Reregistering Triggercmd on a New PC and copying across all commands
Hi
My old PC died and I want to reregister TriggerCmd on my new pc and make sure it is working before I pay for a yearly subs.
I have an image of the old PC on my new PC. I can see all my commands showing in the commands.json file from the image.
So the only way is to delete the PC showing under my account and add the new PC and copy accross the contents from the commands.json file?
If so when I delete the PC will there be an option to add a PC, I cent see any option currently to add a PC
Can you somehow just edit the MAC address somewhere?
I ended up deleting the computer from my account, uninstalling trigger from pc and deleting the trigger directory user settings.
Lucky I had a copy of my settings/commands from my old pc. I copied across the file contents and it worked.
Has to be an easier as all that is technically changing is the MAC address?
Also, if u use my than 1 PC do u need to create a shutdown command for each PC and edit the voice command to include the PC name or and will it work by using 1 shutdown command and simply say "shutdown (computername)"
@Edwin-Zahra, I'm glad you figured it out. You did the right thing - because you haven't subscribed, you can only have one computer, so you had to delete the old computer before you could add the new computer.
An alternative would have been to copy your ~/.TRIGGERcmdData folder from your old computer to your new one. That would have copied your commands.json and your computerid.cfg file which contains your computer ID. That computer ID is what connects your computer record to your actual computer running the triggercmd agent software. It's not the MAC address - it's that computer ID.
Also, yes, whether it's your old or new computer, if you check the "Create Alexa Smart Home device for this computer" checkbox you can say Alexa, turn off X, where X is your computer's voice name.
Sorry Im not seeing this screen, went thru every menu item. Im guessing its some where under computer management ? Looks like you have an extra line under Computer Management. Can you please advise path or settings to get to this screen. Below is what showing in my client.
Also, not sure if this is related, when I say power on (pc name), Alexa says something along the lines, enable the skill for this device, but still boots up?
@Edwin-Zahra, sorry, to get to your profile settings page, click your name in the upper-right, and click Profile.
@Russ I think you may be answering someone's question?
However it is useful as the profile has setting for the default computer.
You're right @Edwin-Zahra, I'm sorry I sent bad instructions last reply.
To get to that Computer Edit screen, click the Edit button for the computer:
Thanks alot, last question:
Only way to use a voice command of "run (skill)" as a default, instead of turn on "(skill)" is thru Alexa, cant be done within triggercmd? Seems weird saying "Turn on shutdown".
FYI most commands work by saying "run", not sure why shutdown doesnt work.
Thanks for all ur help
@Edwin-Zahra, you're welcome.
One thing I want to make sure you understand is if you're checking that "Create Alexa Smart Home device for this computer" checkbox, it creates a device for the computer, which is separate from the devices created for each command that has a voice word filled in. That computer device can be used for turn on (wake-on-lan) and turn off (run the shutdown command you specify).
You'd say "turn on shutdown" if you want to run the shutdown command via its own device.
You'd say "turn off laptop" to run the shutdown command you specified in the Computer Edit screen.
After checking the option to "Create Alexa device for this computer" in the computer edit screen, I created a 2 routines for the computer device created in Alexa, one to logoff and the other to logon.
The routine to turn on the computer is setup so when I say " Turn on the computer", Alexa will first say "Turning on the computer", then run the Power setting with "On" checked. I then have selected the Echo to hear Alexa from.
The PC Turns on automatically when I say " Turn on the computer" but doesnt say the phrase for some reason
I have done something similar when turning off the computer. It turns the computer off automatically, but doesnt say the phrase "Turning off the computer".
Also, not sure if this might be the cause, I went back into the computer edit screen and all the settings I had saved in that screen from before, were all now unchecked/blank, not sure if thats the way its meant to be?
@Edwin-Zahra, no, it's supposed to save your settings under the computer Edit screen. Can you reproduce that issue?
I tested it myself and I found that my settings do save.
All I can think of that would clear your settings if you deleted your computer and recreated it. I did notice if I rename my "Alexa Shutdown Command" it gets cleared, but the Volume and Mute commands don't, so I'll fix that.
I wonder if the reason Alexa isn't saying "Turning on the computer" is because it's not actually running your routine - maybe it's finding the computer device you created for your TRIGGERcmd computer by checking that box. You could use a very different trigger phrase, like "apple" or "banana" to run your routine for testing.
@Russ I think the saving issue might have been one off issue, as I had trouble logging in for some reason using my google account for several days. The only way I could login before was using the pair option. Since now I can login normally without any issue, settings are saved when I check computer edit
