    Can't install the Setup
    4 Posts 2 Posters 1.1k Views 1 Watching
    • LennartL Offline
      Lennart
      I got a Surface Pro and want to install the .exe but after this fancy installing animation pops up I receive an "Installation has failed" window. Can you help me with that?15be52c3-0c4d-4cbe-9a02-6406d95f2c68-image.png I could also give you the Setup log if it helps
      • LennartL Offline
        Lennart
        Could be because the surface pro x runs on arm...
        • RussR Online
          Russ @Lennart
          @Lennart, you're right - it only works on Windows 64bit, not even 32bit.
          • LennartL Offline
            Lennart
            Ok thank you
