    how to execute .sh in disc d
    10 Posts 2 Posters 1.8k Views 1 Watching
    • Luisito PalmaL Offline
      Luisito Palma
      hi, create a program in python that runs with the following bash, the bash is located in the same path of the project.
      What parameters would I put in the cmd trigger to execute the .sh?
        Russ @Luisito Palma
        @Luisito-Palma, I see you're trying to run a shell script using Git bash.
        Please try this as your command:
        "c:\Program Files\Git\git-bash.exe" -c /d/learn/script_python/ejecutar.sh
        Luisito PalmaL 2 Replies Last reply Reply Quote 0
          Luisito Palma @Russ
          @Russ When I run in, the terminal opens and closes automatically without executing the script.
            Luisito Palma @Russ
            @Russ when I run the script from terminal it works normally
              Russ @Luisito Palma
              @Luisito-Palma, please try running this command from a Windows cmd window and send me a screenshot. I'd like to see the error it gives, if any.
              That command is working for me - it's running my bash script.
              Luisito PalmaL 2 Replies Last reply Reply Quote 1
                Luisito Palma @Russ
                I had to put a sleep because the terminal closes automatically when it shows that error, but when I execute the command that you told me, that Windows terminal opens and not the gitbash
                However, the git bash path is correct
                  Luisito Palma @Russ
                  @Russ The solution was to put the full path of where the .sh file is located and the script now works, however it continues to be executed in a cmd and not in git bash
                    Russ @Luisito Palma
                    @Luisito-Palma, nice job. I'm glad you got it figured out.
                    I think it must be running the bash script in git-bash even though the window shows cmd because you can see the output of the python script your bash script is running.
                    Luisito PalmaL 1 Reply Last reply Reply Quote 0
                      Luisito Palma @Russ
                      @Russ Yes I think the same, but "if it works it's better not to touch it" hahaha, it's a bug that my future self will see how to solve, thank you very much for the help
                        Russ @Luisito Palma
                        @Luisito-Palma, makes sense. You're welcome. Your project looks interesting.
