    Question
    14 Posts 2 Posters 3.2k Views 1 Watching
    • S Offline
      Smart Communities
      I got you a couple of screenshots. Hope this helps.
      Agent running
      Default task still on pc
      pc name
      Triggercmd account
      • S Offline
        Smart Communities @Russ
        • S Offline
          @Russ any idea where I’m messing up?
            Russ @Smart Communities
            @Smart-Communities, I don't think you're doing anything wrong, but I don't know yet what went wrong.
            Can you try two things?
            1. Rename the background command and see if it shows up.
            If it doesn't, try:
            1. Uninstall and reinstall the background agent and see if it shows up.
            • S Offline
              @Russ neither of those worked but here's what did.
              I ran "update agent" which stated Background service must be reinstalled once update is complete. Upon reinstalling background service after the update I was able to see the background command.
              My triggercmdagentsetup is on a thumbdrive. Is that bound to a specific version of triggercmd?
                @Smart-Communities, that's correct. It doesn't download the latest version when you run the pre-downloaded agent installer on your thumb drive, it will install that specific version when you run it.
                So I'm guessing either the uninstall / re-install fixed it, or maybe there was a bug in the version you had on your thumb drive.
                Anyway I'm glad it's working now. Sorry for the trouble.
                • S Offline
                  @Russ downloaded newest and same issue. To be clear, the background agent is automatically installed when TriggerCMD is installed. That correct?
                    @Smart-Communities, no that is not correct.
                    You install the background service by right-clicking the TRIGGERcmd tray icon and clicking Background Service - Install Background Service.
                    • S Offline
                      @Russ Apologies Russ. Not sure why I thought that. Maybe because it was a default command when installing. Anyway sorry to waste your time.
                        No problem at all @Smart-Communities. I'm glad you asked.
