    PI Hole command not working
    761
    • T
      TI_Gaming_TV
      I followed all the instructions given by Russ. The trigger on and off are going to my pi (i can see it over the console). Parameter off was send, but he pihole_on_off.sh file not working do not send pihole enable (same with on).
      • T
        TI_Gaming_TV
        I needed to change file permissions.
        Now i get this:
        /root/.TRIGGERcmdData/pihole_on_off.sh: line 2: syntax error near unexpected token '§'in\r'
        'root/. TRIGGERcmdData/pihole_on_off.sh: line 2: 'case "$1" in
          Russ @TI_Gaming_TV
          @TI_Gaming_TV, can you copy/paste your script here? You seem to have an error on line 2.
          • T
            TI_Gaming_TV @Russ
            root@DietPi:~# cat / root/. TRIGGERcmdData/pihole_on_off.sh
            #/bin/bash
            case "$1" in
            "on")
            pihole enable
            "off")
            pihole disable
            echo "Run this with on or off as the parameter."
            exit 1
            esac
              Russ @TI_Gaming_TV
              @TI_Gaming_TV, you're missing these lines:
              Please try this:
              #!/bin/bash
              case "$1" in
                "on")
                  pihole enable
                "off")
                  pihole disable
                  exit 1
              esac
              • T
                TI_Gaming_TV @Russ
                @Russ sry. The ;; weren’t copied because I used the iPhone photo scan. That’s not the problem
                  Russ @TI_Gaming_TV
                  @TI_Gaming_TV, I thought that was it because I got a similar error when I used the script you pasted above, although the error was on a different line.
                  ./pihole_on_off.sh: line 5: syntax error near unexpected token `)'
                  ./pihole_on_off.sh: line 5: `"off")'
                  Can you copy/paste your actual script text here?
                  T 2 Replies Last reply Reply Quote 0
                  • T
                    TI_Gaming_TV @Russ
                    #/bin/bash
                    case "$1" in
                      "on")
                        pihole enable
                      "off")
                        pihole disable
                        exit 1
                    esac
                    • T
                      TI_Gaming_TV @Russ
                      @Russ now i know the problem. it was the !# in line 1. I forgot the !
                        Russ @TI_Gaming_TV
                        @TI_Gaming_TV, awesome. So it's working now?
