    No-GUI TRIGGERcmd agent that works on 32bit Windows
    25 Posts 5 Posters 16.8k Views 1 Watching
      @gcabot, sorry I didn't see this until now, but good job getting it to work. The double backslashes are necessary to "escape" a backslash to be compatible with .json. That's one reason I built the GUI editor - the text file and those backslashes are a pain to deal with.
        Hi Russ, does this 32-bit support parameter as in the GUI 64-bit?
          @tim-tran, yes. It has the same functionality. Just add "allowParams": "true" to commands.json entry.
            "trigger": "Logger",
            "command": "d:\\tools\\logger.bat",
            "ground": "foreground",
            "voice": "",
          • XanderX Offline
            Xander
            I was banging my head on my desk trying to install TriggerCMD on my compute-stick until I found this. It's tiny but hosts my remote support software but it is x86 so....
            Couple of hiccoughs:
            1. How do I register this computer under my account? Half the reason I want to install it on this computer is to try to get WOL working on my main PC.
            2. Once I've run the batch file, I don't have a .TRIGGERcmdData folder under %userprofile%. The closest I've got is a wincommands.json file in the folder where the batch itself is (under Program Files for reasons).
              Russ @Xander
              @xander, the first time you run the batch file it should prompt you for your token from the Instructions page like this:
              C:\triggercmdagent>node C:\triggercmdagent\agent --console
              Daemon install: false
              prompt: token:
              It should also create a C:\Users\(yourUser)\.TRIGGERcmdData folder, and copy the wincommands.json file to C:\Users\(yourUser)\.TRIGGERcmdData\commands.json which is the file you should edit to add commands.
              • XanderX Offline
                Xander @Russ
                @russ -- Just re-ran it and the cmd window closes itself a few seconds, even tried it as Admin. The stick-pc is running Win10 Home, if that helps and the Node.js version is the Win7x32 one.
                  Russ @Xander
                  @xander, I don't have much info yet, but if you open a cmd window and run the batch file from there, it might give us some useful output.
                  Line this:
                  • Press Windows key and R
                  • Type cmd, and press enter.
                  • Type cd \triggercmdagent <- (or whatever folder you unzipped it to) and press enter
                  • Type triggercmdagent and press enter.
                  • Copy/paste the output into this forum thread.
                  • XanderX Offline
                    Xander
                    C:\Program Files\TriggerCMD>node C:\Program Files\TriggerCMD\agent --console
                    module.js:538
                    throw err;
                    Error: Cannot find module 'C:\Program'
                    at Function.Module._resolveFilename (module.js:536:15)
                    at Function.Module._load (module.js:466:25)
                    at bootstrap_node.js:608:3
                      Russ @Xander
                      @xander, awesome!!
                      I see the problem. This command is failing because there's a space between Program and Files.
                      Please change the command in triggercmdagent.bat to this:
                      node "%~dp0agent" --console
                      Or just re-download the zip file. I updated it to add those quotes.
                      The quotes should allow you to put this in a folder that has spaces in the name.
                      Thanks for discovering this, and for your patience.
                      • XanderX Offline
                        Xander
                        Workin' ... almost.
                        Token entered, it now shows up on my list here on your site. Entered a new command in the commands.json but, even after allowing some time for that list to sync up, it's not showing. FWIW, the default list had three commands built into it (reboot, calc, notepad) and only two show up server-side (calc, notepad).
                        https://i.gyazo.com/0a9e27487781c04fe5ab2d2949f4f164.png
                        Even with that, Alexa "can't find trigger command Notepad on the stick" She said she was triggering Calculator...but it never opened (and shows "0 runs" on the server). Update: eventually got Alexa to say she was running it but, like Calc, nothing did.
                          Russ @Xander
                          @xander, good progress.
                          The reason only Calculator and Notepad show up is you're only running a foreground agent. The background agent won't work in your case because you're using the basic 32bit Windows agent. The foreground agent reads foreground commands from commands.json, and the background agent reads the background commands.
                          Are you able to run the commands from the green Trigger buttons on the website?
                          Do you get any output in your cmd window when you trigger a command from the website?
                          prik mP 1 Reply Last reply Reply Quote 0
                          • prik mP Offline
                            prik m @Russ
                            I'm posting here because I followed the previos posts instruction to installa the agent on a Win 7 32bit PC.
                            Yesterday I did the same on my PC (Win 7 64) to test the remote controls through Alexa on my phone (waiting for the delivery of an Echo 4 ge speaker) and everything works.
                            Now I'm setting up an agent on my wife's music PC so she can control Foobar remotely with Google assistant.
                            On the site I can see the computer and the triggers (Calc and notepad) but clicking on the green button I can only see the site going into another page for a second and then coming back to the list, but on the PC and in in a vmd window nothing happens.
                            What should I check?
                            Thank you.
                              Russ @prik m
                              @prik-m,
                              Please confirm your wife's computer is 32bit so you're running the agent in a cmd window? Will you please send me a screenshot?
                              If you see the computer in your wife's TRIGGERcmd account, then it must have talked to TRIGGERcmd at some point and logged in with her token.
                              The screenshot might show me whether it's connected to the server.
                              Also, please show me the version of node js you're using by typing this command:
                              node --version
                              • prik mP Offline
                                prik m @Russ
                                Hi Russ,
                                thank you for the propmp reply.
                                The js version is v8.9.1
                                I re-ran the .bat and it asked for the token again.
                                Now the site sees my triggers and updates them straight away.
                                After a few minutes, the Google Home app is not getting the updates anymore : any hint?
                                Thanks.
                                • prik mP Offline
                                  prik m @prik m
                                  @prik-m
                                  I tried log out of the site to login with a diffrent google user but it automatically login with the previous one without giving me the possibility to change: can I do something about it?
                                  Thx.
                                  prik mP RussR 2 Replies Last reply Reply Quote 0
                                  • prik mP Offline
                                    prik m @prik m
                                    @prik-m
                                    I can't make this trigger to work on the Win 32 pc. I copied the config lines from the commands.json file I created with the GUI on a win 64 pc:
                                      "trigger": "FB desk stop",
                                      "command": "C:\\Users\\fabio\\Desktop\\foobar162\\foobar2000.exe /stop",
                                      "offCommand": "",
                                      "voice": "music desk stop",
                                      "voiceReply": "got it",
                                      "allowParams": "false"
                                    Even if I trigger it with the online green button it does nothing and I can't see anything happening in an open cmd window: any clue? Or at least how can I troubleshoot this problem?
                                    Thanks.
                                      Russ @prik m
                                      @prik-m said in No-GUI TRIGGERcmd agent that works on 32bit Windows:
                                      C:\Users\fabio\Desktop\foobar162\foobar2000.exe /stop
                                      On the Win 32 pc, does this command work?
                                      Also, you mentioned "an open cmd window." Is that the cmd window where you're running the node agent.js --console command?
                                      Or are you expecting TRIGGERcmd to type a command in a cmd window you opened? I doesn't do that.
                                      Can you send me a screenshot?
                                        Russ @prik m
                                        @prik-m
                                        Thx.
                                        If you use Chrome, you could use a different profile logged in as the other user.
                                        https://support.google.com/chrome/answer/2364824?hl=en&co=GENIE.Platform%3DDesktop
