    error with google routines
    Scheduled Pinned Locked Moved Google Home
    2 Posts 2 Posters 1.6k Views 1 Watching
    • ANDRES ROJASA Offline
      ANDRES ROJAS
      I cannot do routines with google home because when I go to take some command that I have created to activate or deactivate the option does not appear.
        Russ @ANDRES ROJAS
        @ANDRES-ROJAS, I might be having the same problem you are. I tried creating a Google Assistant routine that flips one of the virtual switches on, but it won't allow me to select the switch now. I'll look into that, but there's another way that does work.
        Here's what worked for me:
        • Open the Home app
        • Tap Routines
        • Tap the + to create a routine
        • Tap Personal
        • Tap "Add starter"
        • Tap "When I say to Google Assistant"
        • Type "calculator"
        • Tap "Add action"
        • Tap "Try adding your own"
        • Type "turn on calculator"
        For this to work, you have to enable the TRIGGERcmd Smart Home action first.
