Raspberry Pi setup
@avs2020, it looks like you figured it out because I see commands associated with your raspberrypi computer now. Please confirm.
It looks like offCommand is never called using this PI/Debian distribution, do you have an update? Did you forget to include this functionality for Linux, it works fine on Windows.
@George-Hatzisymeon, sorry I never responded to this. I just noticed it because someone upvoted it.
I just verified that the offCommand commands.json value is supported in the current version of the Raspberry Pi agent. If you were using that version and it didn't work, then maybe you were missing this part:
"allowParams":"true"Here's an example entry I just tested. It turns my led strip off if the parameter was off, and if the parameter was on, it turns the strip on and makes the leds green.
{ "trigger":"Green", "command":"\/root\/killrun.sh leds.py green", "offCommand": "\/root\/killrun.sh leds.py off", "ground":"background", "voice":"green", "allowParams":"true" }, -
R Russ referenced this topic on
T tuicemen moved this topic from Instructions on
T tuicemen pinned this topic on
D Dean McNaughton referenced this topic on
What I did wrong? It appears:
E: Unable to locate package https://agents.triggercmd.com
E: Couldn't find any packageb by glob 'https://agents.triggercmd.com'
E: Couldn't find any packageb by regex 'https://agents.triggercmd.com'I'm a noob, and sorry for my english.
@Ar7hur, the URL to download the Raspberry Pi installer is this:
https://agents.triggercmd.com/triggercmdagent_1.0.1_all.deb
Does that answer your question?
@Russ I wrote this, but appears what I mentioned
@Ar7hur, how do you get those errors? Can you please give me the command you typed, or paste a screenshot?
@Russ It was my mistake. I discovered where was wrong
Sorry
How to create a trigger to turn off? and is there how to turn on the pi by voice command? -
@Ar7hur, no problem. I'm glad you got it working.
You could create a trigger that runs shutdown --poweroff but it won't actually power the Raspberry Pi off. Raspberry Pi's also do not support wake-on-lan, so you couldn't power it on from another computer on your network like you could with a PC.
The only thing I can think of is you could power the Pi on/off with a relay by connecting/disconnecting the vbus on the 5volt power input with an adapter you could build with something like this, or you could use a smart plug to power it off/on. You could run a command that runs an Alexa routine that powers the smart plug on or off.
Hello, first of all thanks for this amazing integration/work.
I've a question:
Do you know if there's a way to add a parameter over the "commands.json" file in order to make Alexa speak when you execute the trigger? So she'll reply when you do a query. Would be great so it could be integrated with some bash scripts/ansible playbooks.
Thank you,
Kind regards. -
@Jorge-Fuentes, yes, there is a way.
You can use the Voice Reply field to do that.
This article explains how.
Basically, put "{{result}}" in your voicereply field and run the sendresult script that the TRIGGERcmd agent installs here:
Windows:
%USERPROFILE%\.TRIGGERcmdData\sendresult.batLinux / Mac:
~/.TRIGGERcmdData/sendresult.shI know you're on a Raspberry Pi, but I'm pasting the Windows GUI editor screenshot just to make sure the concept is clear.
In the runs list you can see what the "sendresult" script is sending back to the server as the "result" of the command you ran. If you include {{result]] in the Voice Reply field, The TC, TRIGGERcmd, or Trigger Command Alexa skills will say that text when you use one of those skills to trigger the command.
Instead of making the command in the commands.json file directly run the sendresult script, normally the commands.json would reference a script that would run the sendresult script last, and send back the value of an environment variable like this:
~/.TRIGGERcmdData/sendresult.sh ${RESULT}The one problem with the above method is it uses one of the non-smart home TRIGGERcmd Alexa skills. Those skills are not as reliable at matching the words in the sentence pattern it uses to run the command. The TRIGGERcmd Smart Home Alexa skill does a much better job.
TC / TRIGGERcmd / Trigger Command Alexa skill pattern:
- Alexa, ask TRIGGERcmd to run Calculator
TRIGGERcmd Smart Home Alexa skill pattern:
- Alexa, turn on Calculator
If you want to use the TRIGGERcmd Smart Home skill to run your command, you use this method.
That's brilliant, thank you for the information.
With your input, this post could be even better š
