    Installation has failed
    2.9k
    • D
      dpes
      Re: Can't install the Setup
      Can someone help me? Same error when I try to install.
      Windows 10, x64.
        Russ @dpes
        @dpes, I've seen install errors when it's 32bit Windows, but you wrote "Windoes 10, x64" above. I've also seen it happen with certain types of antivirus software. You could copy/paste the setup log here. It might provide a clue.
        D 1 Reply Last reply Reply Quote 0
        • D
          dpes @Russ
          @Russ After reboot my system, the installation worked. Thanks!!
          • kellanistK
            kellanist
            @Russ I got the same error after uninstalling and then attempting to reinstall this morning. I'll restart and give it another go. I took a look at the log but I can't copypasta it on there due to length.
            Let me paste a couple entries that caught my eye in terms of the failed install:
            2020-04-24 09:14:11> Program: Starting Squirrel Updater: --install .
            2020-04-24 09:14:11> Program: Starting install, writing to C:\Users\kadamson\AppData\Local\SquirrelTemp
            2020-04-24 09:14:11> Program: About to install to: C:\Users\kadamson\AppData\Local\TRIGGERcmdAgent
            2020-04-24 09:14:11> Program: Install path C:\Users\kadamson\AppData\Local\TRIGGERcmdAgent already exists, burning it to the ground
            2020-04-24 09:14:12> Utility: DeleteDirectory: could not delete - C:\Users\kadamson\AppData\Local\TRIGGERcmdAgent\app-1.0.22\resources\app\src: System.IO.IOException: The process cannot access the file 'C:\Users\kadamson\AppData\Local\TRIGGERcmdAgent\app-1.0.22\resources\app\src' because it is being used by another process.
            at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
            at System.IO.Directory.DeleteHelper(String fullPath, String userPath, Boolean recursive, Boolean throwOnTopLevelDirectoryNotFound, WIN32_FIND_DATA& data)
            at System.IO.Directory.Delete(String fullPath, String userPath, Boolean recursive, Boolean checkHost)
            at Squirrel.Utility.<DeleteDirectory>d__19.MoveNext()
            2020-04-24 09:14:13> Utility: DeleteDirectory: could not delete - C:\Users\kadamson\AppData\Local\TRIGGERcmdAgent\app-1.0.22\resources\app: System.IO.IOException: The directory is not empty.
            2021-03-05 09:04:01> Program: Starting install, writing to C:\Users\kadamson\AppData\Local\SquirrelTemp
            2021-03-05 09:04:01> Program: About to install to: C:\Users\kadamson\AppData\Local\TRIGGERcmdAgent
            2021-03-05 09:04:01> Program: Install path C:\Users\kadamson\AppData\Local\TRIGGERcmdAgent already exists, burning it to the ground
            2021-03-05 09:04:01> IEnableLogger: Failed to remove existing directory on full install, is the app still running???: System.UnauthorizedAccessException: Access to the path 'C:\Users\kadamson\AppData\Local\TRIGGERcmdAgent\app-1.0.25\resources\app\src\node.exe' is denied.
            Win10 64. 20H2. Running as a full admin and also use "Run as admin". AV is Windows Defender.
            One question I did have. What is going on with the Discord, Teams, Whatsapp stuff that I'm seeing in the log? What are you doing in these folders?
            3912> 2020-03-12 16:59:13> Program: About to install to: C:\Users\kadamson\AppData\Local\Discord why is it installing in the Discord AppData folder?
            • kellanistK
              kellanist
              Restarting worked for me as well. Installed successfully and the service launched automatically.
                Russ @kellanist
                Oh, sweet @kellanist. I just answered you on the other thread. I'll link that one here.
