    Subscription mail
    12
    7.5k
      A Former User @Russ
      @Russ sorry for my misunderstanding, now all it's clear.
      I payed the subscription fee but my account is still a free account... What can I do?
        Russ @A Former User
        @davboc , please check again - I manually changed your account to subscribed. I see there was an error reading your email address. You might have found a bug. If so, thank you - I'll fix it right away.
        EDIT: You did find a bug (oops). I fixed it.
          A Former User @Russ
          @Russ great work, I have a premium account now!
          Last question, I'm trying to install triggercmd on a raspberry pi following your guide, works fine but I can't add a command (or modify one of the list), every change at the commands.json file disappears when I reopen the file. I tried to stop the triggercmdagent then modify the commands.json, but when I start the triggercmdagent all changes are lost.
            Russ @A Former User
            @davboc , I think I might know what's wrong. If you have a comma at the end of your commands.json file, it will revert it to the previous commands.json. In otherwords, it detects the problem and restores the backup.
            I've made that mistake a few times myself - if you copy a line and forget to remove that last comma, it's bad json format. You could past your json into this tool to check it: https://jsonlint.com/
            Here's my commands.json file from my Raspberry Pi. Notice the last line doesn't have a comma at the end.
            {"trigger":"Reboot","command":"shutdown -r","ground":"background","voice":"reboot"},
            {"trigger":"Russ Garage Door","command":"/root/russdoor.sh","ground":"background","voice":"russ"},
            {"trigger":"Betsy Garage Door","command":"/root/betsydoor.sh","ground":"background","voice":"betsy"},
            {"trigger":"boot russfam","command":"wakeonlan c0:7c:d1:a1:89:f8","ground":"background","voice":"boot"}
              A Former User @Russ
              @Russ yes you're absolutely right, comma was the problem. However now I can modify the file, but I still can't see created triggers on the website and I can't execute the trigger that I've added...
                Russ @A Former User
                @davboc,
                Did you install the background service? On a Raspberry Pi you'd generally only use the background service.
                Also use "ground":"background" instead of "ground":"foreground".
                You can install the background service with this command:
                Also, here's a troubleshooting tip for Linux/Raspberry Pi. If you run this, you'll see the latest output from the agent running as a background service (aka daemon):
                systemctl status triggercmdagent -l
                  A Former User @Russ
                  @Russ yes I installed the service as explained in your guide, I tried both foreground and background but I still can't see my triggers, and of the default triggers I can only see "gnome editor" that is the only in foreground...
                  Thanks again for your patience
                    Russ @A Former User
                    @davboc , I'm happy to help. Thank you for your patience. We'll get this.
                    I wonder if your Raspberry Pi is connected to your old account, if you created a new one today?
                    Or maybe the background service isn't running now. You could check that with this command:
                    You could try getting a fresh start like this:
                    • Delete your Raspberry Pi computer record from your account here.
                    • Delete your ~/.TRIGGERcmdData/token.tkn file.
                    • Run: triggercmdagent (runs agent in foreground)
                    • Paste in your token from the Instructions page.
                    • CTRL-C out of the foreground agent.
                    • systemctl restart triggercmdagent
                    • systemctl status triggercmdagent
                    • Check to see if the background commands were added.
                    Please IM me your computer name - that might help me troubleshoot.
                      A Former User @Russ
                      @Russ after that fresh start all works well. Thank you so much, I really appreciate your work
                        Russ @A Former User
                        You're welcome @davboc. Thanks again for finding that Paypal bug.
