    Question
    14 Posts 2 Posters 3.3k Views 1 Watching
    • S Offline
      Smart Communities @Russ
      @Russ yes Triggercmd PID 1440 is running with Startup set to automatic.
      My trigger list only shows notepad and calculator.
      This has always been the case for me but I thought it was because I was using Windows AME. This is on a standard win 11 install.
        Russ @Smart Communities
        @Smart-Communities, can you send a screenshot of the Windows service like this?
        I'll test on my Windows 11 box tomorrow.
        I just tried running this d:\tools\logger.bat script in the background agent and it worked, but this is a Windows 10 machine.
        The d:\tools\logger.bat script just has this line in it:
        echo from background >> c:\background_log.txt
        I see this in my c:\background_log.txt file:
        from background
        EDIT:
        I installed the background agent on my Windows 11 box, and created my logger command as a background command. The trigger showed up in my account. I tried running it and it worked for me. I got an entry in my log when it ran.
        So I'm not sure what's going wrong on your Windows 11 machine. You could try removing and re-installing your background agent.
        • S Offline
          Smart Communities
          I got you a couple of screenshots. Hope this helps.
          Agent running
          Default task still on pc
          pc name
          Triggercmd account
          • S Offline
            • S Offline
              @Russ any idea where I’m messing up?
                @Smart-Communities, I don't think you're doing anything wrong, but I don't know yet what went wrong.
                Can you try two things?
                1. Rename the background command and see if it shows up.
                If it doesn't, try:
                1. Uninstall and reinstall the background agent and see if it shows up.
                • S Offline
                  @Russ neither of those worked but here's what did.
                  I ran "update agent" which stated Background service must be reinstalled once update is complete. Upon reinstalling background service after the update I was able to see the background command.
                  My triggercmdagentsetup is on a thumbdrive. Is that bound to a specific version of triggercmd?
                    @Smart-Communities, that's correct. It doesn't download the latest version when you run the pre-downloaded agent installer on your thumb drive, it will install that specific version when you run it.
                    So I'm guessing either the uninstall / re-install fixed it, or maybe there was a bug in the version you had on your thumb drive.
                    Anyway I'm glad it's working now. Sorry for the trouble.
                    • S Offline
                      @Russ downloaded newest and same issue. To be clear, the background agent is automatically installed when TriggerCMD is installed. That correct?
                        @Smart-Communities, no that is not correct.
                        You install the background service by right-clicking the TRIGGERcmd tray icon and clicking Background Service - Install Background Service.
                        • S Offline
                          @Russ Apologies Russ. Not sure why I thought that. Maybe because it was a default command when installing. Anyway sorry to waste your time.
                            No problem at all @Smart-Communities. I'm glad you asked.
