    Combine two commands
    4 Posts 4 Posters 2.8k Views 1 Watching
    • M Offline
      mark kreger
      Is there a way to combine delete browser history and the clean up commands? Possibly clearing Chromes history as well as internet explorer?
        Russ @mark kreger
        @mark-kreger, you could create a c:\tools folder, and in it, create a ClearHistory.bat file in it with these contents:
        REM Clear IE history:
        rundll32.exe InetCpl.cpl,ClearMyTracksByProcess 255
        REM Clear Chrome history:
        cd /d C:\Users\%USERNAME%\AppData\Local\Google\Chrome\User Data
        del /s History*
        Then create a TRIGGERcmd command that runs c:\tools\ClearHistory.bat
        • S Offline
          StartServer
          I have the issue that the cmd window stays open after executing the bat file.
          Usually cmd.exe /c or start /c would close the window. Here adding /c would not work at all. 😢
          Thoughts?
          • XanderX Offline
            Xander
            You should just be able to add an "Exit" command at the end of your batch.
            Or, you can 'pipeline' your commands by putting the | command in between them:
             cd /d C:\Users\%USERNAME%\AppData\Local\Google\Chrome\User Data | del /s History*
