    smartthings
    45 Posts 13 Posters 30.4k Views 6 Watching
    • D Offline
      djsweeneyiii @djsweeneyiii
      @Russ I am slowly moving away from my Tcmd-X10 system. The New ST integration has prolonged my efforts, since the integration works so well. The only issue is that I cannot get the X10-switch status if I manually operate the switch. Operating the switch via Voice commands or ActionTiles reflects the actual state of the X10 switch.
        Russ @djsweeneyiii
        @djsweeneyiii, I see, so it sounds like it would be better if the ST devices were switches instead of lights, or even better if you could configure some as lights and some as switches like you can with the GH TRIGGERcmd devices.
        • D Offline
          djsweeneyiii @Russ
          @Russ Yes. It looks like GH will default Switch Device Type to Lights; Light(Switch), but I am able to override this type in GH.
          • G Offline
            Garcia
            @Russ said in New SmartThings integration (2023):
            https://www.triggercmd.com/oauth/token
            Hello,
            I am new in TRIGGERcmd, and need some clarification.
            I did the install TRIGGERcmd on IFTTT and works perfectly.
            Now Id like to integrate it in Smartthings. I did install it according to your recommendation, and update my Profile as well as smartthing in developer mode. When adding a device, I can see the option "Mytesting devices", and then "My setup APP" and "Mydevices" but when clicking on the Devices, I see only the 2 basic app: Calculator , Notepad, and none of my own app.
            any ideas ?
            Eric
              Russ @Garcia
              @Garcia, do you see only Calculator and Notepad listed on this Smart Home Voice Commands page too? If so, you probably haven't given your other commands a voice word yet, so you won't see them in SmartThing either.
              If you fill that Voice field in, your commands should show up because the SmartThings integration uses the same logic as the Alexa and Google Assistant integrations for choosing which devices to create.
              • G Offline
                Garcia @Russ
                @Russ Thanks a lot. It works now.
                • Sylvain BoisséS Offline
                  Sylvain Boissé
                    Sylvain Boissé @Russ
                    @Russ At the step 27, I receive this message on my SmartThings app:
                    Access_token_request_failed….
                    What I did wrong?
                    • P Offline
                      pjthaut-gmail.co
                      Thanks for the good work.
                      Unfortunately, in the SmartThings app, when I add device, under Partner devices/My Testing Devices, I see :-
                      My setup apps
                      My devices
                      If I tap on either of these, I get :
                      Couldn't add device
                      A network or server error occurred. Try again later
                      At least one of my commands has a voice field
                      I've created the project three times now to carefully check the entries.
                      Is there a way to get further diagnostics?
                        Russ @pjthaut-gmail.co
                        @pjthaut-gmail-co, I might see the problem.
                        None of your computers have a voice word associated.
                        For a command to get a SmartThings device (or Alexa device for that matter), the computer needs a voice word or the computer must be your default computer.
                        You can set your default computer in your profile.
                        One way to confirm what commands will get a device created is look at your Smart Home Voice Commands page. That page only lists the commands that are setup for voice activation. Only those commands will get a SmartThings device created.
                        If that's not the problem, please send me some screenshots of your config via the forum chat. I might be able to spot the issue.
                          Russ @Sylvain Boissé
                          @Sylvain-Boissé, did you ever get it working? Sorry for the late reply.
                          EDIT: Nevermind - I see in our chat that you got it working.
                            @pjthaut-gmail-co, I'm seeing that error too now. As soon as I tap "TRIGGERcmd" under My Testing Devices I see this error:
                            I didn't change anything, so I think the Samsung SmartThings system changed somehow.
                            I found that the TRIGGERcmd servers don't receive any request when I tap the "TRIGGERcmd".
                            I'll work on it and let you know what I find.
                            • P Offline
                              pjthaut-gmail.co
                              Re network error. It the SmartThings app version. 1.8.01.22 works. Previous versions available on apkpure fail to go into developer mode because of file permissions that can't be set. I've not tried 1.8.01.44 . Another Android device running the latest version now shows the devices.
                                Thanks you @pjthaut-gmail-co. I have SmartThings version 1.8.05.24 on my Samsung S20 phone and I get the error. I'll try some older versions. If that works for me too, I'll report this to Samsung SmartThings support.
                                EDIT: I also found that it works if I use version 1.8.01.22 of the SmartThings app.
                                  Russ @Russ
                                  I got a reply from Samsung SmartThings:
                                  Hi Russell
                                  Thank you for contacting SmartThings Developer Support.
                                  We were able to reproduce the issue also in the 1.8.05.24, we will create a report as soon as we have updated I will inform you.
                                  Cristian DindinelliC Tiago DiasT 2 Replies Last reply Reply Quote 0
                                    Cristian Dindinelli @Russ
                                    @Russ nice, waiting for news
                                    • G Offline
                                      gfh0229
                                      Need a little help. I'm setting up SmartThings integration with Triggercmd on a PC, and have proceeded thru step 16 (Display Name & Logo). However when I go to SAVE the project, I get a 403 error. Please let me know how to clear. Thanks.
                                      <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"> <HTML><HEAD><META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"> <TITLE>ERROR: The request could not be satisfied</TITLE> </HEAD><BODY> <H1>403 ERROR</H1> <H2>The request could not be satisfied.</H2> <HR noshade size="1px"> Request blocked. We can't connect to the server for this app or website at this time. There might be too much traffic or a configuration error. Try again later, or contact the app or website owner. <BR clear="all"> If you provide content to customers through CloudFront, you can find steps to troubleshoot and help prevent this error by reviewing the CloudFront documentation. <BR clear="all"> <HR noshade size="1px"> <PRE> Generated by cloudfront (CloudFront) Request ID: MIY0dFDLnqckr0fXeyfHtZUB7eMuLbfJi7wwnvpB3to6TATFfUFCdA== </PRE> <ADDRESS> </ADDRESS> </BODY></HTML>
                                        Russ @gfh0229
                                        @gfh0229, I just clicked that Save button and it worked for me. Maybe they fixed it on their end, or maybe there's something in one of your data fields that it's rejecting. 403 is access denied, but their error also suggested, "There might be too much traffic or a configuration error."
                                        Can you try it again now that you've waited a day?
                                        • Tiago DiasT Offline
                                          Tiago Dias @Russ
                                          @Russ I have that issue as well. Are they going to fix it soon? Thx
                                            Russ @Tiago Dias
                                            @Tiago-Dias, do you have the same problem as @gfh0229? Where you click this SAVE button and you get a 403 error?
                                            I don't have that problem. When I click SAVE, I see this:
                                            Or, are you getting the "Couldn't add device A network or server error occurred.
                                            Try again later" error? I'm still waiting to hear back from Samsung about that. I see it's still an issue in their latest version 1.8.06.23.
