<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Reregistering Triggercmd on a New PC and copying across all commands]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">My old PC died and I want to reregister TriggerCmd on my new pc and make sure it is working before I pay for a yearly subs.</p>
<p dir="auto">I have an image of the old PC on my new PC. I can see all my commands showing in the commands.json file from the image.</p>
<p dir="auto">So the only way is to delete the PC showing under my account and add the new PC and copy accross the contents from the commands.json file?</p>
<p dir="auto">If so when I delete the PC will there be an option to add a PC, I cent see any option currently to add a PC</p>
<p dir="auto">Can you somehow just edit the MAC address somewhere?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://www.triggercmd.com/forum/topic/3394/reregistering-triggercmd-on-a-new-pc-and-copying-across-all-commands</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 23:16:10 GMT</lastBuildDate><atom:link href="https://www.triggercmd.com/forum/topic/3394.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 06 Nov 2026 23:34:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Reregistering Triggercmd on a New PC and copying across all commands on Sat, 07 Nov 2026 01:59:17 GMT]]></title><description><![CDATA[<p dir="auto">I ended up deleting the computer from my account, uninstalling trigger from pc and deleting the trigger directory user settings.</p>
<p dir="auto">Lucky I had a copy of my settings/commands from my old pc. I copied across the file contents and it worked.</p>
<p dir="auto">Has to be an easier as all that is technically changing is the MAC address?</p>
<p dir="auto">Also, if u use my than 1 PC do u need to create a shutdown command for each PC and edit the voice command to include the PC name or and will it work by using 1 shutdown command and simply say "shutdown (computername)"</p>
]]></description><link>https://www.triggercmd.com/forum/post/8986</link><guid isPermaLink="true">https://www.triggercmd.com/forum/post/8986</guid><dc:creator><![CDATA[Edwin Zahra]]></dc:creator><pubDate>Sat, 07 Nov 2026 01:59:17 GMT</pubDate></item></channel></rss>
