    2. TI_Gaming_TV
    T Offline
    • Posts 13
    • RE: PI Hole command not working
      @Russ now i know the problem. it was the !# in line 1. I forgot the !
      T
      TI_Gaming_TV
      #/bin/bash
      case "$1" in
        "on")
          pihole enable
        "off")
          pihole disable
          echo "Run this with on or off as the parameter."
          exit 1
      esac
      T
      TI_Gaming_TV
      @Russ sry. The ;; weren’t copied because I used the iPhone photo scan. That’s not the problem
      T
      TI_Gaming_TV
      root@DietPi:~# cat / root/. TRIGGERcmdData/pihole_on_off.sh
      #/bin/bash
      case "$1" in
      "on")
      pihole enable
      "off")
      pihole disable
      exit 1
      esac
      T
      TI_Gaming_TV
      I needed to change file permissions.
      Now i get this:
      /root/.TRIGGERcmdData/pihole_on_off.sh: line 2: syntax error near unexpected token '§'in\r'
      'root/. TRIGGERcmdData/pihole_on_off.sh: line 2: 'case "$1" in
      T
      TI_Gaming_TV
    • PI Hole command not working
      I followed all the instructions given by Russ. The trigger on and off are going to my pi (i can see it over the console). Parameter off was send, but he pihole_on_off.sh file not working do not send pihole enable (same with on).
      T
      TI_Gaming_TV
    • RE: Cant install background agent
      I changed in the installdaemon.sh the code to this:
      find / root/TRIGGERcmd-Agent -type d -name "src" | grep /src | while read dname; do /root/TRIGGERcmd-Agent/src env node $dname/agent. js --daemoninstall /bin/sh $dname/daemonmqr.sh --add $HOME/ . TRIGGERcmdData
      T
      TI_Gaming_TV
      I changed some lines in daemoninstall.sh and it works now
      T
      TI_Gaming_TV
      When i try this: /root/TRIGGERcmd-Agent/src/installdaemon.sh
      I get this: find: ‘/usr/*/triggercmdagent’: No such file or directory
      Failed to enable unit: Unit file triggercmdagent.service does not exist.
      Unit triggercmdagent.service could not be found.
      T
      TI_Gaming_TV
      This is not existing:
      /usr/share/triggercmdagent/app/src/installdaemon.sh
      T
      TI_Gaming_TV
    • Cant install background agent
      i installed Triggercmd on by Dietpi and everything works fine, but im not able to install the background agent. My directory is root/TRIGGERcmd/src-Agent. The daemoninstall.sh is there, but im not able to install it.
      T
      TI_Gaming_TV
