    Warzone
    7 Posts 4 Posters 4.1k Views 1 Watching
    • Arnold Martinez CastilloA Offline
      I'm trying to open Call Of Duty Warzone, but before it opens, Launcher Battle.net will open first. For the game to start I need to click on "Play" in the Launcher. Is there any way around this situation?
        Russ @Arnold Martinez Castillo
        @Arnold-Martinez-Castillo, I don't have Call Of Duty Warzone, but I did figure it out for World of Warcraft, so I think you could the same method to find the .exe file, and run it directly.
        I opened Task Manager's Details tab and sorted by the CPU column, then I opened World of Warcraft from the Battle.net app. The top CPU user was Wow.exe.
        I right-clicked Wow.exe and clicked Open file location.
        That showed me the full path to Wow.exe.
        Now I can launch it with this command:
        "C:\Program Files (x86)\World of Warcraft\_retail_\Wow.exe"
        frankerebusF 1 Reply Last reply Reply Quote 1
        • frankerebusF Offline
          frankerebus @Russ
          @Russ not work for cod, just try to run it, but dont do it
          "C:\Program Files (x86)\Call of Duty_retail_\cod.exe"
          some sugest?
            Russ @frankerebus
            @frankerebus, are you sure the path to the cod.exe is "C:\Program Files (x86)\Call of Duty_retail_\cod.exe"?
            You can find it by running Call of Duty, then open Task Manager, then right-click the task and click Open file location.
            frankerebusF 1 Reply Last reply Reply Quote 0
              frankerebus @Russ
              the cod.exe not work. even if you run it directly manually
              BUT
              resolved thanks to u ... In another forum league
              I saw that you recommended the use of autoit to make the click for you
              & ill do it an script for close teamviewer because it gives problems and also closes the battle net platform at the end¨
              *AutoIt Version: 3.3.16.1
              Author: frankerebus
              Script Function:
              Lanzar warzone y cerrar teamviewer
              #ce ----------------------------------------------------------------------------
              ; Script Start - Add your code below here
              WinMinimizeAll()
              _RunDos("start taskkill /F /IM TeamViewer.exe")
              ShellExecute ( "C:\Program Files (x86)\Battle.net\Battle.net.exe" )
              #include <Process.au3>
              Sleep(7000) ; wait 7 seconds for show "jugar"
              WinSetState("[ACTIVE]", "", @SW_MAXIMIZE)
              WinActivate ( "Battle.net" )
              $pos = WinGetPos("Battle.net")
              $x = 155
              $y = 1578
              MouseClick("left", $pos[0] + $x, $pos[1] + $y) ; click the jugar button
              Sleep(10000) ; wait 10 seconds
              _RunDos("start taskkill /F /IM Battle.net.exe")
              #include <Process.au3>*
              this script works only to launch the latest game on the platform assuming you only use call of duty or any other it's ok
              now can i tell alexa to run warzone 😄
              I HOPE IT IS USEFUL FOR SOMEONE ELSE
              RussR Arthur OscarA 2 Replies Last reply Reply Quote 0
                Russ @frankerebus
                @frankerebus, nice job! I'm glad you figured out a method that works.
                • Arthur OscarA Offline
                  Arthur Oscar @frankerebus
                  @frankerebus i did something similar too.. but as you say, assuming you only play cod and no updates open in battle.net window...
                  now im trying to make a imagesearch to find play button to detect if cod is the active game on battle.net and to click on it... i already did works runing script manually, but when i tell to triggercmd to do it... it returns 0 on my search... trying to figure why... any idea? i replyied in other topic here
                  https://www.triggercmd.com/forum/topic/1303/problem-run-call-of-duty-warzone/8?_=1684440229512
                  • RussR Russ moved this topic from Blog on
