17,008 K
                svchost.exe                   2288 Services                   0      8,944 K
                svchost.exe                   2296 Services                   0      7,816 K
                svchost.exe                   2452 Services                   0      7,076 K
                NVDisplay.Container.exe       2520 Console                    1     47,532 K
                svchost.exe                   2556 Services                   0      7,332 K
                svchost.exe                   2628 Services                   0      8,504 K
                svchost.exe                   3000 Services                   0      8,364 K
                svchost.exe                   2268 Services                   0     13,404 K
                svchost.exe                   2660 Services                   0      7,664 K
                svchost.exe                   2944 Services                   0      9,756 K
                svchost.exe                   3092 Services                   0     12,796 K
                spoolsv.exe                   3232 Services                   0     18,068 K
                svchost.exe                   3300 Services                   0     18,720 K
                svchost.exe                   3328 Services                   0     43,620 K
                svchost.exe                   3344 Services                   0     18,612 K
                svchost.exe                   3520 Services                   0      8,172 K
                svchost.exe                   3608 Services                   0     10,908 K
                svchost.exe                   4028 Services                   0     37,572 K
                svchost.exe                   4036 Services                   0     14,880 K
                svchost.exe                   4048 Services                   0     27,560 K
                mDNSResponder.exe             4056 Services                   0      6,964 K
                svchost.exe                   4060 Services                   0      8,012 K
                Everything.exe                4072 Services                   0      6,956 K
                svchost.exe                   4080 Services                   0      6,612 K
                nvcontainer.exe               4088 Services                   0     31,332 K
                ijplmsvc.exe                  3152 Services                   0      7,268 K
                NvTelemetryContainer.exe      3908 Services                   0     17,800 K
                LDSvc.exe                     3444 Services                   0     91,904 K
                openvpnserv.exe               4108 Services                   0      4,172 K
                svchost.exe                   4140 Services                   0      8,444 K
                MBAMService.exe               4148 Services                   0     59,276 K
                NIHardwareService.exe         4156 Services                   0     14,812 K
                svchost.exe                   4296 Services                   0      9,256 K
                svchost.exe                   4320 Services                   0      5,460 K
                svchost.exe                   4328 Services                   0     19,872 K
                svchost.exe                   4340 Services                   0      7,432 K
                MsMpEng.exe                   4384 Services                   0    197,584 K
                svchost.exe                   4508 Services                   0      5,324 K
                svchost.exe                   4668 Services                   0     13,376 K
                svchost.exe                   4728 Services                   0      5,608 K
                svchost.exe                   5444 Services                   0      7,020 K
                svchost.exe                   5460 Services                   0      7,504 K
                sihost.exe                    5920 Console                    1     27,380 K
                svchost.exe                   5960 Console                    1     36,168 K
                svchost.exe                   6008 Console                    1     38,468 K
                Core Temp.exe                 6100 Console                    1      4,260 K
                taskhostw.exe                 6132 Console                    1     19,320 K
                svchost.exe                   6148 Services                   0     16,124 K
                svchost.exe                   6352 Services                   0      8,028 K
                nvcontainer.exe               6816 Console                    1     57,412 K
                explorer.exe                  6876 Console                    1    165,816 K
                svchost.exe                   6960 Services                   0     18,232 K
                svchost.exe                   7384 Console                    1     22,988 K
                NisSrv.exe                    8004 Services                   0     10,444 K
                StartMenuExperienceHost.e     8116 Console                    1     89,820 K
                RuntimeBroker.exe             7032 Console                    1     27,184 K
                SearchIndexer.exe             8368 Services                   0     64,304 K
                RuntimeBroker.exe             8776 Console                    1     35,816 K
                svchost.exe                   9024 Services                   0      9,952 K
                svchost.exe                   9452 Services                   0     18,724 K
                SettingSyncHost.exe           9528 Console                    1     13,588 K
                NVIDIA Web Helper.exe        10232 Console                    1     11,624 K
                conhost.exe                   2020 Console                    1      1,776 K
                GoogleCrashHandler.exe        4784 Services                   0      1,404 K
                GoogleCrashHandler64.exe      4792 Services                   0      1,224 K
                svchost.exe                  10200 Console                    1     24,236 K
                SecurityHealthSystray.exe    10636 Console                    1      9,504 K
                SecurityHealthService.exe    10668 Services                   0     16,760 K
                RAVCpl64.exe                 10904 Console                    1     11,876 K
                TuneupUI.exe                 10952 Console                    1     37,008 K
                svchost.exe                  11108 Services                   0      5,972 K
                svchost.exe                  11148 Services                   0     10,836 K
                7+ Taskbar Tweaker.exe        8972 Console                    1      8,252 K
                svchost.exe                  10468 Services                   0      9,928 K
                AutoHotkey.exe                9888 Console                    1      8,896 K
                AutoHotkey.exe               11356 Console                    1      8,912 K
                loopBeMon.exe                11768 Console                    1      9,700 K
                AutoHotkey.exe               11836 Console                    1      8,908 K
                CCleaner64.exe               11596 Console                    1     15,008 K
                chrome.exe                     712 Console                    1    205,752 K
                chrome.exe                   11556 Console                    1      7,076 K
                chrome.exe                   11800 Console                    1     94,988 K
                chrome.exe                   11292 Console                    1     48,848 K
                chrome.exe                    1376 Console                    1     35,672 K
                chrome.exe                    2064 Console                    1     69,400 K
                chrome.exe                    2060 Console                    1     42,536 K
                chrome.exe                    6864 Console                    1     34,816 K
                chrome.exe                    2468 Console                    1     38,880 K
                chrome.exe                   11668 Console                    1     48,372 K
                chrome.exe                    1412 Console                    1     43,424 K
                chrome.exe                    1812 Console                    1     34,684 K
                TextInputHost.exe            12296 Console                    1     52,308 K
                chrome.exe                   12304 Console                    1     35,296 K
                chrome.exe                   12312 Console                    1     34,948 K
                chrome.exe                   12320 Console                    1     43,768 K
                chrome.exe                   12328 Console                    1     35,036 K
                chrome.exe                   12372 Console                    1    169,116 K
                svchost.exe                  13952 Services                   0     10,396 K
                ApplicationFrameHost.exe     13900 Console                    1     42,280 K
                WinStore.App.exe             13888 Console                    1     36,716 K
                RuntimeBroker.exe            14128 Console                    1     19,644 K
                Music.UI.exe                 13036 Console                    1     12,804 K
                chrome.exe                    1608 Console                    1     66,116 K
                dllhost.exe                  13104 Console                    1     21,992 K
                Calculator.exe                6032 Console                    1     15,076 K
                svchost.exe                   3324 Services                   0      8,520 K
                MicrosoftEdgeUpdate.exe      10852 Services                   0      3,616 K
                SgrmBroker.exe               14120 Services                   0      9,068 K
                svchost.exe                  11604 Services                   0     11,660 K
                chrome.exe                    2964 Console                    1     69,848 K
                chrome.exe                   10108 Console                    1     44,520 K
                chrome.exe                   13460 Console                    1     55,424 K
                chrome.exe                   13700 Console                    1     90,576 K
                chrome.exe                    1592 Console                    1    102,028 K
                chrome.exe                   13848 Console                    1     85,812 K
                chrome.exe                    8976 Console                    1     18,244 K
                svchost.exe                   9608 Services                   0     11,136 K
                svchost.exe                  11848 Services                   0     12,984 K
                LockApp.exe                  14244 Console                    1     54,088 K
                RuntimeBroker.exe            13784 Console                    1     31,596 K
                svchost.exe                   5848 Services                   0     12,356 K
                svchost.exe                  14440 Services                   0      7,804 K
                svchost.exe                  14972 Services                   0      5,668 K
                cmd.exe                      15140 Console                    1      4,428 K
                conhost.exe                  15044 Console                    1     20,164 K
                chrome.exe                   13224 Console                    1    102,908 K
                chrome.exe                    9552 Console                    1    140,104 K
                SystemSettings.exe           14788 Console                    1     53,784 K
                Taskmgr.exe                  15960 Console                    1     62,660 K
                ctfmon.exe                    3008 Console                    1     21,732 K
                explorer.exe                 13152 Console                    1     45,388 K
                dllhost.exe                  15864 Console                    1      8,712 K
                TRIGGERcmdAgent.exe          15944 Console                    1    105,972 K
                TRIGGERcmdAgent.exe           5364 Console                    1     70,432 K
                TRIGGERcmdAgent.exe           7764 Console                    1     92,616 K
                svchost.exe                   1612 Services                   0     10,020 K
                MoUsoCoreWorker.exe          12156 Services                   0     27,328 K
                svchost.exe                  14692 Services                   0      7,496 K
                audiodg.exe                   3156 Services                   0     11,916 K
                SearchApp.exe                 3664 Console                    1    247,884 K
                RuntimeBroker.exe             8256 Console                    1     18,640 K
                svchost.exe                   5308 Services                   0      8,752 K
                chrome.exe                   10124 Console                    1    117,052 K
                chrome.exe                   10612 Console                    1     22,552 K
                tasklist.exe                 15504 Console                    1      9,040 K
                WmiPrvSE.exe                  8792 Services                   0      9,500 K
                Additionally, here is a list of all of my active connections on 443:
                TCP    192.168.1.2:49981      52.242.211.89:443      ESTABLISHED     4328     svchost.exe
                TCP    192.168.1.2:49992      75.75.214.51:443       ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50102      75.75.214.51:443       ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50212      96.6.24.32:443         ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50228      185.184.8.30:443       ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50236      151.101.2.133:443      ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50243      151.101.2.2:443        ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50247      151.101.2.133:443      ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50290      108.174.10.14:443      CLOSE_WAIT      3664     SearchApp.exe
                TCP    192.168.1.2:50305      96.6.24.32:443         ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50337      72.21.81.200:443       CLOSE_WAIT      3664     SearchApp.exe
                TCP    192.168.1.2:50363      152.199.4.33:443       ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50364      130.211.16.53:443      ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50370      151.101.2.217:443      ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50373      151.101.0.133:443      ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50374      151.101.0.133:443      ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50375      151.101.0.133:443      ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50376      151.101.0.133:443      ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50378      151.101.0.133:443      ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50379      130.211.26.229:443     ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50382      52.167.253.237:443     TIME_WAIT       0
                TCP    192.168.1.2:50383      52.167.253.237:443     ESTABLISHED     5960     svchost.exe
                TCP    192.168.1.2:50384      172.217.12.163:443     ESTABLISHED     11292    chrome.exe
                TCP    192.168.1.2:50385      104.244.37.20:443      CLOSE_WAIT      11292    chrome.exe
                TCP    192.168.1.2:50386      104.244.37.20:443      CLOSE_WAIT      11292    chrome.exe
                I know that's a lot of information but I'm hoping maybe you see something I don't. Let me know if there's anything else you think I should try. Happy to run any further testing.
                  Russ @truedarkness
                  @truedarkness, can you send me a listing of your environment variables? To get that list, just type this command:
                  set
                  I was able to produce a similar error by setting an environment variable called HTTPS_PROXY.
                  C:\Users\russe\AppData\Local\TRIGGERcmdAgent\app-1.0.23\resources\app>set HTTPS_PROXY=8.8.8.8
                  C:\Users\russe\AppData\Local\TRIGGERcmdAgent\app-1.0.23\resources\app>node src\agent.js --console
                  Daemon install: false
                  Logging in with saved token.
                  Checking if the 5cdde2c3ad333300188e83c4 computer exists.
                  Error while checking whether computer exists in your account.
                  Error: tunneling socket could not be established, cause=connect ECONNREFUSED 127.0.0.1:80
                      at ClientRequest.onError (C:\Users\russe\AppData\Local\TRIGGERcmdAgent\app-1.0.23\resources\app\node_modules\tunnel-agent\index.js:177:17)
                      at Object.onceWrapper (events.js:422:26)
                      at ClientRequest.emit (events.js:315:20)
                      at Socket.socketErrorListener (_http_client.js:426:9)
                      at Socket.emit (events.js:315:20)
                      at emitErrorNT (internal/streams/destroy.js:92:8)
                      at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
                      at processTicksAndRejections (internal/process/task_queues.js:84:21) {
                    code: 'ECONNRESET'
                  If you do need HTTPS_PROXY set, you might be able to exclude www.triggercmd.com with the NO_PROXY variable:
                  set NO_PROXY=www.triggercmd.com
                  Another thing I don't understand - your screenshot shows the agent trying to connect to a host name 8888 on port instead of www.triggercmd.com on port 443.
                  You've probably already tried this, but maybe uninstall the agent and delete the C:\Users\David\AppData\Local\TRIGGERcmdAgent folder and re-install it.
