    Never used parameters before...
    4.6k
    • Royher FigueraR
      Royher Figuera @Russ
      @Russ said in Never used parameters before...:
      @Royher-Figuera, good question. No, that's not possible. The preguntarle a Ejecuta Comando part tells Google Assistant to use TRIGGERcmd, and the part after that tells TRIGGERcmd what to do. I know it's a lot to say. That's why I like the Smart Home version better, but I know that only allows on or off as parameters.
      Wow, 😞 It´s a lot to say...
      But is a good reason to diggin about...
      • Royher FigueraR
        Royher Figuera
        Hi @Russ I'm back again...
        Again when I make a searching, the results are the variables of my .bat file.
        For example
        https://www.farmatodo.com.ve/buscar?producto=$10$20$30$4&departamento=Todos&filtros=
        https://www.youtube.com/results?search_query=$10$20$30$4
        https://www.cinecalidad.is/?s=$10$20$30$4
        Before was go Well
        Can You Check, please?
          Russ @Royher Figuera
          @Royher-Figuera, in a .bat file, the syntax for a parameter is %1 for the first parameter, and %2 for the second parameter, etc.
          So you could make a simple batch file that google's something like this:
          start https://www.google.com/search?q=%1
          Royher FigueraR 1 Reply Last reply Reply Quote 0
          • Royher FigueraR
            @Russ Yes, my mistake.
            I have a error in my .bat file with a "$" and "%". I compare with my google.bat and this is ok and modified the another files.
            Thank You
            • Ivan KulerI
              Ivan Kuler
              This post is deleted!
