    Home Assistant syntax question
    • kellanistK
      kellanist
      Setting up Home Assistant.
      I saw the post here: https://www.triggercmd.com/forum/topic/193/how-to-run-commands-from-home-assistant
      This is what needs to be entered in the .yml
      rest_command:
      triggercmd_calculator:
      url: 'https://www.triggercmd.com/api/run/triggerSave'
      method: "post"
      content_type: "application/x-www-form-urlencoded"
      payload: "trigger=calculator&computer=russfam&token=(your token from Instructions page)"
      Questions:
      1. For triggercmd_calculator in the second line, can that be anything? Where is that variable used?
      2. If I have a trigger called "Lock My PC" what do I use as a delimiter for the spaces? -? ""?
      3. Any fun script that anyone has kicking around that will parse the existing commands into the format above?
      • kellanistK
        kellanist
        Tried adding this to the yml file:
        rest_command:
        triggercmd_mute:
        method: "post"
        payload: "trigger=mute&computer=VIEWSCREEN&token=MYTOKEN"
        Doesn't seem to show up in the Home Assistant dashboard.
        Anyone have any ideas?
          Russ @kellanist
          @kellanist, maybe you have to reload the config?
          I see mine if I click Services under Developer tools, and click the down arrow. It's called "rest_command.triggercmd_calculator".
          This is what's at the end of my configuration.yaml file:
          rest_command:
              method: "post"
              payload: "trigger=calculator&computer=russfam&token=(mytoken)
          • kellanistK
            kellanist
            Ahhhh Ok I see it now! I thought it was going to add them to the dashboard directly but I need to add the service to an automation for it to work.
            For trigger names with spaces what is the delimiter?
              Russ @kellanist
              @kellanis, the delimiter is %20
