    How do you run an application from Trigger CMD on my laptop
    5 Posts 2 Posters 2.8k Views 1 Watching
    • M Offline
      Minh-Tam Nguyen
      Hi! Quick question on how to launch an application from TriggerCMD on my computer. My current code for this is
      "trigger": "League of Legends",
      "command": "C:\Riot Games\League of Legends\LeagueClient.exe",
      "ground": "foreground",
      "voice": "League of Legends",
      "voiceReply": "Launching League of Legends"
        @Minh-Tam-Nguyen, that entry looks good, except it needs double backslashes \\, which is something you don't have to worry about if you use the GUI editor.
        I recommend finding the icon for the app, and copy/pasting the command from the Target field in it's properties.
        • M Offline
          Minh-Tam Nguyen
          I copied and pasted the command from the Target field in its properties, however, the program still does not launch. Is there something wrong with the way I did it in the GUI editor? Thanks for getting back quickly! I am still fairly new to this.
            Russ @Minh-Tam Nguyen
            @minh-tam-nguyen, I think I might know what's wrong. Because there are spaces in your command, you probably need quotes around it.
            Using the GUI editor, please make your command:
            Also, please test it using the green play button in the GUI editor.
            • M Offline
              Minh-Tam Nguyen
              Thank you so much! I've been at this for a while now
