    Turn monitors on and off
    17 Posts 8 Posters 16.3k Views 2 Watching
      Turn monitors off:
      powershell (Add-Type '[DllImport(\"user32.dll\")]^public static extern int SendMessage(int hWnd, int hMsg, int wParam, int lParam);' -Name a -Pas)::SendMessage(-1,0x0112,0xF170,2)
      Turn monitors on (didn't work for me - see below):
      powershell (Add-Type '[DllImport(\"user32.dll\")]^public static extern int SendMessage(int hWnd, int hMsg, int wParam, int lParam);' -Name a -Pas)::SendMessage(-1,0x0112,0xF170,-1)
      In my case, the Turn monitors on powershell command didn't work for me. My monitors turned on but then turned right back off for some reason. So instead, I used this script and made this my command line so it effectively presses the Print Scrn button to turn my monitors back on:
      wscript d:\scripts\key.vbs PRTSC
      Rhadson MatiasR 1 Reply Last reply Reply Quote 0
      • Trenton LawsonT Offline
        Trenton Lawson
        @Russ said in Turn monitors on and off:
        powershell (Add-Type '[DllImport("user32.dll")]^public static extern int SendMessage(int hWnd, int hMsg, int wParam, int lParam);' -Name a -Pas)::SendMessage(-1,0x0112,0xF170,2)
        When I try and run the turn monitors off command, it works briefly, but my screen wakes up after maybe three seconds. While my monitors are off my keyboard and mouse flash rapidly at me. Any idea on how to fix this?
          Russ @Trenton Lawson
          @Trenton-Lawson unfortunately I think the problem is specific to your hardware.
          Trenton LawsonT 1 Reply Last reply Reply Quote 0
            I get an error when running the monitor off command:
            PS C:\Windows\System32\WindowsPowerShell\v1.0> powershell (Add-Type '[DllImport(\"user32.dll\")]^public static extern int SendMessage(int hWnd, int hMsg, int wParam, int lParam);' -Name a -Pas)::SendMessage(-1,0x0112,0xF170,2)
            Add-Type : c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : Unexpected character '\'
            c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(7) :     {
            c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : >>>     [DllImport(\"user32.dll\")]^public static extern int
            c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(9) :
            At line:1 char:13
            + powershell (Add-Type '[DllImport(\"user32.dll\")]^public static exter ...
                + CategoryInfo          : InvalidData: (Microsoft.Power...peCompilerError:AddTypeCompilerError) [Add-Type], Except
               ion
                + FullyQualifiedErrorId : SOURCE_CODE_ERROR,Microsoft.PowerShell.Commands.AddTypeCommand
            Add-Type : c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : Newline in constant
            At line:1 char:13
               ion
            Add-Type : c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : Invalid expression term ''
            At line:1 char:13
               ion
            Add-Type : c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : ) expected
            At line:1 char:13
               ion
            Add-Type : c:\Users\xxx\AppData\Local\Temp\xzybaz5r.0.cs(8) : Invalid token '"user32.dll")]^public stati...' in
            class, struct, or interface member declaration
            At line:1 char:13
               ion
            Add-Type : Cannot add type. Compilation errors occurred.
            At line:1 char:13
                + CategoryInfo          : InvalidData: (:) [Add-Type], InvalidOperationException
                + FullyQualifiedErrorId : COMPILER_ERRORS,Microsoft.PowerShell.Commands.AddTypeCommand
            (Just a note: I've been using Nircmd to do this, it does the same)
              Trenton Lawson @Russ
              @Russ Is it possible one of my apps could be preventing it? Such as Wallpaper Engine which creates live wallpapers.
                @Trenton-Lawson, it's possible because I don't know specifically why it's doing that, but I doubt that's it. It seems more like a hardware problem.
                  @Russ Any idea on what piece of hardware might be causing the issue? If not no worries
                    @Trenton-Lawson, maybe the video card or monitor, but it might even be the motherboard because of what you told me about the keyboard and mouse flashing.
                    • XanderX Offline
                      Xander
                      NirCMD (https://www.nirsoft.net/utils/nircmd.html) can do this with a single command: nircmd.exe monitor off
                      • R Offline
                        raeyatd
                        someone help me!!! when I use the command 'wscript d: \ scripts \ key.vbs PRTSC' it says that the script file 'd: \ scripts \ key.vbs' could not be found.
                        • R Offline
                          raeyatd @raeyatd
                          @raeyatd said in Turn monitors on and off:
                          @Russ please
                            Russ @raeyatd
                            @raeyatd, for that to work, you'd need to have a 😧 drive with a scripts folder in the root of it, and you'd need to create the key.vbs file. If you don't have a 😧 drive, you could use your 😄 drive.
                            These are the contents of that key.vbs for quick reference:
                            Dim Wsh
                            Wsh.SendKeys "{" + WScript.Arguments.Item(0) +"}"
                            • Rhadson MatiasR Offline
                              Rhadson Matias @Russ
                              I have more than one monitor, can you choose which one to turn off?
                                Russ @Rhadson Matias
                                @Rhadson-Matias, I don't know of any tools that can turn specific monitors off. I'll have to do some research.
                                At first I thought you were asking if you can shutdown a second computer. For that you could say something like this:
                                Alexa, turn off power on laptop.
                                Power is the voice word for the command on the computer with laptop as its voice word.
                                • S Offline
                                  SniperVB @Russ
                                  @Russ Hii, did you find a way to turn a specific monitor off? Or at least just a second screen?
                                  • XanderX Offline
                                    Xander
                                    "Enable/disable/configure multiple monitors on Windows"
                                    https://www.nirsoft.net/utils/multi_monitor_tool.html
                                    MultiMonitorTool.exe /disable \.\DISPLAY3
                                    And, for single monitors, my comment from a year ago still works.
                                    1 Reply Last reply Reply Quote 2
                                    • Fernando Montes VázquezF Offline
