    Install from github repo?
    23 Posts 2 Posters 11.0k Views 1 Watching
      Russ @stevef9432203
      @stevef9432203, I forgot you need to run this from the root of the git repo:
      npm install
      You'll probably need to install npm first.
      • S Offline
        stevef9432203
        @russ said in Install from github repo?:
        node ./src/agent.js --console
        Seems to load
        stever@GT-AC5300:/tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent# node ./src/agent.js --console
        Daemon install: false
        prompt: token: tokenblahblahremoved
        Token saved for next time.
        Computer ID 5c5ba652592b050016ee1e4a saved for next time.
        Write backup completed.
        Initiated command removals
        Connected at: Wed Feb 06 2019 19:30:27 GMT-0800 (PST)
        Initiated command adds
        { message: 'Subscribed to 5c5ba652592b050016ee1e4a!' }
        Added Gnome Editor
        I will have to create a startup s cript and when down I will use these instructions to create an install instruction
        set
          Russ @stevef9432203
          @stevef9432203, that's awesome! I never thought I'd see the agent running on a router.
          • S Offline
            stevef9432203
            asus gt-ac5300 4 cores and 1gb ram 256mb flash, two usb 3 ports, got 6tb drive plugged in.
            Any way to get list commands
              Russ @stevef9432203
              @stevef9432203, you probably know you can get the list of commands for the local computer from ~/.TRIGGERcmdData/commands.json, but are you asking if there's an API endpoint to list the commands?
              Please explain more specifically what you're looking for. I'm willing to add an API if it would help.
              For now, you could try these:
              curl -X GET https://www.triggercmd.com/api/computer/list -H "authorization: Bearer `cat ~/.TRIGGERcmdData/token.tkn`" | jq
              curl -X POST https://www.triggercmd.com/api/command/list -H "authorization: Bearer `cat ~/.TRIGGERcmdData/token.tkn`" -H 'content-type: application/json' -d  '{"computer_id":"5ab7db9d8d2282785d369132"}' | jq
              curl -X GET https://www.triggercmd.com/api/command/commandlist -H "authorization: Bearer `cat ~/.TRIGGERcmdData/token.tkn`" -H 'content-type: application/json'  | jq
              The first one lists your computers.
              The second one lists the commands for a given computer.
              The third lists all of your commands on all of your computers with a field called "did" showing (computer_id)-(command_id).
              • S Offline
                stevef9432203
                Specifically triggercmd start up options. I am assuming options for starting as system start,syslog options , daemon, etc
                • S Offline
                  stevef9432203
                  Well so far I've emulated the linux install script option and got thus far -
                  Startup cmd from my Linux workstation systemd service file
                  node /usr/share/triggercmdagent/resources/app/src/daemon.js --run /home/stevef/.TR
                  Startup Test of running as root ->>>
                  /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent# node ./src/daemon.js --run /root/.TR
                  Running Linux daemon to run background tasks.
                  Logging in with saved token to run background tasks.
                  Connected at: Sun Feb 10 2019 12:59:47 GMT-0800 (PST)
                  { message: 'Subscribed to 5c608a9f592b050016ee2fff!' }
                  Added Reboot
                  Added yum update
                  Added apt update
                  Damn it works
                  ps | grep node
                  13393 stever 3076 R grep node
                  27544 stever 1098m S node ./src/daemon.js --run /root/.TRIGGERcmdData
                    Russ @stevef9432203
                    @stevef9432203, so are you good now?
                    • S Offline
                      stevef9432203
                      seems so, just got to create a entware start script in /opt/etc/init.d to start it.
                      Would you like a full install howto? This can be used with a lot of routers that support Entware
                        Russ @stevef9432203
                        @stevef9432203, yes please!
                        • S Offline
                          stevef9432203
                          @stevef9432203 said in Install from github repo?:
                          =Current Installl notes-
                          Entware What is it -
                          Minimum Requirements - Extra storage (Small HD preferred,but will work with USB stick)
                          Also Router should have 128M or ram. The TriggerCMD will use about 25M of ram.
                          Entware - Is an addon for Embedded devices "Routers, Access Points, and Nas"
                          that with install of Entware Repo adds an addtional 2200 additional apps to what
                          is in your Router or Nas.
                          ---->>>> https://entware.net/about.html
                          See https://github.com/Entware/Entware/wiki for supported devices
                          and Installion notes.
                          Perform steps from wiki to install on your Device.
                          Once Entware is installed you need to perform these Steps
                          ######################## INSTALL node-js and utils #################################
                          opkg update
                          Downloading http://bin.entware.net/mipselsf-k3.4/Packages.gz.
                          Updated list of available packages in /opt/var/opkg-lists/entware.
                          opkg upgrade
                          Downloading and updating installed Packages...
                          opkg install node-js
                          Installing node-js...
                          opkg install node-npm
                          Install node-npm.....
                          opkg install git-http
                          Installing git-http tools...
                          update npm
                          npm update npm
                          ths took 4 minutes now have patience...
                          ############################# Install TriggerCMD-Agent ############################
                          cd /mnt
                          Get Mount point
                          mount
                          ubi:rootfs_ubifs on / type ubifs (ro,relatime)
                          devtmpfs on /dev type devtmpfs (rw,relatime,mode=0755)
                          proc on /proc type proc (rw,relatime)
                          tmpfs on /var type tmpfs (rw,noexec,relatime,size=420k)
                          sysfs on /sys type sysfs (rw,relatime)
                          debugfs on /sys/kernel/debug type debugfs (rw,relatime)
                          mtd:bootfs on /bootfs type jffs2 (ro,relatime)
                          devpts on /dev/pts type devpts (rw,relatime,mode=600)
                          mtd:data on /data type jffs2 (rw,relatime)
                          tmpfs on /tmp type tmpfs (rw,relatime)
                          /dev/mtdblock8 on /jffs type jffs2 (rw,noatime)
                          /dev/sda1 on /tmp/mnt/Backup+Hub type ext4 (rw,nodev,relatime,stripe=8191,data=ordered)
                          Your mount point is usually dev/sda1
                          on my router /dev/sda1 on {/tmp/mnt/Backup+Hub}
                          Now we need to change to the directory returned by you mount command ( not Mine)
                          cd /tmp/mnt/Backup+Hub
                          Now lets make a "gitrepo" directory
                          mkdir gitrepo
                          Now change to that directory
                          cd gitrepo
                          Now lets clone the from Github. -# https://github.com/rvmey/TRIGGERcmd-Agent.git #-
                          Cloning into 'TRIGGERcmd-Agent'...
                          remote: Enumerating objects: 65, done.
                          remote: Counting objects: 100% (65/65), done.
                          remote: Compressing objects: 100% (44/44), done.
                          remote: Total 809 (delta 35), reused 44 (delta 21), pack-reused 744
                          Receiving objects: 100% (809/809), 17.73 MiB | 11.22 MiB/s, done.
                          Resolving deltas: 100% (371/371), done.
                          Now install Agent dependencies
                          cd to TriggerCMD agent
                          cd TRIGGERcmd-Agent
                          Now udate dependcy files
                          npm install
                          npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
                          npm WARN deprecated istanbul@0.4.5: This module is no longer maintained, try this instead:
                          npm WARN deprecated npm i nyc
                          npm WARN deprecated Visit https://istanbul.js.org/integrations for other alternatives.
                          npm WARN deprecated jade@1.11.0: Jade has been renamed to pug, please install the latest version of pug instead of jade
                          npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                          npm WARN deprecated gulp-util@2.2.20: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
                          npm WARN deprecated react-tools@0.13.3: react-tools is deprecated. For more information, visit https://fb.me/react-tools-deprecated
                          npm WARN deprecated constantinople@3.0.2: Please update to at least constantinople 3.1.1
                          npm WARN deprecated transformers@2.1.0: Deprecated, use jstransformer
                          npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                          npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
                          npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                          npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                          npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
                          npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
                          npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
                          npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
                          npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
                          npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
                          electron@4.0.0 postinstall /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent/node_modules/electron-prebuilt-compile/node_modules/electron
                          node install.js
                          npm notice created a lockfile as package-lock.json. You should commit this file.
                          npm WARN triggercmdagent@1.0.1 No repository field.
                          npm WARN triggercmdagent@1.0.1 license should be a valid SPDX license expression
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                          Just ignore the WARN messages, it will run
                          added 1407 packages from 901 contributors, updated 1 package and audited 14059 packages in 164.529s
                          ################################## Install the Agent ############################################
                          prompt: token: c5NiIsImlhasdf1MDM3NTcyN30.hcOtGZ7U95kS1nhCi4P1asdfobug-Pn4LAFJSY
                          Computer ID 5c68db4062f9b30017477972 saved for next time.
                          Connected at: Sat Feb 16 2019 19:55:45 GMT-0800 (PST)
                          { message: 'Subscribed to 5c68db406477972!' }
                          Added Gnome Editor
                          If you got these steps you are Alive!!! Control C to Stop
                          node /usr/share/triggercmdagent/resources/app/src/daemon.js --run /home/stevef/.TRIGGERcmdData
                          /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent# /opt/bin/node ./src/daemon.js --run /root/.TRIGGERcmdData
                          Added Reboot
                          Added yum update
                          Added apt update
                          Damn it works -
                          ps | grep node
                          lets Create Entware Startup Script -
                            Russ @stevef9432203
                            @stevef9432203, thank you for posting your steps!
                            • S Offline
                              stevef9432203
                              I've put a more complete install outline, in the Installs Sub-Forum. Let me know if its complete enough.
                                Russ @stevef9432203
                                @stevef9432203, yes, I think that's good. Thank you for doing it. I don't have a router to verify every step, but the instructions look detailed enough that someone could follow it.
                                • S Offline
                                  stevef9432203
                                  Tested on Two asus Routers asus rt ac5300, asus gt-ac5300, and qnap nas
                                    Russ @stevef9432203
                                    @stevef9432203, ooh, I do have a qnap nas I could try it on.
                                    • S Offline
                                      stevef9432203
                                      Interesting issue pops up every few boots, two files dissapear; token.tkn and computerid
                                      .cfg vanish after reboot. Kind of resembles lack flexible closure or no shutdown handling traps hup
                                      Oct or kill..Gotta restore token.tkn to reboot sevices .
                                      Comments? Or ?
                                        Russ @stevef9432203
                                        @stevef9432203, please confirm - your commands.json stays when the router reboots, but your token.tkn file and computerid.cfg file go away? If so that's odd because the agent doesn't keep those two files open - it just reads them during startup.
                                        • S Offline
                                          stevef9432203
                                          Yes the commands.json files stay intact. I will move content startup directory to hard disk storage to test. Can I specify the path to the data directory with the '--run' path prefix ?
                                            Russ @stevef9432203
                                            @stevef9432203, no, but you could change this line to set your "homedir" to something else.
                                            homedir = (process.platform === 'win32') ? process.env.HOMEPATH : process.env.HOME;
                                            Or maybe you could symlink your ~/.TRIGGERcmdData folder to a path on your hard drive.
