    How to use Off Command
    30 Posts 11 Posters 68.7k Views 4 Watching
      Russ @Terry Ap
      @Terry-Ap, this is already available in the latest version of the Windows agent. I'm having trouble with the Mac version and I haven't started trying to build the Linux version yet. I hope to finish those soon. Maybe within a couple weeks.
      • R Offline
        Rob Lee
        Russ - is this working in windows currently or no? i see you said above that it is - but the option is still grayed out for me. I've updated the agent and everything, so just trying to figure out if there's an issue on my end or if it's just not ready.
          Russ @Rob Lee
          @Rob-Lee, the "Off Command" field is greyed out if "Allow Parameters" is set to false.
          Allow Parameters has to be true if you want to use the Off Command field.
          I'm glad you asked, because it's not particularly intuitive.
          • DJD Offline
            DJ
            On Windows 10. I tried this example and when I asked Alexa to "turn on calculator" it failed. I had to ask "turn Calculator on" for it to work. no biggie there. But when I said "turn Calculator off" it opened another instance of calculator and said as much in reply from my Echo show. What's the issue?
              Russ @DJ
              @DJ, if you want to do something else when you tell Alexa/Google to turn the virtual device off, you need to populate the Off Command field set Allow Parameters to true.
              In this screenshot you'll see I'm closing calculator when Alexa turns the device off.
              • David JonesD Offline
                David Jones @Russ
                @russ Works like a charm .. a newbee to this.
                Now how to send a voice/ text back to my Google Nest Mini.
                David Jones MVP
                https://github.com/djaus2
                @IOTMaestro
                  David Jones @David Jones
                  @david-jones I am using Cast from Windows. Chasing equivalent for RPi on Raspian.
                  David Jones MVP
                  @IOTMaestro
                  • Tobias KnabeT Offline
                    Tobias Knabe
                      I'm trying to set up a command "Turn ON Monitors" and "Turn OFF monitors" for Alexa.
                      Am I doing something wrong here? Doesn't work.
                      Thank you
                        @David-0, what you show in that screenshot looks correct, assuming nircmd.exe is in that "c:\local apps\nircmd" folder. It's good you quoted the full path because it contains a space.
                        Do those commands work if you run them locally in a powershell or cmd window? I suppose the monitor on command would be difficult to type if the monitor is off, but you could press the up arrow and delete the two f's and add an n and press enter.
                        Also, what if you run them from the website, like from your phone? Does that work? If not, you should troubleshoot that before moving on to Alexa (or Smart Things). When you're ready to move on, please check for this page to make sure it shows the "on" Alexa phrase. If it's not there, something is wrong, like maybe your computer isn't your default computer or it doesn't have a voice word set (which you only need to set if it's not your default computer).
                        I've had pretty good luck with nircmd but some monitors don't respond to nircmd's on/off commands, so you'll want to test the monitor off command manually first.
                          @Russ Hi
                          Thanks for your continuous support.
                          1. Yes, the commands work from the website, triggered from my phone
                          2. I have separated both commands.
                          • I've changed the "Monitors ON" command to sendkeypress to see if it works better than monitors on.
                          • Now, Both commands work fine from the website AND from Alexa as well.
                          • The "Nircmd monitor on" command still doesn't work for some reason (hence I changed to sendkeypress)
                          • It also doesn't work if I use the "Off Command" option in your Windows App, I apparently have to make 2 separate commands.
                          Thanks a lot! Sorry for my many questions, I'm just starting with TRIGGERcmd.
                          Until now, I was using ACC (AssistantComputerControl) and IFTTT in my Alexa routines but as of 31 October, IFTTT won't be available in Alexa anymore in the UK so I needed to switch to something else.
                          Money well spent on TRIGGERcmd!!
                                  fala portuges
                                  • XanderX Offline
                                    Xander @Russ
                                    @Russ I'm trying to setup an on/off command for some services. The PC is x86 so I'm just editing the JSON file.
                                    Here's the line inside the JSON:
                                    {"trigger":"Remote","command":"C:\Users\STICK10\Documents\SC on.bat","offCommand":"C:\Users\STICK10\Documents\SC off.bat","ground":"foreground","voice":"Remote","voiceReply":"Okay","allowParams":"true" },
                                    When I try to trigger it, it's only running the SC ON batch file, not the OFF. What's my error? Or do I need to set these as two different commands altogether?
                                    Inside TCMD's cmd window:
                                    { trigger: 'Remote',
                                    params: 'on' }
                                    Running trigger: Remote Command: C:\Users\STICK10\Documents\SC on.bat
                                    Reported: Command Ran
                                    params: 'off' }
                                      Russ @Xander
                                      @Xander, I just tried sending "off" with this commands.json entry and it worked for me.
                                        "trigger": "Remote",
                                        "command": "C:\\Users\\STICK10\\Documents\\SC on.bat",
                                        "offCommand": "C:\\Users\\STICK10\\Documents\\SC off.bat",
                                        "ground": "foreground",
                                        "voice": "",
                                        "voiceReply": "",
                                        "allowParams": "true"
                                      This was my output:
                                      { trigger: 'Remote', id: '___', params: 'off' }
                                      Running trigger: Remote  Command: C:\Users\STICK10\Documents\SC off.bat
                                      So maybe you're using a old version of the agent from before I added the logic to use the offCommand field. I know you're running in on an x86 Windows box, so you're not running the normal agent. You can probably just update the agent.js file.
                                      • XanderX Offline
                                        Xander @Russ
                                        @Russ That's probably it. The agent.js has a date stamp of Nov 2017. Closed tcmd, updated from your link (old was 23kb, new is 348kb. Quite the diff!)
                                        But, on starting the batch file, I get an "unexpected token" error. It also overwrote my .json file but it was mostly the line above so I'll redo it if I need to. Swapped the old .js back and it runs so something is amiss.
                                        SyntaxError: Unexpected token <
                                            at createScript (vm.js:80:10)
                                            at Object.runInThisContext (vm.js:139:10)
                                            at Module._compile (module.js:599:28)
                                            at Object.Module._extensions..js (module.js:646:10)
                                            at Module.load (module.js:554:32)
                                            at tryModuleLoad (module.js:497:12)
                                            at Function.Module._load (module.js:489:3)
                                            at bootstrap_node.js:608:3
                                          Russ @Xander
                                          @Xander, the latest version of agent.js is about 23k. Maybe try again to download it? Or look at the one you have maybe there's a clue what's wrong with it. It shouldn't be that big.
                                          • XanderX Offline
                                            Xander @Russ
                                            @Russ D'oh. The link here showed it went to ...node.js so I downloaded from here but now it's clear that it was a page about it so I've DL'd it properly 🤦🏻‍♂️
                                            That's back up and running.
                                            Question, though. I switched the command to use SCHTASKS to run a job of the same batch files to circumvent any UAC issues but SCoff doesn't work in either bat or task form. The cmd window -says- it's being called but no window is called. Any ideas?
                                               {"trigger":"Users","command":"schtasks.exe /run /tn users","ground":"foreground","voice":"users"},
                                               {"trigger":"Connect","command":"schtasks.exe /run /tn SCon","ground":"background","voice":"connect"},
                                               {"trigger":"Disconnect","command":"schtasks.exe /run /tn SCoff","ground":"background","voice":"disconnect"},
                                               {"trigger":"Remote","command":"schtasks.exe /run /tn SCon","offCommand":"schtasks.exe /run /tn SCoff","ground":"foreground","voice":"Remote","voiceReply":"Okay","allowParams":"true" },
                                               {"trigger":"Reboot","command":"shutdown /r /t 10","ground":"foreground","voice":"reboot"}
                                            In case I would need them as separate commands, I created the Connect/Disconnect commands which I think are fine but they don't show in the TCMD trigger page at all.
