    2. Alexander Cleary
    Alexander ClearyA Offline
    • Topics 4
    • Posts 9
    • RE: I keep getting this error on cpu startup
      okay thanks Russ, I was on vacation, maybe it was something to do with the wifi for the hotel, i'll let you know if it continues doing it now i'm back
      Alexander ClearyA
      Alexander Cleary
    • I keep getting this error on cpu startup
      Alexander ClearyA
      Alexander Cleary
    • RE: Command Doesn't Work If PC Hasn't Been Used Recently (Not In Sleep)
      @russ
      Hi Russ
      1. No Anti Virus Software installed
      2. I have closing the lid set to do nothing, so it doesn't affect anything. Lock screen is not showing, I don't want it to, just the desktop is showing. This isn't the issue, because if i've done something manually on the computer within the past hour, trigger cmd works
      It just seems that Trigger CMD goes into some type of sleep state after a period of inactivity on the computer. Task scheduler actions still work during this time
      Alexander ClearyA
      Alexander Cleary
    • Command Doesn't Work If PC Hasn't Been Used Recently (Not In Sleep)
      Hi Russ
      Can you help please?
      I'm triggering a command through integromat > it triggers to open a BAT file to then open an excel file
      If i've used the computer in the last hour, and i've closed the laptop lid, the triggercmd command via integromat works fine, without any issues
      The PC is not in sleep mode, it's set to NEVER be in sleep mode.
      But if i haven't done anything manually on that computer for more than a few hours. The laptop stops responding to the triggerCMD command until i've opened it up and done something manual on it
      Other commands through windows task scheduler work fine without any issues (when the laptop lid is closed and i haven't done anything manual on it for hours/days). It just seems that if the laptop has not been active for a few hours it doesn't want to respond to triggercmd
      If log in to the laptop a with remote desktop software "nudge it / reactivate it", trigger CMD will work after i've done that for a while. Again, I repeat, the settings for the laptop are to never go to sleep even when the lid is closed
      I tried installing the "background service" for triggercmd to see if maybe that had anything to do with it, I assume it didn't because this command i'm trying to run is just to open a bat file, the background service didn't seem to make any difference
      Do you have any ideas please?
      thanks
      Alexander ClearyA
      Alexander Cleary
    • RE: Can't connect my account, don't get a token prompt after install
      @russ okay.... i'm making progress here, i figured out that i can create a bat file to open the excel file
      how do i trigger the bat file command?
      Alexander ClearyA
      Alexander Cleary
      @russ so i just figured out how to open word. I use "Start" and i don't need to put the file number, just the exe
      How would I open up an excel file on my desktop, i'm struggling to work that out
      Alexander ClearyA
      Alexander Cleary
      @russ
      Thanks, that worked, i deleted it and it prompted me
      i'm really struggling to understand how the instructions are laid out here, i'm having the following issues
      1. Text command editor. I'll make changes in that, press save and nothing is changed when i open it back up even when i press save
      2. I'm trying to create some basic commands just to test, for example open word. I've tried pasting the location of the exe in the command such as
      "C:\Program Files (x86)\Microsoft Office\root\Office16\WINWORD.EXE"
      But when i press run it doesn't open the exe
      i've also tried putting Open "C:\Program Files (x86)\Microsoft Office\root\Office16\WINWORD.EXE"
      but it doesn't work
      is there a tutorial somewhere that explains how create these commands?
      Alexander ClearyA
      Alexander Cleary
    • Can't connect my account, don't get a token prompt after install
      Can't use this service at all, seems good in theory, but i don't get a popup to input a token after install on windows 10 so it's pretty much useless to me, i can't do anything
      Alexander ClearyA
      Alexander Cleary
