    smartthings
    45 Posts 13 Posters 30.4k Views 6 Watching
      @Russ Hi. I have the same ST app version (1.8.07.23) and I'm still getting the same error message!d0030099-18db-4e4e-9206-fa267771ffc1-image.png
        @David-0, thanks for letting me know. I'll test it again soon and let you know what I see.
        • MauroM Offline
          Mauro
          I have the same problem, triggercmd app exist, but can't connect.
            @Russ Thank you so much for your help!
              @David-0 you're welcome.
                @Russ Hi Thanks.
                SmartThings settings:
                sorry where do I find information in the "smartthings connector"?
                  @David-0, that info needs to match your settings on the connector you setup in your Samsung account here:
                  https://smartthings.developer.samsung.com/workspace/projects
                    @Russ Works now, my apologies, thanks for your help
                      @David-0 awesome!
                      BTW, I saw you were asking about the Alexa skills here but you don't actually need to activate any of the TRIGGERcmd Alexa skills if you link your SmartThings account with Alexa. The pattern for running commands via Smart Things Alexa skill is similar to the TRIGGERcmd Smart Home Alexa skill: Alexa, turn on calculator. They both use that same pattern because they both create Alexa devices named after voice name of your commands.
                      • Diego GuerraD Offline
                        Diego Guerra
                        Hi guys,
                        @Russ I'm having trouble to create the connection, Samsung is reporting this error: Sorry. A temporary server error occurred. Please try again in a few minutes.
                        How can I solve this ?
                          Russ @Diego Guerra
                          @Diego-Guerra, can you send me screenshots of your SmartThings values in your profile and the connector you created in your SmartThings account? I want to see that they match. Send them via the Forum chat to keep them private.
                          • schmuttisS Offline
                            schmuttis
                            Russ I got up to step 26. Log into TRIGGERcmd (if necessary) and ended up with two TriggerCMDs TwoTriggerCMDs.png
                            No matter which one I choose when I login I get an error: ErrorAfterLoggingIn.png
                            Do you have any idea what I'm doing incorrectly?
                            Thanks for your help.
                              Russ @schmuttis
                              @schmuttis, please send me your SmartThings settings from your profile page and your SmartThings account. I want to confirm everything matches up. Send them to me via the chat feature too because you don't want make your settings public.
                              All 4 values need to match up between your TRIGGERcmd profile and your SmartThings Cloud Connector.
                              schmuttisS 1 Reply Last reply Reply Quote 0
                                schmuttis @Russ
                                • RussR Russ unpinned this topic on
                                • A AZRushFan referenced this topic on
                                • Irfan Khan 0I Offline
                                  Irfan Khan 0
                                  Well I got the app created in SmartThings developer and see it in my app. But I still get no devices. I DO see the devices in my Google Home app and it works via that, and I have GH connected to ST. But the devices don’t come through. I do have voice triggers as well, and set the PC to have a voice trigger as well.
                                  Edit: I deleted and readded TriggerCMD and got an “internal server error” and then it continued to add but said no devices were available
                                  Irfan Khan 0I 1 Reply Last reply Reply Quote 0
                                    Irfan Khan 0 @Irfan Khan 0
                                    @Irfan-Khan-0
                                    Edit2: now when I do it again I get “discovery request failed”
                                      Russ @Irfan Khan 0
                                      @Irfan-Khan-0, I just tested it an it's working for me.
                                      Could you try clicking the "Regenerate" button to regenerate the Client ID and Client Secret under App credentials, then copy/paste those into your user profile?
                                      And make sure the "SmartThings Device Cloud Credentials Client ID" values (starts with st-) and the "SmartThings Device Cloud Credentials Client Secret" value match those values under App Details?
                                      If those 4 values match, and you have these URL's setup, it should work:
                                      Authorization URI: https://www.triggercmd.com/oauth/authorize
                                      Token URI: https://www.triggercmd.com/oauth/token
                                        Cristian Dindinelli
                                        hi, i just changed my pc and i messed up everything so i deleted triggercmd from smartthing, but now i can't install it anymore. This link https://developer.smartthings.com/workspace/projects/new won't make me create a new project but send me to an other page.
                                          Cristian Dindinelli @Cristian Dindinelli
                                          @Cristian-Dindinelli said in New SmartThings integration (2023):
                                          After some extra step, I could connect to smartthing, but only devices with "voice" command are shared, any advice?
