    Install from github repo?
    9.0k
    • S
      stevef9432203
      Any way to install triggercmd from the github repo. I want the agent installed on my asus router so that I can do wakeonlan, which is supported. Got node-js & node-npm installed from entware repo. Two things needed for this will be to change the base path to /opt/ as this is used as the / path is in rom.
        Russ @stevef9432203
        @stevef9432203, yes, you should be able to download the Github repo: https://github.com/rvmey
        Then run this command:
        node ./src/agent.js --console
        • S
          stevef9432203
          @russ said in Install from github repo?:
          Since I am Clueless
          stever@GT-AC5300:/tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent# node ./src/agent.
          js --console
          module.js:550
          throw err;
          Error: Cannot find module 'socket.io-client'
          at Function.Module._resolveFilename (module.js:548:15)
          at Function.Module._load (module.js:475:25)
          at Module.require (module.js:597:17)
          at require (internal/module.js:11:18)
          at Object.<anonymous> (/tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent/src/agent.js:43:22)
          at Module._compile (module.js:653:30)
          at Object.Module._extensions..js (module.js:664:10)
          at Module.load (module.js:566:32)
          at tryModuleLoad (module.js:506:12)
          at Function.Module._load (module.js:498:3)
            Russ @stevef9432203
            @stevef9432203, I forgot you need to run this from the root of the git repo:
            npm install
            You'll probably need to install npm first.
            • S
              stevef9432203
              Seems to load
              stever@GT-AC5300:/tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent# node ./src/agent.js --console
              Daemon install: false
              No token exists. Login to request one.
              prompt: token: tokenblahblahremoved
              Token saved for next time.
              Computer ID 5c5ba652592b050016ee1e4a saved for next time.
              Write backup completed.
              Initiated command removals
              |> Now connected to https://www.triggercmd.com.
              ___/ For help, see: http://bit.ly/2q0QDpf
              Connected at: Wed Feb 06 2019 19:30:27 GMT-0800 (PST)
              Initiated command adds
              { message: 'Subscribed to 5c5ba652592b050016ee1e4a!' }
              Added Gnome Editor
              I will have to create a startup s cript and when down I will use these instructions to create an install instruction
              set
                Russ @stevef9432203
                @stevef9432203, that's awesome! I never thought I'd see the agent running on a router.
                • S
                  stevef9432203
                  asus gt-ac5300 4 cores and 1gb ram 256mb flash, two usb 3 ports, got 6tb drive plugged in.
                  Any way to get list commands
                    Russ @stevef9432203
                    @stevef9432203, you probably know you can get the list of commands for the local computer from ~/.TRIGGERcmdData/commands.json, but are you asking if there's an API endpoint to list the commands?
                    Please explain more specifically what you're looking for. I'm willing to add an API if it would help.
                    For now, you could try these:
                    curl -X GET https://www.triggercmd.com/api/computer/list -H "authorization: Bearer `cat ~/.TRIGGERcmdData/token.tkn`" | jq
                    curl -X POST https://www.triggercmd.com/api/command/list -H "authorization: Bearer `cat ~/.TRIGGERcmdData/token.tkn`" -H 'content-type: application/json' -d  '{"computer_id":"5ab7db9d8d2282785d369132"}' | jq
                    curl -X GET https://www.triggercmd.com/api/command/commandlist -H "authorization: Bearer `cat ~/.TRIGGERcmdData/token.tkn`" -H 'content-type: application/json'  | jq
                    The first one lists your computers.
                    The second one lists the commands for a given computer.
                    The third lists all of your commands on all of your computers with a field called "did" showing (computer_id)-(command_id).
                    • S
                      stevef9432203
                      Specifically triggercmd start up options. I am assuming options for starting as system start,syslog options , daemon, etc
                      • S
                        stevef9432203
                        Well so far I've emulated the linux install script option and got thus far -
                        Startup cmd from my Linux workstation systemd service file
                        node /usr/share/triggercmdagent/resources/app/src/daemon.js --run /home/stevef/.TR
                        Startup Test of running as root ->>>
                        /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent# node ./src/daemon.js --run /root/.TR
                        Running Linux daemon to run background tasks.
                        Logging in with saved token to run background tasks.
                        Connected at: Sun Feb 10 2019 12:59:47 GMT-0800 (PST)
                        { message: 'Subscribed to 5c608a9f592b050016ee2fff!' }
                        Added Reboot
                        Added yum update
                        Added apt update
                        Damn it works
                        ps | grep node
                        13393 stever 3076 R grep node
                        27544 stever 1098m S node ./src/daemon.js --run /root/.TRIGGERcmdData
                          Russ @stevef9432203
                          @stevef9432203, so are you good now?
                          • S
                            stevef9432203
                            seems so, just got to create a entware start script in /opt/etc/init.d to start it.
                            Would you like a full install howto? This can be used with a lot of routers that support Entware
                              Russ @stevef9432203
                              @stevef9432203, yes please!
                              • S
                                stevef9432203
                                @stevef9432203 said in Install from github repo?:
                                =Current Installl notes-
                                Entware What is it -
                                Minimum Requirements - Extra storage (Small HD preferred,but will work with USB stick)
                                Also Router should have 128M or ram. The TriggerCMD will use about 25M of ram.
                                Entware - Is an addon for Embedded devices "Routers, Access Points, and Nas"
                                that with install of Entware Repo adds an addtional 2200 additional apps to what
                                is in your Router or Nas.
                                ---->>>> https://entware.net/about.html
                                See https://github.com/Entware/Entware/wiki for supported devices
                                and Installion notes.
                                Perform steps from wiki to install on your Device.
                                Once Entware is installed you need to perform these Steps
                                ######################## INSTALL node-js and utils #################################
                                opkg update
                                Downloading http://bin.entware.net/mipselsf-k3.4/Packages.gz.
                                Updated list of available packages in /opt/var/opkg-lists/entware.
                                opkg upgrade
                                Downloading and updating installed Packages...
                                opkg install node-js
                                Installing node-js...
                                opkg install node-npm
                                Install node-npm.....
                                opkg install git-http
                                Installing git-http tools...
                                update npm
                                npm update npm
                                ths took 4 minutes now have patience...
                                ############################# Install TriggerCMD-Agent ############################
                                cd /mnt
                                Get Mount point
                                mount
                                ubi:rootfs_ubifs on / type ubifs (ro,relatime)
                                devtmpfs on /dev type devtmpfs (rw,relatime,mode=0755)
                                proc on /proc type proc (rw,relatime)
                                tmpfs on /var type tmpfs (rw,noexec,relatime,size=420k)
                                sysfs on /sys type sysfs (rw,relatime)
                                debugfs on /sys/kernel/debug type debugfs (rw,relatime)
                                mtd:bootfs on /bootfs type jffs2 (ro,relatime)
                                devpts on /dev/pts type devpts (rw,relatime,mode=600)
                                mtd:data on /data type jffs2 (rw,relatime)
                                tmpfs on /tmp type tmpfs (rw,relatime)
                                /dev/mtdblock8 on /jffs type jffs2 (rw,noatime)
                                /dev/sda1 on /tmp/mnt/Backup+Hub type ext4 (rw,nodev,relatime,stripe=8191,data=ordered)
                                Your mount point is usually dev/sda1
                                on my router /dev/sda1 on {/tmp/mnt/Backup+Hub}
                                Now we need to change to the directory returned by you mount command ( not Mine)
                                cd /tmp/mnt/Backup+Hub
                                Now lets make a "gitrepo" directory
                                mkdir gitrepo
                                Now change to that directory
                                cd gitrepo
                                Now lets clone the from Github. -# https://github.com/rvmey/TRIGGERcmd-Agent.git #-
                                git clone https://github.com/rvmey/TRIGGERcmd-Agent.git
                                Cloning into 'TRIGGERcmd-Agent'...
                                remote: Enumerating objects: 65, done.
                                remote: Counting objects: 100% (65/65), done.
                                remote: Compressing objects: 100% (44/44), done.
                                remote: Total 809 (delta 35), reused 44 (delta 21), pack-reused 744
                                Receiving objects: 100% (809/809), 17.73 MiB | 11.22 MiB/s, done.
                                Resolving deltas: 100% (371/371), done.
                                Now install Agent dependencies
                                cd to TriggerCMD agent
                                cd TRIGGERcmd-Agent
                                Now udate dependcy files
                                npm install
                                npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                                npm WARN deprecated istanbul@0.4.5: This module is no longer maintained, try this instead:
                                npm WARN deprecated npm i nyc
                                npm WARN deprecated Visit https://istanbul.js.org/integrations for other alternatives.
                                npm WARN deprecated jade@1.11.0: Jade has been renamed to pug, please install the latest version of pug instead of jade
                                npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                                npm WARN deprecated gulp-util@2.2.20: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                                npm WARN deprecated react-tools@0.13.3: react-tools is deprecated. For more information, visit https://fb.me/react-tools-deprecated
                                npm WARN deprecated constantinople@3.0.2: Please update to at least constantinople 3.1.1
                                npm WARN deprecated transformers@2.1.0: Deprecated, use jstransformer
                                npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                                npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                                npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                                npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
                                npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
                                npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
                                npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                                npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                                electron@4.0.0 postinstall /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent/node_modules/electron-prebuilt-compile/node_modules/electron
                                node install.js
                                npm notice created a lockfile as package-lock.json. You should commit this file.
                                npm WARN triggercmdagent@1.0.1 No repository field.
                                npm WARN triggercmdagent@1.0.1 license should be a valid SPDX license expression
                                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
                                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                                Just ignore the WARN messages, it will run
                                added 1407 packages from 901 contributors, updated 1 package and audited 14059 packages in 164.529s
                                ################################## Install the Agent ############################################
                                prompt: token: c5NiIsImlhasdf1MDM3NTcyN30.hcOtGZ7U95kS1nhCi4P1asdfobug-Pn4LAFJSY
                                Computer ID 5c68db4062f9b30017477972 saved for next time.
                                Connected at: Sat Feb 16 2019 19:55:45 GMT-0800 (PST)
                                { message: 'Subscribed to 5c68db406477972!' }
                                Added Gnome Editor
                                If you got these steps you are Alive!!! Control C to Stop
                                node /usr/share/triggercmdagent/resources/app/src/daemon.js --run /home/stevef/.TRIGGERcmdData
                                /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent# /opt/bin/node ./src/daemon.js --run /root/.TRIGGERcmdData
                                Added Reboot
                                Added yum update
                                Added apt update
                                Damn it works -
                                ps | grep node
                                lets Create Entware Startup Script -
                                  Russ @stevef9432203
                                  @stevef9432203, thank you for posting your steps!
                                  • S
                                    stevef9432203
                                    I've put a more complete install outline, in the Installs Sub-Forum. Let me know if its complete enough.
                                      Russ @stevef9432203
                                      @stevef9432203, yes, I think that's good. Thank you for doing it. I don't have a router to verify every step, but the instructions look detailed enough that someone could follow it.
                                      • S
                                        stevef9432203
                                        Tested on Two asus Routers asus rt ac5300, asus gt-ac5300, and qnap nas
                                          Russ @stevef9432203
                                          @stevef9432203, ooh, I do have a qnap nas I could try it on.
                                          • S
                                            stevef9432203
                                            Interesting issue pops up every few boots, two files dissapear; token.tkn and computerid
                                            .cfg vanish after reboot. Kind of resembles lack flexible closure or no shutdown handling traps hup
                                            Oct or kill..Gotta restore token.tkn to reboot sevices .
                                            Comments? Or ?
