    2. Instructions
    3. Home Assistant
    Log in to post
    Load new posts
    • Recently Replied
    • Recently Created
    • Most Posts
    • Most Views
      How to run commands from Home Assistant
      Watching Ignoring Scheduled Pinned Locked Moved
      15
      0 Votes
      15k Views
      RussR
      @Andru, thanks for the idea. I'll look into it.
      Trigger your commands in VR with Immersive Home
      0 Votes
      No one has replied
    • M
      sending parameter to a home assistant TCMD switch
      0 Votes
      1k Views
      RussR
      Thanks @metablast. I've been thinking about how I could allow other parameters. Would you want to create an HA automation that triggers the command, and do you want the properties of the device that triggered the automation to be selectable as command parameters? I think I could build a way to do that.
      ESP32 infrared receiver for Home Assistant to run 21 commands
      0 Votes
      2k Views
      No one has replied
      Quick Home Assistant setup with Docker
      0 Votes
      No one has replied
      Just adding a post to plug the blueprint I just published to support the Home Assistant integration.
      0 Votes
      No one has replied
      Run one of your TRIGGERcmd commands from a python script via Home Assistant
      0 Votes
      No one has replied
