    Adding Parameter to raspberry pi commands
    Raspberry Pi
    1.7k
    • J
      js
      Re: Raspberry Pi setup
      I am trying to turn on/off monitor connected to raspberry pi using one command by passing two different parameter. Could you please help me with the command
        Russ @js
        @js, can you post the commands you're using to turn your monitor on and off?
        You can use a script like this to handle the on and off parameters:
        #!/bin/bash
        if [ "$1" = "on" ] ; then
          echo Turning it on
        fi
        if [ "$1" = "off" ] ; then
          echo Turning it off
        fi
        • J
          js
          Sorry for the delay. Please find the commands listed below
          sudo cat /root/.TRIGGERcmdData/commands.json
          {"trigger":"Monitor ON","command":"vcgencmd display_power 1","ground":"background","voice":"Monitor ON","allowParams": "false"},
          {"trigger":"Monitor OFF","command":"vcgencmd display_power 0","ground":"background","voice":"Monitor OFF","allowParams": "false"}
            Russ @js
            Ok @js, you could change your commands.json to this:
              {"trigger":"Monitor","command":"/root/monitor.sh","ground":"background","voice":"Monitor","allowParams": "true"}
            And put this in your /root/monitor.sh script:
            #!/bin/bash
              echo Turning it on
            fi
              echo Turning it off
            fi
            And say this to Alexa or Google Assistant:
            ask TRIGGERcmd to run monitor with parameter on
            Or use the TRIGGERcmd Smart Home Alexa skill or the SmartThings integration with Google Assistant, and say this:
            turn on monitor
            Oskar PerssonO 1 Reply Last reply Reply Quote 1
            • Oskar PerssonO
              Oskar Persson @Russ
              This post is deleted!
