    2. Călin Cătălin Alexandru
    @Călin Cătălin Alexandru
    Îmi plac grasutele
    Călin Cătălin Alexandru Unfollow Follow
    Latest posts made by Călin Cătălin Alexandru
    • RE: Raspberry Pi OS (64 bit)
      looks like the problem was the last line in commands.json
      i have delete: {"trigger":"Pi temperature","command":"python3 /home/pi/temperature.py","ground":"background","voice":"system temperature","voiceReply":"The pi temperature is {{result}} degrees","allowParams": "false"}
      and now it works 🙂
      Călin Cătălin AlexandruC
      https://imgur.com/a/pjRUKOO
      root@z3r0:~# systemctl status triggercmdagent
      Active: active (running) since Tue 2020-07-28 18:39:58 EEST; 671ms ago
      Main PID: 625 (node)
      Tasks: 6 (limit: 4539)
      └─625 node /usr/share/triggercmdagent/app/src/daemon.js --run /root/.TRIGGERcmdData
      Jul 28 18:39:58 z3r0.go.ro systemd[1]: Started TRIGGERcmd Agent.
    • Raspberry Pi OS (64 bit)
      i can't make it work on the Raspberry Pi OS (64 bit)
      i have modified the file /root/.TRIGGERcmdData/commands.json
      but is still showing the default commands on the site.
      {"trigger":"Clear ram","command":"/home/pi/ram.sh","ground":"background","voice":"Clear ram","allowParams": "false"},
      {"trigger":"Computer on","command":"/home/pi/wol.sh","ground":"background","voice":"Computer on","allowParams": "false"},
      {"trigger":"apt update","command":"apt-get -y update","ground":"background","voice":"update","allowParams": "false"}
      and on site it shows
      Gnome Editor
      Reboot
      yum update
      apt update
      and i dot kow way evry time i refresh the page on site the token is a new one.
      in: Your Computers it shows up like is connected.
