    Never used parameters before...
    3.4k
    • XanderX
      Xander
      Maybe it's the heatwave we're having here but I'm having no luck setting this up.
      All I want is to be able to send a Google search to my computer. This is so I can either remember to look something up later or to use as a To-Do. If I get back to my computer and there's a browser tab with a googlin' of "Remember to do backups", I'll know what I meant by that.
      So...
      What's the syntax on it?
      "trigger": "search",
      "command": "https://www.google.com/search?q=parameter",
      "ground": "foreground",
      "voice": "search",
      "voiceReply": "Sure!",
      "allowParams": "true"
      Once I get the basics working, I'll see about turning it into a IFTTT trigger like my most commonly used commands.
        Russ @Xander
        @Xander, you could make your command, "start https://www.google.com/search?q=" and that would almost solve the problem but it still wouldn't work because there would be a space between q= and your parameter.
        So instead, what I recommend is create a simple batch file like this:
        start https://www.google.com/search?q=%1
        Then make your command run the batch file. The first parameter (aka %1) will be added after a space to that command.
        • XanderX
          Xander
          So....
          "command": "path\search.bat",
          "voice": "search",
          Search.bat:
          That should work?
            Russ @Xander
            @Xander, if "path" is meant to be a placeholder for the path where your search.bat resides, like c:\scripts\, then yes, that should work.
            "command": "c:\scripts\search.bat",
            "voice": "search",
            • XanderX
              Xander
              Well....
              "Alexa, ask TriggerCMD to run Search on my computer with parameters martini recipes" got me a search on 'recipes'
              "Alexa, ask TriggerCMD to run Search on my computer with parameters cotton candy" got me a search on 'candy'
              "Alexa, ask TriggerCMD to run Search on my computer with parameters camping gear reviews" got me a search on 'reviews'
              Any idea why it's using only the last word of parameters?
              And wasn't there a way to set one PC as a default so I wouldn't need to specify it? It defaults on other commands (so I must have set something up a while back) but, for this one, it insists that I specify which PC. As is, it's fairly clunky in the verbiage department for a 'quick' reminder.
                Russ @Xander
                @Xander, you can set your default computer in your profile. Click your name in the in the upper-right to find your profile.
                You don't have to say the "... on my computer ..." part when it's your default computer.
                I recommend testing with a batch file that outputs all of your parameters to a log file like this:
                echo %1 %2 %3 %4 %5 %6 %7 >> c:\scripts\params.log
                That way you'll know if Alexa is passing all of your parameters to your script.
                I said, "Alexa, ask TRIGGERcmd to run Logger with parameter cotton candy" and I got this entry:
                cotton candy
                You can also test your script by running it with the "Parameters" button on the website.
                Royher FigueraR 1 Reply Last reply Reply Quote 0
                • Royher FigueraR
                  Royher Figuera
                  @Russ I made the changes to search videos on youtube following your instructions but my params (%1) can´t connect with my browser. I'm missing something?
                  "C:\Users\xxx.TRIGGERcmdData\Youtube.bat
                  .BAT
                  start https://www.youtube.com/results?search_query=%1
                  "trigger": "Youtube2",
                  "command": ""C:\Users\xxx\.TRIGGERcmdData\Youtube.bat",
                  "voice": "busqueda",
                  "voiceReply": "Abriendo Youtube PC",
                    Russ @Royher Figuera
                    @Royher-Figuera said in Never used parameters before...:
                    @Royher-Figuera, I created a .bat file with only this line in it, and it worked for me.
                    Does it even work for you using the Parameters button on the website?
                    • Royher FigueraR
                      Royher Figuera @Russ
                      @Russ I try 2 times, with params nothing happens and without params open youtube...
                      • Royher FigueraR
                        Royher Figuera @Royher Figuera
                        @Russ I was find my error... In GUI command editor I forgot a final quotation marks. Sorry and thank You...
                        • Royher FigueraR
                          @Russ said in Never used parameters before...:
                          @Russ I set my default pc but when I try to run a trigger with parameters google home insists in say which PC run the trigger
                            @Royher-Figuera, I'm glad you figured out the Youtube parameters thing.
                            Please tell me the exact words you're using.
                            If you're saying what's on the page when you click this button (on your default computer line):
                            ... then this button:
                            ... then I might have a problem. I'm sure I can fix it though, so I'd appreciate your help troubleshooting it.
                            What does Google Assistant say back to you exactly?
                            • Royher FigueraR
                              Royher Figuera
                              @Russ I follow your instructions and this is the result:
                              My native language is spanish
                              Google Home mini says:
                              no se ha encontrado un ordenador con ese nombre busqueda (a computer with that name was not found search)
                              Google home listen my trigger (busqueda) like my computer name
                                @Royher-Figuera, thank you! I think I can fix this. I'll try this weekend and ask you to test it.
                                EDIT:
                                @Royher-Figuera, I think I see the problem.
                                When you said, "ejecuta en PC búsqueda con parámetros reggaetón"
                                Google sent these parameters:
                                trigger = ejecuta
                                command = búsqueda
                                params = reggaetón
                                If you had said, "ejecuta búsqueda con parámetros reggaetón" I think it would have worked.
                                When I tried that, Google sent these parameters:
                                trigger = búsqueda
                                params = reggaetón
                                "ejecuta en PC búsqueda" is not one of the valid patterns.
                                • Royher FigueraR
                                  EDIT:
                                  trigger = ejecuta
                                  command = búsqueda
                                  params = reggaetón
                                  trigger = búsqueda
                                  params = reggaetón
                                  Hi @Russ still having issues... I try both cases, but google home need a name pc to execute the trigger. Google Home´s listen "Busqueda" like my pc name, when I use your recommendation. It´s saying " no se ha encontrado un ordenador con ese nombre búsqueda" (a computer with that name was not found Búsqueda).
                                  If I have my default PC (PC) Why It´s still taken my trigger like a PCname
                                  Edit:
                                  I try first "Ok Google, hablar con ejecuta comando" and then "ejecuta Búsqueda en PC con parametro X" ... and the search in youtube was sucedeed.
                                  When I use "Ok Google, hablar a Ejecuta Comando ejecutar Búsqueda con parámetro X" ... is failing*
                                  This line error nocomputercalledprefix = "No se ha encontrado un ordenador con ese nombre."
                                  I will be doing tests and will comment...
                                    @Royher-Figuera, what happens when you do this?
                                    "Ok Google, preguntarle a Ejecuta Comando ejecutar búsqueda con el parámetro X."
                                    I found your phrases in the history Google gives me to help train it.
                                    For this one: ejecutar búsqueda con parámetro USB
                                    It identified búsqueda as a computer instead of the trigger. I changed that in the training. I did the same for a few of your other phrases too. I hope that helps. The change will take effect after Google approves it in a couple days (hopefully). I submitted for approval just now.
                                    I also found that google sent trigger = undefined. I can work around that and change the logic so if computer is something but trigger is undefined, it will use the computer value as the trigger. I'm working on that now.
                                    EDIT: I didn't finish today, but I'll try to finish tomorrow. It's a simple change but I'm running into a deployment problem now.
                                    • Royher FigueraR
                                      @Russ When I say this:
                                      Google Home says
                                      "Lo siento, no puedo ayudarte con eso"
                                      Thanks again, and let me know When I can try again
                                        @Royher-Figuera, ok, please try it now. I made the change.
                                        • Royher FigueraR
                                          @Russ is working now...
                                          But, one question. We only can say "Ok Google, preguntarle a Ejecuta Comando ejecutar búsqueda con el parámetro X" ?, the long version?
                                          It´s not posible only say "Ok google, ejecutar* búsqueda con parámetro X" ?
                                            @Royher-Figuera, good question. No, that's not possible. The preguntarle a Ejecuta Comando part tells Google Assistant to use TRIGGERcmd, and the part after that tells TRIGGERcmd what to do. I know it's a lot to say. That's why I like the Smart Home version better, but I know that only allows on or off as parameters.
