It worked. Thank you so much again.
Best posts made by Bráulio Betônico
RE: Is it possible to wake a laptop from sleep?posted in General Discussion
RE: PS4-Waker troubleshootingposted in Mac
@Russ said in PS4-Waker troubleshooting:
/usr/local/bin/node /usr/local/lib/node_modules/ps4-waker/dist/cli.js standby
Thank you very much. worked correctly.
Latest posts made by Bráulio Betônico
How are you? Everything ok? Can you help me?
In triggercmd how can I insert the command turn on screen and turn off screen in the same command configuration? -
@Russ Thank you very, very much! I am really happy! Would you have a command to put it to sleep?
if I type in the terminal, the system runs normally, I still linked the triggnercmd on Alexa Amazon, it recognizes the APP, she (Alexa) says she recognized a new APP, but it doesn't trigger the PS4. But, when I go to the terminal and type ps4-waker turns on, and ps4 waker standby it goes to sleep, but by the triggercmd command, it doesn't work, I've uninstalled it several times, I redid all the configuration and nothing. Anyone to help?
