    How to use Off Command
    30 Posts 11 Posters 67.3k Views 4 Watching
    • David JonesD Offline
      David Jones @Russ
      @russ Works like a charm .. a newbee to this.
      Now how to send a voice/ text back to my Google Nest Mini.
      David Jones MVP
      https://github.com/djaus2
      @IOTMaestro
        David Jones @David Jones
        @david-jones I am using Cast from Windows. Chasing equivalent for RPi on Raspian.
        David Jones MVP
        @IOTMaestro
        • Tobias KnabeT Offline
          Tobias Knabe
            I'm trying to set up a command "Turn ON Monitors" and "Turn OFF monitors" for Alexa.
            Am I doing something wrong here? Doesn't work.
            Thank you
              @David-0, what you show in that screenshot looks correct, assuming nircmd.exe is in that "c:\local apps\nircmd" folder. It's good you quoted the full path because it contains a space.
              Do those commands work if you run them locally in a powershell or cmd window? I suppose the monitor on command would be difficult to type if the monitor is off, but you could press the up arrow and delete the two f's and add an n and press enter.
              Also, what if you run them from the website, like from your phone? Does that work? If not, you should troubleshoot that before moving on to Alexa (or Smart Things). When you're ready to move on, please check for this page to make sure it shows the "on" Alexa phrase. If it's not there, something is wrong, like maybe your computer isn't your default computer or it doesn't have a voice word set (which you only need to set if it's not your default computer).
              I've had pretty good luck with nircmd but some monitors don't respond to nircmd's on/off commands, so you'll want to test the monitor off command manually first.
                @Russ Hi
                Thanks for your continuous support.
                1. Yes, the commands work from the website, triggered from my phone
                2. I have separated both commands.
                • I've changed the "Monitors ON" command to sendkeypress to see if it works better than monitors on.
                • Now, Both commands work fine from the website AND from Alexa as well.
                • The "Nircmd monitor on" command still doesn't work for some reason (hence I changed to sendkeypress)
                • It also doesn't work if I use the "Off Command" option in your Windows App, I apparently have to make 2 separate commands.
                Thanks a lot! Sorry for my many questions, I'm just starting with TRIGGERcmd.
                Until now, I was using ACC (AssistantComputerControl) and IFTTT in my Alexa routines but as of 31 October, IFTTT won't be available in Alexa anymore in the UK so I needed to switch to something else.
                Money well spent on TRIGGERcmd!!
                        fala portuges
                        • XanderX Offline
                          Xander @Russ
                          @Russ I'm trying to setup an on/off command for some services. The PC is x86 so I'm just editing the JSON file.
                          Here's the line inside the JSON:
                          {"trigger":"Remote","command":"C:\Users\STICK10\Documents\SC on.bat","offCommand":"C:\Users\STICK10\Documents\SC off.bat","ground":"foreground","voice":"Remote","voiceReply":"Okay","allowParams":"true" },
                          When I try to trigger it, it's only running the SC ON batch file, not the OFF. What's my error? Or do I need to set these as two different commands altogether?
                          Inside TCMD's cmd window:
                          { trigger: 'Remote',
                          params: 'on' }
                          Running trigger: Remote Command: C:\Users\STICK10\Documents\SC on.bat
                          Reported: Command Ran
                          params: 'off' }
                            Russ @Xander
                            @Xander, I just tried sending "off" with this commands.json entry and it worked for me.
                              "trigger": "Remote",
                              "command": "C:\\Users\\STICK10\\Documents\\SC on.bat",
                              "offCommand": "C:\\Users\\STICK10\\Documents\\SC off.bat",
                              "ground": "foreground",
                              "voice": "",
                              "voiceReply": "",
                              "allowParams": "true"
                            This was my output:
                            { trigger: 'Remote', id: '___', params: 'off' }
                            Running trigger: Remote  Command: C:\Users\STICK10\Documents\SC off.bat
                            So maybe you're using a old version of the agent from before I added the logic to use the offCommand field. I know you're running in on an x86 Windows box, so you're not running the normal agent. You can probably just update the agent.js file.
                            • XanderX Offline
                              Xander @Russ
                              @Russ That's probably it. The agent.js has a date stamp of Nov 2017. Closed tcmd, updated from your link (old was 23kb, new is 348kb. Quite the diff!)
                              But, on starting the batch file, I get an "unexpected token" error. It also overwrote my .json file but it was mostly the line above so I'll redo it if I need to. Swapped the old .js back and it runs so something is amiss.
                              SyntaxError: Unexpected token <
                                  at createScript (vm.js:80:10)
                                  at Object.runInThisContext (vm.js:139:10)
                                  at Module._compile (module.js:599:28)
                                  at Object.Module._extensions..js (module.js:646:10)
                                  at Module.load (module.js:554:32)
                                  at tryModuleLoad (module.js:497:12)
                                  at Function.Module._load (module.js:489:3)
                                  at bootstrap_node.js:608:3
                                Russ @Xander
                                @Xander, the latest version of agent.js is about 23k. Maybe try again to download it? Or look at the one you have maybe there's a clue what's wrong with it. It shouldn't be that big.
                                • XanderX Offline
                                  Xander @Russ
                                  @Russ D'oh. The link here showed it went to ...node.js so I downloaded from here but now it's clear that it was a page about it so I've DL'd it properly 🤦🏻‍♂️
                                  That's back up and running.
                                  Question, though. I switched the command to use SCHTASKS to run a job of the same batch files to circumvent any UAC issues but SCoff doesn't work in either bat or task form. The cmd window -says- it's being called but no window is called. Any ideas?
                                     {"trigger":"Users","command":"schtasks.exe /run /tn users","ground":"foreground","voice":"users"},
                                     {"trigger":"Connect","command":"schtasks.exe /run /tn SCon","ground":"background","voice":"connect"},
                                     {"trigger":"Disconnect","command":"schtasks.exe /run /tn SCoff","ground":"background","voice":"disconnect"},
                                     {"trigger":"Remote","command":"schtasks.exe /run /tn SCon","offCommand":"schtasks.exe /run /tn SCoff","ground":"foreground","voice":"Remote","voiceReply":"Okay","allowParams":"true" },
                                     {"trigger":"Reboot","command":"shutdown /r /t 10","ground":"foreground","voice":"reboot"}
                                  In case I would need them as separate commands, I created the Connect/Disconnect commands which I think are fine but they don't show in the TCMD trigger page at all.
                                    Russ @Xander
                                    @Xander, I think the reason those 2 commands don't show up in your account is you've set them as "background" commands and you're not running the background agent. You'll need to run the background agent or switch them to foreground.
                                    You wrote, "SCoff doesn't work in either bat or task form." Does it work if you run it manually from a cmd prompt? You might want to put something in your .bat file that logs to a file so you know for sure whether the .bat is running. I just wonder if it's running but it's getting an error that you can't see. Something like this would at least confirm whether it's running or not:
                                    echo SCoff ran >> c:\logs\scoff.log
                                    • XanderX Offline
                                      Xander @Russ
                                      @Russ Sorry for the delayed reply; crazy week.
                                      Background was the problem on the one part.
                                      On the other, for some weird reason, Task Scheduler was renaming the actual .job from "SCoff" to "SC off" so that the path was wrong. Once I spotted that, I got it working.
                                      Just to check - I've been running the x86 version of TCMD on that PC for...years? Other than the updated .js, there's no newer version? The main DL is x64.
                                        Russ @Xander
                                        @Xander, there's no official x86 TRIGGERcmd agent version. If you updated agent.js, you've got the latest functionality.
                                        • YoniY Offline
                                          Yoni @Russ
                                          @Russ May be worth updating the instructions to indicate that "on" and "off" are case sensitive if you want it to automatically choose between the On and Off commands. (Alternatively ignore case for on and off to choose between on command and off command)
                                          e.g. I used IFTTT and sent "ON" or "OFF" as parameters, and it just sent those as arguments to my ON command.
                                          Once I fixed it to "on" and "off" it properly instead chose between the commands instead of using them as arguments.
                                            Russ @Yoni
                                            @Yoni, thanks for letting me know. I'll make it case-insensitive in the next version.
