    Install from github repo?
    23 Posts 2 Posters 10.5k Views 1 Watching
    • S Offline
      stevef9432203
      Well so far I've emulated the linux install script option and got thus far -
      Startup cmd from my Linux workstation systemd service file
      node /usr/share/triggercmdagent/resources/app/src/daemon.js --run /home/stevef/.TR
      Startup Test of running as root ->>>
      /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent# node ./src/daemon.js --run /root/.TR
      Running Linux daemon to run background tasks.
      Logging in with saved token to run background tasks.
      Write backup completed.
      Connected at: Sun Feb 10 2019 12:59:47 GMT-0800 (PST)
      { message: 'Subscribed to 5c608a9f592b050016ee2fff!' }
      Initiated command removals
      Initiated command adds
      Added Reboot
      Added yum update
      Added apt update
      Damn it works
      ps | grep node
      13393 stever 3076 R grep node
      27544 stever 1098m S node ./src/daemon.js --run /root/.TRIGGERcmdData
        Russ @stevef9432203
        @stevef9432203, so are you good now?
        • S Offline
          stevef9432203
          seems so, just got to create a entware start script in /opt/etc/init.d to start it.
          Would you like a full install howto? This can be used with a lot of routers that support Entware
            Russ @stevef9432203
            @stevef9432203, yes please!
            • S Offline
              stevef9432203
              @stevef9432203 said in Install from github repo?:
              node ./src/agent.js --console
              =Current Installl notes-
              Entware What is it -
              Minimum Requirements - Extra storage (Small HD preferred,but will work with USB stick)
              Also Router should have 128M or ram. The TriggerCMD will use about 25M of ram.
              Entware - Is an addon for Embedded devices "Routers, Access Points, and Nas"
              that with install of Entware Repo adds an addtional 2200 additional apps to what
              is in your Router or Nas.
              ---->>>> https://entware.net/about.html
              See https://github.com/Entware/Entware/wiki for supported devices
              and Installion notes.
              Perform steps from wiki to install on your Device.
              Once Entware is installed you need to perform these Steps
              ######################## INSTALL node-js and utils #################################
              opkg update
              Downloading http://bin.entware.net/mipselsf-k3.4/Packages.gz.
              Updated list of available packages in /opt/var/opkg-lists/entware.
              opkg upgrade
              Downloading and updating installed Packages...
              opkg install node-js
              Installing node-js...
              opkg install node-npm
              Install node-npm.....
              opkg install git-http
              Installing git-http tools...
              update npm
              npm update npm
              ths took 4 minutes now have patience...
              ############################# Install TriggerCMD-Agent ############################
              cd /mnt
              Get Mount point
              mount
              ubi:rootfs_ubifs on / type ubifs (ro,relatime)
              devtmpfs on /dev type devtmpfs (rw,relatime,mode=0755)
              proc on /proc type proc (rw,relatime)
              tmpfs on /var type tmpfs (rw,noexec,relatime,size=420k)
              sysfs on /sys type sysfs (rw,relatime)
              debugfs on /sys/kernel/debug type debugfs (rw,relatime)
              mtd:bootfs on /bootfs type jffs2 (ro,relatime)
              devpts on /dev/pts type devpts (rw,relatime,mode=600)
              mtd:data on /data type jffs2 (rw,relatime)
              tmpfs on /tmp type tmpfs (rw,relatime)
              /dev/mtdblock8 on /jffs type jffs2 (rw,noatime)
              /dev/sda1 on /tmp/mnt/Backup+Hub type ext4 (rw,nodev,relatime,stripe=8191,data=ordered)
              Your mount point is usually dev/sda1
              on my router /dev/sda1 on {/tmp/mnt/Backup+Hub}
              Now we need to change to the directory returned by you mount command ( not Mine)
              cd /tmp/mnt/Backup+Hub
              Now lets make a "gitrepo" directory
              mkdir gitrepo
              Now change to that directory
              cd gitrepo
              Now lets clone the from Github. -# https://github.com/rvmey/TRIGGERcmd-Agent.git #-
              Cloning into 'TRIGGERcmd-Agent'...
              remote: Enumerating objects: 65, done.
              remote: Counting objects: 100% (65/65), done.
              remote: Compressing objects: 100% (44/44), done.
              remote: Total 809 (delta 35), reused 44 (delta 21), pack-reused 744
              Receiving objects: 100% (809/809), 17.73 MiB | 11.22 MiB/s, done.
              Resolving deltas: 100% (371/371), done.
              Now install Agent dependencies
              cd to TriggerCMD agent
              cd TRIGGERcmd-Agent
              Now udate dependcy files
              npm install
              npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
              npm WARN deprecated istanbul@0.4.5: This module is no longer maintained, try this instead:
              npm WARN deprecated npm i nyc
              npm WARN deprecated Visit https://istanbul.js.org/integrations for other alternatives.
              npm WARN deprecated jade@1.11.0: Jade has been renamed to pug, please install the latest version of pug instead of jade
              npm WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
              npm WARN deprecated gulp-util@2.2.20: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
              npm WARN deprecated react-tools@0.13.3: react-tools is deprecated. For more information, visit https://fb.me/react-tools-deprecated
              npm WARN deprecated constantinople@3.0.2: Please update to at least constantinople 3.1.1
              npm WARN deprecated transformers@2.1.0: Deprecated, use jstransformer
              npm WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
              npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
              npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
              npm WARN deprecated minimatch@0.3.0: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
              npm WARN deprecated browserslist@1.7.7: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
              npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
              npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
              npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
              npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
              npm WARN deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
              electron@4.0.0 postinstall /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent/node_modules/electron-prebuilt-compile/node_modules/electron
              node install.js
              npm notice created a lockfile as package-lock.json. You should commit this file.
              npm WARN triggercmdagent@1.0.1 No repository field.
              npm WARN triggercmdagent@1.0.1 license should be a valid SPDX license expression
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.7 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
              Just ignore the WARN messages, it will run
              added 1407 packages from 901 contributors, updated 1 package and audited 14059 packages in 164.529s
              ################################## Install the Agent ############################################
              Daemon install: false
              prompt: token: c5NiIsImlhasdf1MDM3NTcyN30.hcOtGZ7U95kS1nhCi4P1asdfobug-Pn4LAFJSY
              Token saved for next time.
              Computer ID 5c68db4062f9b30017477972 saved for next time.
              Connected at: Sat Feb 16 2019 19:55:45 GMT-0800 (PST)
              { message: 'Subscribed to 5c68db406477972!' }
              Added Gnome Editor
              If you got these steps you are Alive!!! Control C to Stop
              node /usr/share/triggercmdagent/resources/app/src/daemon.js --run /home/stevef/.TRIGGERcmdData
              /tmp/mnt/Backup+Hub/gitrepo/TRIGGERcmd-Agent# /opt/bin/node ./src/daemon.js --run /root/.TRIGGERcmdData
              Added Reboot
              Added yum update
              Added apt update
              Damn it works -
              ps | grep node
              lets Create Entware Startup Script -
                Russ @stevef9432203
                @stevef9432203, thank you for posting your steps!
                • S Offline
                  stevef9432203
                  I've put a more complete install outline, in the Installs Sub-Forum. Let me know if its complete enough.
                    Russ @stevef9432203
                    @stevef9432203, yes, I think that's good. Thank you for doing it. I don't have a router to verify every step, but the instructions look detailed enough that someone could follow it.
                    • S Offline
                      stevef9432203
                      Tested on Two asus Routers asus rt ac5300, asus gt-ac5300, and qnap nas
                        Russ @stevef9432203
                        @stevef9432203, ooh, I do have a qnap nas I could try it on.
                        • S Offline
                          stevef9432203
                          Interesting issue pops up every few boots, two files dissapear; token.tkn and computerid
                          .cfg vanish after reboot. Kind of resembles lack flexible closure or no shutdown handling traps hup
                          Oct or kill..Gotta restore token.tkn to reboot sevices .
                          Comments? Or ?
                            Russ @stevef9432203
                            @stevef9432203, please confirm - your commands.json stays when the router reboots, but your token.tkn file and computerid.cfg file go away? If so that's odd because the agent doesn't keep those two files open - it just reads them during startup.
                            • S Offline
                              stevef9432203
                              Yes the commands.json files stay intact. I will move content startup directory to hard disk storage to test. Can I specify the path to the data directory with the '--run' path prefix ?
                                Russ @stevef9432203
                                @stevef9432203, no, but you could change this line to set your "homedir" to something else.
                                homedir = (process.platform === 'win32') ? process.env.HOMEPATH : process.env.HOME;
                                Or maybe you could symlink your ~/.TRIGGERcmdData folder to a path on your hard drive.
