    Raspberry Pi OS (64 bit)
    • Călin Cătălin AlexandruC
      i can't make it work on the Raspberry Pi OS (64 bit)
      i have modified the file /root/.TRIGGERcmdData/commands.json
      but is still showing the default commands on the site.
      {"trigger":"Clear ram","command":"/home/pi/ram.sh","ground":"background","voice":"Clear ram","allowParams": "false"},
      {"trigger":"Computer on","command":"/home/pi/wol.sh","ground":"background","voice":"Computer on","allowParams": "false"},
      {"trigger":"apt update","command":"apt-get -y update","ground":"background","voice":"update","allowParams": "false"}
      {"trigger":"Pi temperature","command":"python3 /home/pi/temperature.py","ground":"background","voice":"system temperature","voiceReply":"The pi temperature is {{result}} degrees","allowParams": "false"}
      and on site it shows
      Gnome Editor
      Reboot
      yum update
      apt update
      and i dot kow way evry time i refresh the page on site the token is a new one.
      in: Your Computers it shows up like is connected.
      Nu
        Russ @Călin Cătălin Alexandru
        @Călin-Cătălin-Alexandru, please paste the output of this command:
        The problem might be either that you haven't installed the background agent, or you ran the agent as your user instead of as root.
        I recommend you try the steps on this page again, and make sure you run this command first: sudo su -
        If you're not subscribed, you may need to delete your computer on the website before you re-run these steps because if you ran the agent as your non-root user, it would have created a .TRIGGERcmdData directory in your users's home directory, and created a computer associated with that data folder.
          root@z3r0:~# systemctl status triggercmdagent
          Active: active (running) since Tue 2020-07-28 18:39:58 EEST; 671ms ago
          Main PID: 625 (node)
          Tasks: 6 (limit: 4539)
          └─625 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
          Jul 28 18:39:58 z3r0.go.ro systemd[1]: Started TRIGGERcmd Agent.
          Nu
            https://imgur.com/a/pjRUKOO
            Nu
              looks like the problem was the last line in commands.json
              i have delete: {"trigger":"Pi temperature","command":"python3 /home/pi/temperature.py","ground":"background","voice":"system temperature","voiceReply":"The pi temperature is {{result}} degrees","allowParams": "false"}
              and now it works 🙂
              Nu
                Awsome, @Călin-Cătălin-Alexandru I'm glad you figured it out.
