    2. Gaston Mardones
    Gaston MardonesG Offline
    Gaston Mardones
    @Gaston Mardones
    Gaston Mardones Unfollow Follow
    • RE: How can I change spotify device?
      Thanks for the answer, but that is precisely my problem, that in my spotify application in windows 10 the shortcut ctrl + D does not work. So I wanted to know if there was any other solution.
      For now I made a Python script that opens spotify in the web browser and hit TAB 24 times and ENTER until it opens which should do ctrl + D. But as you can imagine, it depends on the page loading fast, and more variables.
      Just in case, sorry for my English, I'm from Argentina and I do what I can haha
      Thanks again
      Gaston MardonesG
      Gaston Mardones
    • How can I change spotify device?
      When you tell google home: play spotify, it plays it on the speaker of the same google home. I would like to know if there is any way to change the playback device through some script or something.
      I saw this post: https://www.triggercmd.com/forum/topic/134/switch-spotify-devices-with-alexa-and-smartthings
      In which, through a VBS script, he managed to change them, but in the script he used
      WshShell.SendKeys '^ {d}'
      That line means ctrl + c, which was a shortcut for the switch device button.
      But unfortunately that shortcut no longer exists, at least in my version of Spotify on Windows 10.
      If anyone knows any solution, I wait for it, thanks.
      posted in General Discussion spotify
      Gaston MardonesG
      Gaston Mardones
    • RE: change audio output device
      Is it possible to run two lines of nircmd in a single triggercmd command?
      If I want, for example, to change the sound device to 27MP65 and then to Speakers in a single command.
      Thanks!
      Trigger: Change Output Device
      Command:
      nircmd setdefaultsounddevice 27mp65
      nircmd setfetaultsounddefice Speakers
      Ground : foreground
      Voice: cambiar dispositivo de audio
      Gaston MardonesG
      Gaston Mardones
