    Subscription mail
    12 Posts 11 Posters 7.7k Views 1 Watching
    • ? Offline
      [[global:former-user]]
      Hi!
      First of all thanks for this beautiful service. I want to make a subscription but my mail address is the same of paypal, there is a way to change mail address of this account or something different to proceed with the subscription?
      Thanks again
        Russ @Guest
        @davboc , your email address for TRIGGERcmd does not have to match your Paypal address. It can match, but it does not have to match - either way works.
        Also if you want to change your TRIGGERcmd account's email address, you could just create a new account. To re-register your agent with your new account, just delete your token.tkn file, then Quit and re-open the TRIGGERcmd agent.
        The token.tkn file is in C:\Users(your user).TRIGGERcmdData on Windows, or ~/.TRIGGERcmdData on Linux and Mac.
        I'm glad you like the service! Tell your friends! 👍🏽
        • ? Offline
          [[global:former-user]] @Russ
          @Russ sorry for my misunderstanding, now all it's clear.
          I payed the subscription fee but my account is still a free account... What can I do?
            Russ @Guest
            @davboc , please check again - I manually changed your account to subscribed. I see there was an error reading your email address. You might have found a bug. If so, thank you - I'll fix it right away.
            EDIT: You did find a bug (oops). I fixed it.
            • ? Offline
              @Russ great work, I have a premium account now!
              Last question, I'm trying to install triggercmd on a raspberry pi following your guide, works fine but I can't add a command (or modify one of the list), every change at the commands.json file disappears when I reopen the file. I tried to stop the triggercmdagent then modify the commands.json, but when I start the triggercmdagent all changes are lost.
                Russ @Guest
                @davboc , I think I might know what's wrong. If you have a comma at the end of your commands.json file, it will revert it to the previous commands.json. In otherwords, it detects the problem and restores the backup.
                I've made that mistake a few times myself - if you copy a line and forget to remove that last comma, it's bad json format. You could past your json into this tool to check it: https://jsonlint.com/
                Here's my commands.json file from my Raspberry Pi. Notice the last line doesn't have a comma at the end.
                {"trigger":"Reboot","command":"shutdown -r","ground":"background","voice":"reboot"},
                {"trigger":"Russ Garage Door","command":"/root/russdoor.sh","ground":"background","voice":"russ"},
                {"trigger":"Betsy Garage Door","command":"/root/betsydoor.sh","ground":"background","voice":"betsy"},
                {"trigger":"apt update","command":"apt-get -y update","ground":"background","voice":"update"},
                {"trigger":"boot russfam","command":"wakeonlan c0:7c:d1:a1:89:f8","ground":"background","voice":"boot"}
                • ? Offline
                  @Russ yes you're absolutely right, comma was the problem. However now I can modify the file, but I still can't see created triggers on the website and I can't execute the trigger that I've added...
                    Russ @Guest
                    @davboc,
                    Did you install the background service? On a Raspberry Pi you'd generally only use the background service.
                    Also use "ground":"background" instead of "ground":"foreground".
                    You can install the background service with this command:
                    Also, here's a troubleshooting tip for Linux/Raspberry Pi. If you run this, you'll see the latest output from the agent running as a background service (aka daemon):
                    systemctl status triggercmdagent -l
                    • ? Offline
                      @Russ yes I installed the service as explained in your guide, I tried both foreground and background but I still can't see my triggers, and of the default triggers I can only see "gnome editor" that is the only in foreground...
                      Thanks again for your patience
                        Russ @Guest
                        @davboc , I'm happy to help. Thank you for your patience. We'll get this.
                        I wonder if your Raspberry Pi is connected to your old account, if you created a new one today?
                        Or maybe the background service isn't running now. You could check that with this command:
                        You could try getting a fresh start like this:
                        • Delete your Raspberry Pi computer record from your account here.
                        • Delete your ~/.TRIGGERcmdData/token.tkn file.
                        • Run: triggercmdagent (runs agent in foreground)
                        • Paste in your token from the Instructions page.
                        • CTRL-C out of the foreground agent.
                        • systemctl restart triggercmdagent
                        • systemctl status triggercmdagent
                        • Check to see if the background commands were added.
                        Please IM me your computer name - that might help me troubleshoot.
                        • ? Offline
                          @Russ after that fresh start all works well. Thank you so much, I really appreciate your work
                            Russ @Guest
                            You're welcome @davboc. Thanks again for finding that Paypal bug.
