Problem: Run Call Of Duty Warzone
ive been working on code...
to not remove posts.. im just going to add again... but modified...
my case now... error stop shows. but still not working when triggercmd start it. even by a .bat filei have 3 monitors... so i changed $x $y $right $bottom values on ImageSearch.au3 (this part still missing negative position. suposing center monitor is the main one with 0-1920px and 0-1080px
well... the problem stills on triggercmd not runing the scripts as a normal person click.
cod.au3
#include <ImageSearch.au3>
$x = FileReadLine("ImageSearch.au3")
$y = FileReadLine("ImageSearch.au3")Sleep(500)
Run ("E:\Battle.net\Battle.net Launcher.exe")
WinActivate("Battle.net")
WinActive("Battle.net")
;while(1)
Run("ImageSearch.au3")
$Search = _ImageSearch("botao.png", 0, $x, $y,0)
if $Search = 1 Then
startapp()
Else
EndIf
;WEndFunc startapp()
Sleep(200)
MouseMove($x,$y+0,0)
Sleep(200)
MouseClick("primary")
endapp()
EndFuncFunc endapp()
Exit
EndFuncImageSearch.au3
#include-once
; AutoIt Version: 3.0
; Language: English
; Description: Functions that assist with Image Search
; Require that the ImageSearchDLL.dll be loadable
; Description: Find the position of an image on the desktop
; Syntax: _ImageSearchArea, _ImageSearch
; Parameter(s):
; $findImage - the image to locate on the desktop
; $tolerance - 0 for no tolerance (0-255). Needed when colors of
; image differ from desktop. e.g GIF
; $resultPosition - Set where the returned x,y location of the image is.
; 1 for centre of image, 0 for top left of image
; $x $y - Return the x and y location of the image
; Return Value(s): On Success - Returns 1
; On Failure - Returns 0
; Note: Use _ImageSearch to search the entire desktop, _ImageSearchArea to specify
; a desktop region to search
Func _ImageSearch($findImage,$resultPosition,ByRef $x, ByRef $y,$tolerance)
return _ImageSearchArea($findImage,$resultPosition,0,0,@DesktopWidth,@DesktopHeight,$x,$y,$tolerance)
EndFuncFunc _ImageSearchArea($findImage,$resultPosition,$x1,$y1,$right,$bottom,ByRef $x, ByRef $y, $tolerance)
$x1=-1920
$y1=-1080
$right=3840
$bottom=1080
;MsgBox(0,"asd","" & $x1 & " " & $y1 & " " & $right & " " & $bottom)
if $tolerance>0 then $findImage = "*" & $tolerance & " " & $findImage
$result = DllCall("ImageSearchDLL.dll","str","ImageSearch","Int",$x1,"Int",$y1,"Int",$right,"Int",$bottom,"str",$findImage)
; Error checking goes here
If (IsArray($result) = False) Then Return 0
; If error exit
if $result[0]="0" then return 0
; Otherwise get the x,y location of the match and the size of the image to
; compute the centre of search
$array = StringSplit($result[0],"|")$x=Abs(Number($array[2]))
$y=Abs(Number($array[3]))
if $resultPosition=1 then
$x=$x + Abs(Number($array[4])/2)
$y=$y + Abs(Number($array[5])/2)
endif
return 1
EndFunc;===============================================================================
; Description: Wait for a specified number of seconds for an image to appear
; Syntax: _WaitForImageSearch, _WaitForImagesSearch
; Parameter(s):
; $waitSecs - seconds to try and find the image
Func _WaitForImageSearch($findImage,$waitSecs,$resultPosition,ByRef $x, ByRef $y,$tolerance)
$waitSecs = $waitSecs * 1000
$startTime=TimerInit()
While TimerDiff($startTime) < $waitSecs
sleep(100)
$result=_ImageSearch($findImage,$resultPosition,$x, $y,$tolerance)
if $result > 0 Then
return 1
EndIf
WEnd
return 0
; Description: Wait for a specified number of seconds for any of a set of
; images to appear
; Syntax: _WaitForImagesSearch
; Parameter(s):
; $findImage - the ARRAY of images to locate on the desktop
; - ARRAY[0] is set to the number of images to loop through
; ARRAY[1] is the first image
; Return Value(s): On Success - Returns the index of the successful find
Func _WaitForImagesSearch($findImage,$waitSecs,$resultPosition,ByRef $x, ByRef $y,$tolerance)
for $i = 1 to $findImage[0]
sleep(100)
$result=_ImageSearch($findImage[$i],$resultPosition,$x, $y,$tolerance)
if $result > 0 Then
return $i
EndIf
Next
WEnd
return 0
EndFunc -
reducing to 1 file...
still same problem...
#include-once
; Language: English
; Parameter(s):
$x1=-1920
$y1=-1080
$right=3840
$bottom=1080
; If error exit
endif
return 1
; Parameter(s):
sleep(100)
if $result > 0 Then
return 1
EndIf
WEnd
return 0
; images to appear
; Parameter(s):
sleep(100)
if $result > 0 Then
return $i
EndIf
Next
WEnd
return 0
EndFunc;#include <ImageSearch.au3>
Sleep(20000)
;while(1)
;Run("ImageSearch.au3")
$x = 1
$y = 1
if $Search = 1 Then
startapp()
Else
MsgBox("resultado", $Search, "A Busca pela Imagem esta retornando 0")
EndIf
;WEnd
Func startapp()
Sleep(200)
Sleep(200)
endapp()
Exit
EndFunc -
@Arthur-Oscar, I tried for a couple hours and I couldn't make it work.
That battle.net app not a normal Windows app, so the normal AutoIt tricks aren't working.
@Russ but works when i click manually.. just when triggercmd try it... it doesnt works... maybe some argument not passing maybe? idk like tell to triggercmd to execute script as operator
thats battle.net app
@Arthur-Oscar, I don’t know why, but I can’t get it to work at all – with or without TRIGGERcmd. If I could make it work without TRIGGERcmd I could try to troubleshoot it with TRIGGERcmd.
@Russ you can change the PNG file into a piece of your desktop printscreen to try.
This way you dont need battle.net app.
BTW, i forgot to ask.. you have imagesearchdll.dll file?
if you havent, here the link.
https://www.autoitscript.com/forum/topic/148005-imagesearch-usage-explanation/
its needed to work.. i tried to send to your email, but gmail doesnt allow me to send.
like this one of mine desktop -
@Russ wich system triggercmd is runing? 32 or 64bit? i noticed if i compile script to 32bits script never works... maybe this influence? if trigger is runing as 32bits... idk
A Arthur Oscar referenced this topic on
@Arthur-Oscar, the TRIGGERcmd agent is 64bit.
Also yes, I have imagesearchdll.dll in the same folder with the cod.au3 script and the compiled cod.exe.
I have seen it detect and move to the Play button, but it usually doesn't, and when it did move to the Play button it didn't click it.
Battle.net made it very difficult to automatically start a game.
@Russ sometimes you have to put a wait after movemouse... it click and move at same time
@Russ as i told before, executing the script by myself, it works fine, but when i order to trigger result scan is 0.
@Arthur-Oscar, I understand, but I can't make it work with or without TRIGGERcmd. I've tried everything. It won't click Play.
@Russ i noticed when i tell to triggercmd to execute cod.bat file... it doesnt blink at the screen, it executes on background or something?
@Arthur-Oscar, you should add a line to your cod.bat that shows something on the screen or writes something to a log like this, so you know it's running.
echo it ran >> c:\scripts\cod.logAlso, make sure Ground = foreground.
@Russ ill do it... btw i discovered why your result was returning 0 executing manually to you. try right click on au3 file and execute script as 64bits... after that... even .exe compiled 64bits runs okay.
Important information!!!!
allmost solved problem!!!just need to run cod.exe inside SysWOW64 cmd prompt
but to do this... i need edit cod.bat file
cod.bat says:
echo program running >> D:\alexa\cod\cod.log
start "" c:\Windows\SysWOW64\cmd.exe >> D:\alexa\cod\cod.exe
exit
but ofc its not working yet... path is incorrect... there is any way to type the path inside the new cmd window? or... execute cmd from 64bit path directly?
@Arthur-Oscar please try this in your cod.bat:
echo program running >> D:\alexa\cod\cod.log c:\Windows\SysWOW64\cmd.exe /c D:\alexa\cod\cod.exeThat will run your cod.exe in the 32bit cmd.exe in the SysWOW64 folder.
@Russ this way its opening in system32 mode...
i need to execute those comands in cmd from syswow64.. like this other image
I Finally Solve the problem...first of all... no .bat is needed. thanks god! hahaha
1st step:
configurates to open a link to execute cod.exe (compiled)
2nd step:
edit a link icon came from cmd (inside SysWOW64 folder) and put this link inside your folder
3rd step:
put the infos as following:
Files needed:
cmd.lnk (icon to run by triggercmd)
cod.au3 (script)
cod.exe(au3 compiled in 64bits)
imagesearch.au3
imagesearchDLL.dll
that's it...
Thanks @Russ to the help...
hope you enjoy @Luiz-Henrique-Dela-Giustina and all the others! -
Forgot to add all the files used
@Arthur-Oscar, awesome. I'm glad you got it working! Thanks for sharing your method and your files too.
