    Turn monitors on and off
    17 Posts 8 Posters 16.3k Views 2 Watching
      Russ @Trenton Lawson
      @Trenton-Lawson unfortunately I think the problem is specific to your hardware.
      Trenton LawsonT 1 Reply Last reply Reply Quote 0
        I get an error when running the monitor off command:
        PS C:\Windows\System32\WindowsPowerShell\v1.0> powershell (Add-Type '[DllImport(\"user32.dll\")]^public static extern int SendMessage(int hWnd, int hMsg, int wParam, int lParam);' -Name a -Pas)::SendMessage(-1,0x0112,0xF170,2)
        Add-Type : c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : Unexpected character '\'
        c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(7) :     {
        c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : >>>     [DllImport(\"user32.dll\")]^public static extern int
        c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(9) :
        At line:1 char:13
        + powershell (Add-Type '[DllImport(\"user32.dll\")]^public static exter ...
            + CategoryInfo          : InvalidData: (Microsoft.Power...peCompilerError:AddTypeCompilerError) [Add-Type], Except
           ion
            + FullyQualifiedErrorId : SOURCE_CODE_ERROR,Microsoft.PowerShell.Commands.AddTypeCommand
        Add-Type : c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : Newline in constant
        At line:1 char:13
           ion
        Add-Type : c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : Invalid expression term ''
        At line:1 char:13
           ion
        Add-Type : c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : ) expected
        At line:1 char:13
           ion
        Add-Type : c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : Invalid token '"user32.dll")]^public stati...' in
        class, struct, or interface member declaration
        At line:1 char:13
           ion
        Add-Type : Cannot add type. Compilation errors occurred.
        At line:1 char:13
            + CategoryInfo          : InvalidData: (:) [Add-Type], InvalidOperationException
            + FullyQualifiedErrorId : COMPILER_ERRORS,Microsoft.PowerShell.Commands.AddTypeCommand
        (Just a note: I've been using Nircmd to do this, it does the same)
        • Trenton LawsonT Offline
          Trenton Lawson @Russ
          @Russ Is it possible one of my apps could be preventing it? Such as Wallpaper Engine which creates live wallpapers.
            @Trenton-Lawson, it's possible because I don't know specifically why it's doing that, but I doubt that's it. It seems more like a hardware problem.
              @Russ Any idea on what piece of hardware might be causing the issue? If not no worries
                @Trenton-Lawson, maybe the video card or monitor, but it might even be the motherboard because of what you told me about the keyboard and mouse flashing.
                • XanderX Offline
                  Xander
                  NirCMD (https://www.nirsoft.net/utils/nircmd.html) can do this with a single command: nircmd.exe monitor off
                  • R Offline
                    raeyatd
                    someone help me!!! when I use the command 'wscript d: \ scripts \ key.vbs PRTSC' it says that the script file 'd: \ scripts \ key.vbs' could not be found.
                    • R Offline
                      raeyatd @raeyatd
                      @raeyatd said in Turn monitors on and off:
                      @Russ please
                        Russ @raeyatd
                        @raeyatd, for that to work, you'd need to have a 😧 drive with a scripts folder in the root of it, and you'd need to create the key.vbs file. If you don't have a 😧 drive, you could use your 😄 drive.
                        These are the contents of that key.vbs for quick reference:
                        Dim Wsh
                        Wsh.SendKeys "{" + WScript.Arguments.Item(0) +"}"
                        • Rhadson MatiasR Offline
                          Rhadson Matias @Russ
                          I have more than one monitor, can you choose which one to turn off?
                            Russ @Rhadson Matias
                            @Rhadson-Matias, I don't know of any tools that can turn specific monitors off. I'll have to do some research.
                            At first I thought you were asking if you can shutdown a second computer. For that you could say something like this:
                            Alexa, turn off power on laptop.
                            Power is the voice word for the command on the computer with laptop as its voice word.
                            • S Offline
                              SniperVB @Russ
                              @Russ Hii, did you find a way to turn a specific monitor off? Or at least just a second screen?
                              • XanderX Offline
                                Xander
                                "Enable/disable/configure multiple monitors on Windows"
                                https://www.nirsoft.net/utils/multi_monitor_tool.html
                                MultiMonitorTool.exe /disable \.\DISPLAY3
                                And, for single monitors, my comment from a year ago still works.
                                1 Reply Last reply Reply Quote 2
                                • Fernando Montes VázquezF Offline
