    Open or close Kodi with a SmartThings virtual switch
    5.3k
      Create a batch file in c:\scripts called kodi.bat with these contents:
      if "%1"=="on" "C:\Program Files (x86)\Kodi\kodi.exe"
      if "%1"=="" "C:\Program Files (x86)\Kodi\kodi.exe"
      if "%1"=="off" taskkill /im kodi.exe
      Go here to setup the TRIGGERcmd SmartApp in SmartThings.
      Use the SmartApp to create a virtual switch for Kodi.
      Say:
      Alexa, turn on Kodi
      Alexa, turn off Kodi
      Profit.
        A Former User
        Kodi as a name works fine for me. even spelled it Kodi vs Cody or something. not sure what the issue may be on your end.
          Russ @A Former User
          @Neflhiem, yea you're right. I was testing it before I told Alexa to discover my new Kodi virtual switch. I assumed it was failing because Alexa didn't hear Kodi right. I was wrong.
          Sorry about that. I re-recorded that video too: https://www.youtube.com/watch?v=qYHbT05UMQc
          E 1 Reply Last reply Reply Quote 0
          • E
            esco0909 @Russ
            @russ
            Hey Russ
            Need some quick help when you have a moment
            I setup everything to voice control apps with alexa and I can get everything running but when I say alexa turn off kodi....nothing happens.
            I tried to create a batch file to force close kodi but nothing happens when i test it on the command gui command editor
              Russ @esco0909
              @esco0909, does it work from the SmartThings app? I mean can you toggle the switch on or off to see Kodi open or close.
              Also, I wonder if it works from the www.triggercmd.com website when you click the Parameters button and type on or off?
              • Mario Anibal Yaranga ColquicochaM
                This post is deleted!
                • Carlos Ignacio Ponce BritoC
                  if "%1"=="on" it works for another program?
                    Russ @Carlos Ignacio Ponce Brito
                    @Carlos-Ignacio-Ponce-Brito, yes, you could use that if "%1"=="on" and if "%1"=="off" in a .bat file to open and close any program.
                    Or instead of using a .bat file, now you can use the Off Command field instead like this:
                    You have to set Allow Parameters to true before you can use the Off Command field.
