    2. Luisito Palma
    Luisito PalmaL Offline
    • Posts 6
    • RE: how to execute .sh in disc d
      @Russ Yes I think the same, but "if it works it's better not to touch it" hahaha, it's a bug that my future self will see how to solve, thank you very much for the help
      Luisito PalmaL
      Luisito Palma
      @Russ The solution was to put the full path of where the .sh file is located and the script now works, however it continues to be executed in a cmd and not in git bash
      Luisito PalmaL
      Luisito Palma
      I had to put a sleep because the terminal closes automatically when it shows that error, but when I execute the command that you told me, that Windows terminal opens and not the gitbash
      However, the git bash path is correct
      Luisito PalmaL
      Luisito Palma
      @Russ when I run the script from terminal it works normally
      Luisito PalmaL
      Luisito Palma
      @Russ When I run in, the terminal opens and closes automatically without executing the script.
      Luisito PalmaL
      Luisito Palma
    • how to execute .sh in disc d
      hi, create a program in python that runs with the following bash, the bash is located in the same path of the project.
      What parameters would I put in the cmd trigger to execute the .sh?
      Luisito PalmaL
      Luisito Palma
