    smartthings
    45 Posts 13 Posters 29.3k Views 6 Watching
    • D Offline
      djsweeneyiii @Russ
      With the new Smartthings Integration (2023), I have found that the device type in Google Home is set to Light when linked to Smartthings. In GH I am able to change the Device Type when GH is linked to TRIGGERcmd but with the GH-ST link I am not and have to accept the default which then GH groups as a Light.
      Connected through: SmartThings
      Manufacturer: TRIGGERcmd
      Name from SmartThings: Stair Light
      Device type: Light
      Connected through: TRIGGERcmd Smart Home
      Name from TRIGGERcmd Smart Home: Stair Light
      Device type: Switch
      I'm not sure which method of integration works best for me, ST or GH. I may have a special case, not all of my Tcmd devices are lights. Since GH defaults ST-Tcmd Device Types to Light it groups them into lights. I now have duplicates one identified as a Switch (GH-Tcmd) the other as a Light (ST-Tcmd). The reason for the ST-Tcmd is that I use ActionTiles.com which allows me to create display panels using only ST devices. So if I want Tcmd devices in my ActionTiles panels I have to integrate Tcmd with ST.
      @Russ said in TriggerCMD Commands are assigned device type "light"?
        Russ @djsweeneyiii
        @djsweeneyiii, I'm familiar with ActionTiles. I always meant to setup a tablet with my ActionTiles panel but never did (yet).
        What problem would you have if you un-linked TRIGGERcmd from GH and just used the ST devices with device type Light?
        I could see if there's a way to make the ST devices switches in GH instead of lights if that would help.
        • D Offline
          djsweeneyiii @Russ
          @Russ Not all of my Tcmd devices are Lights, I have several devices that are switches. Everything from ST-Tcmd is defined as a light so my switches get grouped with the GH lights. When I execute a GH voice command for lights it will also execute my switches.
          This is a similar issue @Rancor had.
          I don't know if GH-Tcmd devices will show up in ActionTiles because the devices do not show in ST.
          • D Offline
            djsweeneyiii @djsweeneyiii
            @Russ I am slowly moving away from my Tcmd-X10 system. The New ST integration has prolonged my efforts, since the integration works so well. The only issue is that I cannot get the X10-switch status if I manually operate the switch. Operating the switch via Voice commands or ActionTiles reflects the actual state of the X10 switch.
              Russ @djsweeneyiii
              @djsweeneyiii, I see, so it sounds like it would be better if the ST devices were switches instead of lights, or even better if you could configure some as lights and some as switches like you can with the GH TRIGGERcmd devices.
              • D Offline
                djsweeneyiii @Russ
                @Russ Yes. It looks like GH will default Switch Device Type to Lights; Light(Switch), but I am able to override this type in GH.
                • G Offline
                  Garcia
                  @Russ said in New SmartThings integration (2023):
                  https://www.triggercmd.com/oauth/token
                  Hello,
                  I am new in TRIGGERcmd, and need some clarification.
                  I did the install TRIGGERcmd on IFTTT and works perfectly.
                  Now Id like to integrate it in Smartthings. I did install it according to your recommendation, and update my Profile as well as smartthing in developer mode. When adding a device, I can see the option "Mytesting devices", and then "My setup APP" and "Mydevices" but when clicking on the Devices, I see only the 2 basic app: Calculator , Notepad, and none of my own app.
                  any ideas ?
                  Eric
                    Russ @Garcia
                    @Garcia, do you see only Calculator and Notepad listed on this Smart Home Voice Commands page too? If so, you probably haven't given your other commands a voice word yet, so you won't see them in SmartThing either.
                    If you fill that Voice field in, your commands should show up because the SmartThings integration uses the same logic as the Alexa and Google Assistant integrations for choosing which devices to create.
                    • G Offline
                      Garcia @Russ
                      @Russ Thanks a lot. It works now.
                      • Sylvain BoisséS Offline
                        Sylvain Boissé
                          Sylvain Boissé @Russ
                          @Russ At the step 27, I receive this message on my SmartThings app:
                          Access_token_request_failed….
                          What I did wrong?
                          • P Offline
                            pjthaut-gmail.co
                            Thanks for the good work.
                            Unfortunately, in the SmartThings app, when I add device, under Partner devices/My Testing Devices, I see :-
                            My setup apps
                            My devices
                            If I tap on either of these, I get :
                            Couldn't add device
                            A network or server error occurred. Try again later
                            At least one of my commands has a voice field
                            I've created the project three times now to carefully check the entries.
                            Is there a way to get further diagnostics?
                              Russ @pjthaut-gmail.co
                              @pjthaut-gmail-co, I might see the problem.
                              None of your computers have a voice word associated.
                              For a command to get a SmartThings device (or Alexa device for that matter), the computer needs a voice word or the computer must be your default computer.
                              You can set your default computer in your profile.
                              One way to confirm what commands will get a device created is look at your Smart Home Voice Commands page. That page only lists the commands that are setup for voice activation. Only those commands will get a SmartThings device created.
                              If that's not the problem, please send me some screenshots of your config via the forum chat. I might be able to spot the issue.
                                Russ @Sylvain Boissé
                                @Sylvain-Boissé, did you ever get it working? Sorry for the late reply.
                                EDIT: Nevermind - I see in our chat that you got it working.
                                  @pjthaut-gmail-co, I'm seeing that error too now. As soon as I tap "TRIGGERcmd" under My Testing Devices I see this error:
                                  I didn't change anything, so I think the Samsung SmartThings system changed somehow.
                                  I found that the TRIGGERcmd servers don't receive any request when I tap the "TRIGGERcmd".
                                  I'll work on it and let you know what I find.
                                  • P Offline
                                    pjthaut-gmail.co
                                    Re network error. It the SmartThings app version. 1.8.01.22 works. Previous versions available on apkpure fail to go into developer mode because of file permissions that can't be set. I've not tried 1.8.01.44 . Another Android device running the latest version now shows the devices.
                                      Thanks you @pjthaut-gmail-co. I have SmartThings version 1.8.05.24 on my Samsung S20 phone and I get the error. I'll try some older versions. If that works for me too, I'll report this to Samsung SmartThings support.
                                      EDIT: I also found that it works if I use version 1.8.01.22 of the SmartThings app.
                                        Russ @Russ
                                        I got a reply from Samsung SmartThings:
                                        Hi Russell
                                        Thank you for contacting SmartThings Developer Support.
                                        We were able to reproduce the issue also in the 1.8.05.24, we will create a report as soon as we have updated I will inform you.
                                        Cristian DindinelliC Tiago DiasT 2 Replies Last reply Reply Quote 0
                                          Cristian Dindinelli @Russ
                                          @Russ nice, waiting for news
                                          • G Offline
                                            gfh0229
                                            Need a little help. I'm setting up SmartThings integration with Triggercmd on a PC, and have proceeded thru step 16 (Display Name & Logo). However when I go to SAVE the project, I get a 403 error. Please let me know how to clear. Thanks.
                                            <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"> <HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"> <TITLE>ERROR: The request could not be satisfied</TITLE> </HEAD><BODY> <H1>403 ERROR</H1> <H2>The request could not be satisfied.</H2> <HR noshade size="1px"> Request blocked. We can't connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner. <BR clear="all"> If you provide content to customers through CloudFront, you can find steps to troubleshoot and help prevent this error by reviewing the CloudFront documentation. <BR clear="all"> <HR noshade size="1px"> <PRE> Generated by cloudfront (CloudFront) Request ID: MIY0dFDLnqckr0fXeyfHtZUB7eMuLbfJi7wwnvpB3to6TATFfUFCdA== </PRE> <ADDRESS> </ADDRESS> </BODY></HTML>
