How do you run an application from Trigger CMD on my laptop
Hi! Quick question on how to launch an application from TriggerCMD on my computer. My current code for this is
"trigger": "League of Legends",
"command": "C:\Riot Games\League of Legends\LeagueClient.exe",
"ground": "foreground",
"voice": "League of Legends",
"voiceReply": "Launching League of Legends" -
@Minh-Tam-Nguyen, that entry looks good, except it needs double backslashes \\, which is something you don't have to worry about if you use the GUI editor.
I recommend finding the icon for the app, and copy/pasting the command from the Target field in it's properties.
I copied and pasted the command from the Target field in its properties, however, the program still does not launch. Is there something wrong with the way I did it in the GUI editor? Thanks for getting back quickly! I am still fairly new to this. -
@minh-tam-nguyen, I think I might know what's wrong. Because there are spaces in your command, you probably need quotes around it.
Using the GUI editor, please make your command:
Also, please test it using the green play button in the GUI editor.
Thank you so much! I've been at this for a while now
