    Trigger from Shortcuts (iOS)
    Mac
    ios siri shortcuts
    2.1k
    • M
      MNPG
      Triggers can be invoked from your iPhone, iPad, Apple Watch, or HomePod via Shortcuts using the REST API. This is by far the easiest and most native way I have found to invoke triggers from iOS.
      URL: https://www.triggercmd.com/api/run/triggerSave
      {Token}: Your token found here.
      {CN}: Your computer name
      {TriggerName}: The name of your trigger.
      RussR 1 Reply Last reply Reply Quote -1
        Russ @MNPG
        @mnpg, that's awesome! Thanks for posting that.
          FYI, two things about this:
          1. Instead of using the authorization header, you can send the token as another parameter called token in the Request Body section.
          2. You don't actually need the { and }'s. I think @MNPG put them there to mean those values are examples.
          @Lewis-S found that out here.
          • kellanistK
            kellanist
            This is fantastic! Good to know!
