    Error in trigger this example commands
    • V
      VeepuEco
      Re: Press the Down Arrow key (or any other key)
      alt text
        Russ @VeepuEco
        @veepueco, how do you get that error? Are you able to trigger some commands, but that example command gives that error?
        • V
          VeepuEco
          I am unable to do anything that was set in the script. Every time I run the command that pops out.
            Russ @VeepuEco
            @veepueco, if you run it from a cmd prompt does it work? Also, can you send a screenshot of the file name and path, and paste the contents of your script below?
