    Command format on Raspi
    32 Posts 3 Posters 15.6k Views
    • Steve PorterS Offline
      Steve Porter @Russ
      @russ steve-porter Am I completely off track on getting X10 working with TriggerCMD on RasberryPI?
        Russ @Steve Porter
        @steve-porter, I think you're close. I assume this command already works if you run it manually?
        echo "pl i6 on" | nc localhost 1099
        I recommend you install the triggercmd agent on the Pi the normal way - using this script:
        It will run as root in background mode and startup on boot.
        There is no GUI editor or icon for the Raspberry Pi version of the agent. You'll need to edit the /root/.TRIGGERcmdData/commands.json file manually.
        If you want, you could create the command on your Windows box, then copy/paste the resulting json from your commands.json on your Windows box to the Pi.
        I think this should work though:
        {"trigger":"Six","command":"echo \"pl i6 on\" | nc localhost 1099","ground":"background","voice":"six","allowParams": "false"},
        Notice I "escaped" the quotes around the pl i6 on part so it didn't break the json formatting.
        Please test that. If it works, I can give you a script to run instead that will take an on or off parameter so you can use one command with allowParams = true. That way you can say, "Alexa, turn on 6" or "Alexa, turn off 6".
        Steve PorterS 1 Reply Last reply Reply Quote 0
          Steve Porter @Russ
          @russ That works, I see the trigger run. I still need to figure out what's going on inside mocad. The Tx function runs, but isn't sending the x10 signal.
          How would it look using parameters? (Obviously parameters true)
            Russ @Steve Porter
            @steve-porter, if you run this command manually does it work?
            You could put that in an i6.sh script that accepts an on or off parameter like this:
            echo "pl i6 $1" | nc localhost 1099
            Make sure you make your script executable with a command like this:
            chmod +x /usr/local/bin/i6.sh
              Steve Porter @Russ
              @russ Hi Russ, just spent a week debugging mochad on Linux/Raspi. It now works sending to X10 perfectly, using the above command line example:
              "echo "pl i6 on" | nc -w 1 localhost 1099
              I've never worked with scripts in linux, but I have edited the commands.json file and have a couple of commands working and showing up in the web interface, and they work.
              Right now one to turn on a fan, a separate one to turn that fan off. So I added a new one, changing "allowParams": "false" to "true". So now the Parameters button is there. How do I format the command in commands.json to pass the "on"/"off" param to this:
              {"trigger":"Living Room Fan On","command":"echo "pl i6 on" | nc -w 1 localhost 1099","ground":"background","voice":"Living Room Fan On","allowParams": "true"} ?
              I tried putting [param] in a few ways but haven't found the correct format.
              Steve
              tuicemenT 3 Replies Last reply Reply Quote 0
              • tuicemenT Offline
                tuicemen @Steve Porter
                @steve-porter , I'm new to TRIGGERcmd but not X10 or scripts
                I played with mochad on a Raspberry pi a bit but it never seemed stable for me.
                I use HomeGenie (HG) now with X10 but I believe you could do something similar to what I did with x10 and HG with a mochad script.
                You could create 1 script that would handle all your X10 devices On & Off I can't remember if mochad did diming but if so the script could allow that as well.
                1 Reply Last reply Reply Quote -1
                • tuicemenT Offline
                  @steve-porter just quickly put together a multi use script for mochad called X10.sh
                  #!bin/bash
                  echo "pl $1 $2" | nc localhost 1099
                  echo "sent powerline command $1 $2 to Mochad"
                  If your stumped on how to create this I can upload the file.
                  your line in the commands.json file would look like this for house code i unit code 6:
                  {"trigger":"i6","command":"/home/pi/scripts/X10.sh i6","ground":"background","voice":"six","allowParams":"true"},
                  Note: this would require your X10.sh script to be in the home/pi/scripts folder to turn on or off a different module you simply add another line to the commands.json file changing the i6 to the address you wished and the voice to something else.
                  • tuicemenT Offline
                    @steve-porter said in Command format on Raspi:
                    I've never worked with scripts in linux, but I have edited the commands.json file.......
                    Creating a script is very easy I'll walk you through this simple one.
                    open the text editor nano at the prompt type
                    • sudo nano X10.sh
                    • in the window that opens paste the script contents from my previous post or type in the lines.
                    • hit the ctrl x keys to exit
                    • you'll get a prompt to save press y for yes
                    • next you'll get the confirmation of the file name press enter if it is OK
                    • now you need to make the file executable type chmod +x X10.sh
                    • to test type sh X10.sh i6 on
                    • sh X10.sh i6 off should turn off the module
                      Steve Porter @tuicemen
                      @tuicemen Thank you for your replies, I appreciated it very much. Creating the shell script would shorten the amount of text in the commands.json triggers. It apprears that I would still need a trigger for each x10 unit on, x10 unit off.
                      I would really like to be able to send the variables [i6 on], or [i6 off] to the same trigger. In the TriggerCMD web interface you can trigger with parameters, but I just don't see how to get those parameters into the trigger command string.
                      Something like this:
                      {"trigger":"Living Room Fan On","command":"echo "pl $1 $2" | nc -w 1 localhost 1099","ground":"background","voice":"Living Room Fan Off","allowParams": "true"}
                      and be able to pass the i6, on. (just my attempt at a guess, this doesn't work)
                      RussR tuicemenT 4 Replies Last reply Reply Quote 0
                        Russ @Steve Porter
                          @steve-porter, that should work fine.
                          All parameters get appended to the end of the command you put in the command field.
                          If you need to embedded parameters in the middle of your command, you'll need to use a script, and refer to the positional parameters as $1 and $2 inside the script.
                          Also if you need to put quotes in your command (in commands.json), you'll need to escape them with a backslash like this:
                          That way the json parser won't think the quotes are part of the json field start/end. The GUI editor handles that for you, so if you're building a command for a Raspberry Pi you could copy paste the json from a Windows computer.
                          • tuicemenT Offline
                            you would only need one line in your commands.json file per X10 address
                            your line would be this
                            {"trigger":"Living Room Fan","command":"/home/pi/scripts/X10.sh i6","ground":"background","voice":"Living Room Fan","allowParams": "true"
                            To turn the living room fan on you'd say "Alexa turn On Living Room Fan" or "Alexa Living Room Fan On"
                            To turn the living room fan off you'd say "Alexa turn Off Living Room Fan" or "Alexa Living Room Fan Off"
                            Alexa adds the condition on or off to the end of your request thats why a script is needed in your case so that the on/off condition gets place in the correct location.
                              Russ @tuicemen
                              • tuicemenT Offline
                                tuicemen @Russ
                                @russ Ya seen that And fixed it
                                • tuicemenT Offline
                                  @steve-porter here is the script : X10.sh
                                  you can test in in the command line by typing sh X10.sh i6 on
                                  to turn your fan off simply change the on to off
                                  • tuicemenT Offline
                                    @steve-porter, I brushed up on Mochad, reading from early posts made by the original developer here https://forums.x10.com/index.php?topic=22045.0
                                    It seems it is possible to send RF as well as PLC and even dim.
                                    though it seems the dimming function was a bit clunky and depended on the age of the Lamp modules.
                                    The current script (I provided) will do on/off for all 256 X10 addresses for PLC only if you wish RF, the script could be modified to handle it easy enough. Your commands.json lines would needed to be edited with an additional parameter.
                                    Dimming functions (not currently available with TRIGGER) would be a little more complicated and depending on how Alexa sends the dim may need some conversion.
                                      Steve Porter
                                      You guys ROCK! Thanks for your guidance for an old 80's c programmer (I'm 63 and still learning *-).....)
                                      K, so I got all my desktop commands into the Raspi .json file. Had to delete my desktop and Raspi from Trig website, then reinstall the Raspi. K, so now commands half way work. Funny thing, Alexa can turn things on , but not off. Hmmmm.....Really just for the paper trail.....just was wondering why, Hmmmmm?
                                      K, so I'll work on the script route, sounds like the best way to go....
                                        Steve Porter @Steve Porter
                                        @steve-porter Just realized that "Alexa, Turn off living Room Fan" also turns the fan ON......another Hmmmmmm.....
                                        • tuicemenT Offline
                                          @steve-porter you only have a year on me I'm still learning too.
                                          I find I have to go through my TRIGGER calls and scripts a couple of times to catch my typos. I seem to have more of them lately 😞
                                          The Script route really is the best route.
                                          I've read several posts on other Home Automation sites complaining about mochad not working correctly for them. It was one reason I chose not to use that Home Automation software.
                                          Mochad was originally created for the North American market and it seems like that maybe why some users have problems though I think it is mainly the RF side of it.
                                          Are you using mochad as a addon for another Home Automation software?
                                          What X10 hardware are you interfaceing with?
                                            @tuicemen I'm mostly now using smart plugs and light bulbs via WiFi but still have a bunch of X10 stuff. My pool light and waterfall both have 220v X10 modules, and the smart plugs won't work with fan motors. And for my house ceiling fans I installed X10 "relay" switches cause they're way cheaper than the smart switches that would work.
                                            I moved all the X10 stuff from my Windows Desktop to the Raspi. Mochad wouldn't compile without a bunch of errors, which is why I modified it. The version I started with was mochad-0.1.17. I've heard rumblings of a mochad-0.1.19 version floating around somewhere, so I'm bumping this one to mochad-0.1.21 just to be sure. Mochad recognized my X10 CM15a with no problem. That's the same hardware I was using with my Windows installation for years.
                                            I'm going to be setting up the script stuff you and Russ pointed my towards today.
                                            Cheers
                                            (P.S: I'm in California, what region are you?)
