    Problem: Run Call Of Duty Warzone
    2.8k
    • Luiz Henrique Dela GiustinaL
      Hi
      First, excuse my English.
      I'm trying to open Call Of Duty Warzone, but before it opens, Launcher Battle.net will open first. For the game to start I need to click on "Play" in the Launcher. Is there any way around this situation?
        Russ @Luiz Henrique Dela Giustina
        @Luiz-Henrique-Dela-Giustina, you could try creating an AutoIt script that clicks Play for you, like this:
        https://www.triggercmd.com/forum/topic/763/start-netflix-app/22
        • Arthur OscarA
          Arthur Oscar
          • Arthur OscarA
            Arthur Oscar
            i already did it... also i had a problem... when i click the au3 file by myself it works.. but when i put to triggercmd execute bat, au3 file, exe file or whatever... it doesnt works...
            just to explain:
            create a trigger to open battle.net launcher
            create a trigger to execute imagesearch to click the "button"
            looks autoit receive command as subscript...
            error says: subscript used on non-acessible variable.imagem_2023-05-12_210826472.png
              Russ @Arthur Oscar
              @Arthur-Oscar, if you show me your ImageSearch.au3 script, I'll take a look. It seems that $result variable is null for some reason.
              Arthur OscarA 1 Reply Last reply Reply Quote 0
              • Arthur OscarA
                Arthur Oscar @Russ
                @Russ exacly... when we manualy click at file.. it works... but when we tell to triggercmd to do it... it comes null
                #include-once
                ; AutoIt Version: 3.0
                ; Language: English
                ; Description: Functions that assist with Image Search
                ; Require that the ImageSearchDLL.dll be loadable
                ; Description: Find the position of an image on the desktop
                ; Syntax: _ImageSearchArea, _ImageSearch
                ; Parameter(s):
                ; $findImage - the image to locate on the desktop
                ; $tolerance - 0 for no tolerance (0-255). Needed when colors of
                ; image differ from desktop. e.g GIF
                ; $resultPosition - Set where the returned x,y location of the image is.
                ; 1 for centre of image, 0 for top left of image
                ; $x $y - Return the x and y location of the image
                ; Return Value(s): On Success - Returns 1
                ; On Failure - Returns 0
                ; Note: Use _ImageSearch to search the entire desktop, _ImageSearchArea to specify
                ; a desktop region to search
                Func _ImageSearch($findImage,$resultPosition,ByRef $x, ByRef $y,$tolerance)
                return _ImageSearchArea($findImage,$resultPosition,0,0,@DesktopWidth,@DesktopHeight,$x,$y,$tolerance)
                EndFunc
                Func _ImageSearchArea($findImage,$resultPosition,$x1,$y1,$right,$bottom,ByRef $x, ByRef $y, $tolerance)
                ;MsgBox(0,"asd","" & $x1 & " " & $y1 & " " & $right & " " & $bottom)
                if $tolerance>0 then $findImage = "*" & $tolerance & " " & $findImage
                $result = DllCall("ImageSearchDLL.dll","str","ImageSearch","int",$x1,"int",$y1,"int",$right,"int",$bottom,"str",$findImage)
                ; If error exit
                if $result[0]="0" then return 0
                ; Otherwise get the x,y location of the match and the size of the image to
                ; compute the centre of search
                $array = StringSplit($result[0],"|")
                $x=Int(Number($array[2]))
                $y=Int(Number($array[3]))
                if $resultPosition=1 then
                $x=$x + Int(Number($array[4])/2)
                $y=$y + Int(Number($array[5])/2)
                endif
                return 1
                EndFunc
                ; Description: Wait for a specified number of seconds for an image to appear
                ; Syntax: _WaitForImageSearch, _WaitForImagesSearch
                ; Parameter(s):
                ; $waitSecs - seconds to try and find the image
                Func _WaitForImageSearch($findImage,$waitSecs,$resultPosition,ByRef $x, ByRef $y,$tolerance)
                $waitSecs = $waitSecs * 1000
                $startTime=TimerInit()
                While TimerDiff($startTime) < $waitSecs
                sleep(100)
                $result=_ImageSearch($findImage,$resultPosition,$x, $y,$tolerance)
                if $result > 0 Then
                return 1
                EndIf
                WEnd
                return 0
                EndFunc
                ; Description: Wait for a specified number of seconds for any of a set of
                ; images to appear
                ; Syntax: _WaitForImagesSearch
                ; Parameter(s):
                ; $findImage - the ARRAY of images to locate on the desktop
                ; - ARRAY[0] is set to the number of images to loop through
                ; ARRAY[1] is the first image
                ; Return Value(s): On Success - Returns the index of the successful find
                Func _WaitForImagesSearch($findImage,$waitSecs,$resultPosition,ByRef $x, ByRef $y,$tolerance)
                for $i = 1 to $findImage[0]
                sleep(100)
                $result=_ImageSearch($findImage[$i],$resultPosition,$x, $y,$tolerance)
                if $result > 0 Then
                return $i
                EndIf
                Next
                WEnd
                return 0
                EndFunc
                • Arthur OscarA
                  Arthur Oscar @Arthur Oscar
                  • Arthur OscarA
                    ive been working on code...
                    to not remove posts.. im just going to add again... but modified...
                    my case now... error stop shows. but still not working when triggercmd start it. even by a .bat file
                    i have 3 monitors... so i changed $x $y $right $bottom values on ImageSearch.au3 (this part still missing negative position. suposing center monitor is the main one with 0-1920px and 0-1080px
                    well... the problem stills on triggercmd not runing the scripts as a normal person click.
                    cod.au3
                    #include <ImageSearch.au3>
                    $x = FileReadLine("ImageSearch.au3")
                    $y = FileReadLine("ImageSearch.au3")
                    Sleep(500)
                    Run ("E:\Battle.net\Battle.net Launcher.exe")
                    WinActivate("Battle.net")
                    WinActive("Battle.net")
                    ;while(1)
                    Run("ImageSearch.au3")
                    $Search = _ImageSearch("botao.png", 0, $x, $y,0)
                    if $Search = 1 Then
                    startapp()
                    Else
                    EndIf
                    ;WEnd
                    Func startapp()
                    Sleep(200)
                    MouseMove($x,$y+0,0)
                    Sleep(200)
                    MouseClick("primary")
                    endapp()
                    EndFunc
                    Func endapp()
                    Exit
                    EndFunc
                    ImageSearch.au3
                    #include-once
                    ; Language: English
                    ; Parameter(s):
                    EndFunc
                    $x1=-1920
                    $y1=-1080
                    $right=3840
                    $bottom=1080
                    $result = DllCall("ImageSearchDLL.dll","str","ImageSearch","Int",$x1,"Int",$y1,"Int",$right,"Int",$bottom,"str",$findImage)
                    ; Error checking goes here
                    If (IsArray($result) = False) Then Return 0
                    ; If error exit
                    $x=Abs(Number($array[2]))
                    $y=Abs(Number($array[3]))
                    $x=$x + Abs(Number($array[4])/2)
                    $y=$y + Abs(Number($array[5])/2)
                    endif
                    return 1
                    EndFunc
                    ; Parameter(s):
                    sleep(100)
                    if $result > 0 Then
                    return 1
                    EndIf
                    WEnd
                    return 0
                    EndFunc
                    ; images to appear
                    ; Parameter(s):
                    sleep(100)
                    if $result > 0 Then
                    return $i
                    EndIf
                    Next
                    WEnd
                    return 0
                    EndFunc
                    • Arthur OscarA
                      reducing to 1 file...
                      still same problem...
                      #include-once
                      ; Language: English
                      ; Parameter(s):
                      EndFunc
                      $x1=-1920
                      $y1=-1080
                      $right=3840
                      $bottom=1080
                      ; If error exit
                      endif
                      return 1
                      EndFunc
                      ; Parameter(s):
                      sleep(100)
                      if $result > 0 Then
                      return 1
                      EndIf
                      WEnd
                      return 0
                      EndFunc
                      ; images to appear
                      ; Parameter(s):
                      sleep(100)
                      if $result > 0 Then
                      return $i
                      EndIf
                      Next
                      WEnd
                      return 0
                      EndFunc
                      ;#include <ImageSearch.au3>
                      Sleep(20000)
                      ;while(1)
                      ;Run("ImageSearch.au3")
                      $x = 1
                      $y = 1
                      if $Search = 1 Then
                      startapp()
                      Else
                      MsgBox("resultado", $Search, "A Busca pela Imagem esta retornando 0")
                      EndIf
                      ;WEnd
                      Func startapp()
                      Sleep(200)
                      Sleep(200)
                      endapp()
                      EndFunc
                      Func endapp()
                      Exit
                      EndFunc
                        Russ @Arthur Oscar
                        @Arthur-Oscar, I tried for a couple hours and I couldn't make it work.
                        That battle.net app not a normal Windows app, so the normal AutoIt tricks aren't working.
                        • Arthur OscarA
                          Arthur Oscar @Russ
                          @Russ but works when i click manually.. just when triggercmd try it... it doesnt works... maybe some argument not passing maybe? idk like tell to triggercmd to execute script as operator
                          thats battle.net app
                            Russ @Arthur Oscar
                            @Arthur-Oscar, I don’t know why, but I can’t get it to work at all – with or without TRIGGERcmd. If I could make it work without TRIGGERcmd I could try to troubleshoot it with TRIGGERcmd.
                            Arthur OscarA 2 Replies Last reply Reply Quote 0
                            • Arthur OscarA
                              Arthur Oscar @Russ
                              @Russ you can change the PNG file into a piece of your desktop printscreen to try.
                              This way you dont need battle.net app.
                              BTW, i forgot to ask.. you have imagesearchdll.dll file?
                              if you havent, here the link.
                              https://www.autoitscript.com/forum/topic/148005-imagesearch-usage-explanation/
                              its needed to work.. i tried to send to your email, but gmail doesnt allow me to send.
                              b08221f0-a161-4ebb-85b5-e3a7521f647a-image.png like this one of mine desktop
                              • Arthur OscarA
                                Arthur Oscar @Russ
                                @Russ wich system triggercmd is runing? 32 or 64bit? i noticed if i compile script to 32bits script never works... maybe this influence? if trigger is runing as 32bits... idk
                                • Arthur OscarA Arthur Oscar referenced this topic on
                                  Russ @Arthur Oscar
                                  @Arthur-Oscar, the TRIGGERcmd agent is 64bit.
                                  Also yes, I have imagesearchdll.dll in the same folder with the cod.au3 script and the compiled cod.exe.
                                  I have seen it detect and move to the Play button, but it usually doesn't, and when it did move to the Play button it didn't click it.
                                  Battle.net made it very difficult to automatically start a game.
                                  • Arthur OscarA
                                    Arthur Oscar @Russ
                                    @Russ sometimes you have to put a wait after movemouse... it click and move at same time
                                    • Arthur OscarA
                                      Arthur Oscar @Russ
                                      @Russ as i told before, executing the script by myself, it works fine, but when i order to trigger result scan is 0.
                                        Russ @Arthur Oscar
                                        @Arthur-Oscar, I understand, but I can't make it work with or without TRIGGERcmd. I've tried everything. It won't click Play.
                                        • Arthur OscarA
                                          Arthur Oscar @Russ
                                          @Russ i noticed when i tell to triggercmd to execute cod.bat file... it doesnt blink at the screen, it executes on background or something?
                                            Russ @Arthur Oscar
                                            @Arthur-Oscar, you should add a line to your cod.bat that shows something on the screen or writes something to a log like this, so you know it's running.
                                            echo it ran >> c:\scripts\cod.log
                                            Also, make sure Ground = foreground.
