    change audio output device
    2.6k
    • Emanuel silva gomesE
      Emanuel silva gomes
      wanted to exchange the audio output of the computer between realtek and hdmi
        Russ @Emanuel silva gomes
        @Emanuel-silva-gomes, for that I recommend using nircmd.exe
        You can run this to list your sound devices:
        nircmd showsounddevices
        Then run commands like these via TRIGGERcmd to change output devices:
        nircmd setdefaultsounddevice 27MP65
        nircmd setdefaultsounddevice Speakers
        https://nircmd.nirsoft.net/setdefaultsounddevice.html
          Emanuel silva gomes
          thank you very much, it worked
          • Gaston MardonesG
            Gaston Mardones
            Is it possible to run two lines of nircmd in a single triggercmd command?
            If I want, for example, to change the sound device to 27MP65 and then to Speakers in a single command.
            Thanks!
            Trigger: Change Output Device
            Command:
            nircmd setdefaultsounddevice 27mp65
            nircmd setfetaultsounddefice Speakers
            Ground : foreground
            Voice: cambiar dispositivo de audio
            • XanderX
              Xander
              Try putting an & between them. e.g. cls & dir
              1 Reply Last reply Reply Quote -1
