    Alexa Skill in Italy
    6 Posts 3 Posters 2.8k Views 2 Watching
    • S Offline
      sulisenator
      Hi!
      I just integrated Trigger CMD in my Smartthings, it's really great, thank you!
      Would it be possible to have the Alexa skill on the Italian skill store ?
      I'd be available for any translation work that's needed.
        Russ @sulisenator
        @sulisenator, I'll probably take you up on that when I get around to adding Italian language support.
          @sulisenator, I'm ready to do the Italian language versions of the Alexa skill and Google Assistant action.
          Would you mind translating the text to the right of the = sign to Italian for me?
                cardtitle = "TRIGGERcmd";
                greeting = "Say something like, run Calculator on Office PC.";
                cardgreeting = greeting;
                helpspeech = "When you install a trigger c m d agent on a computer, it will show up in your account at trigger c m d dot com.  Click that computer's edit button to add a voice trigger.  Then you can have alexa run any commands that have voice triggers on that computer by saying, run X on Y, where X is the command's voice trigger, and Y is the computer's voice trigger.  Go to trigger c m d dot com for more instructions.  What do you want to do now?  Say stop if you're done.";
                helptext = "When you install a TRIGGERcmd agent on a computer, it will show up in your account at triggercmd.com.  Click that computer's Edit button to add a voice trigger.  Then you can have Alexa run any commands that have voice triggers on that computer by saying, run X on Y, where X is the command's voice trigger, and Y is the computer's voice trigger.  What do you want to do now?";
                goodbye = "Good-bye";
                pleaselink = "Please go to your Alexa app and link your account.";
                redohelp = "Say something like, run Notepad on Family PC.  You can also say Help.  Say Stop if you're done.";
                nocomputercalledprefix = "Could not find a computer with voice word ";
                tryagain = ", try again, or say Stop if you're done.";
                notriggercalledprefix = "Could not find a command with voice word ";
                onword = " on ";
                triggering = "Triggering ";
                cardtriggering = triggering;
                doesnotallowparams = " does not allow parameters.";
                withparameter = " with parameter ";
                waitaminute = "Wait a minute, or subscribe so you don't have to.";
                launched = "Launched";
                nodefaultspeech = "You haven't set a default computer in your trigger C M D profile yet.";
          • G Offline
            gauner
            @russ
            I tried my best, can't wait to see this skill on the italian store
              greeting = "Dici qualcosa del tipo apri Calcolatrice sul PC";
              helpspeech = "Quando installi trigger c m d sul computer, esso apparirà nel tuo account di trigger c m d punto com. Clicca sulle impostazioni per aggiungere un comando vocale. A questo punto, Alexa eseguirà qualsiasi comando vocale sul computer dicendo apri X su Y, dove X è l'applicazione o il comando vocale e Y il computer sul quale vuoi che si apra. Visita trigger c m d punto com per maggiori informazioni. Cosa vuoi fare adesso? Dici Stop quando hai finito";
              helptext = "Quando installi trigger c m d sul computer, apparirà nel tuo account di trigger c m d punto com. Clicca sulle impostazioni per aggiungere un comando vocale. A questo punto, Alexa eseguirà qualsiasi comando vocale sul computer dicendo apri X su Y, dove X è l'applicazione o il comando vocale e Y il computer sul quale vuoi che si apra. Visita trigger c m d punto com per maggiori informazioni. Cosa vuoi fare adesso?";
              goodbye = "Arrivederci";
              pleaselink = "Per favore, vai sull'app di Alexa ed associa il tuo account";
              redohelp = "Dici qualcosa del tipo apri Blocco Note sul PC.  Puoi anche dire Aiuto per maggiori istruzioni. Dici Stop quando hai finito";
              nocomputercalledprefix = "Non riesco a trovare il PC ";
              tryagain = ", riprova, o dici Stop quando hai finito.";
              notriggercalledprefix = "Non riesco a trovare il comando ";
              onword = " su ";
              doesnotallowparams = " parametri non consentiti.";
              withparameter = " con parametro ";
              waitaminute = "Aspetta un minuto o iscriviti per velocizzare.";
              launched = "Sto aprendo";
              nodefaultspeech = "Non hai ancora indicato un computer di default sul tuo profilo di trigger c m d.";
              Russ @gauner
              Thanks @gauner. I've got the code updated. Would you mind translating this too for the listing in the directory?
              TRIGGERcmd is a cloud service that allows you to securely and remotely run commands on your computers.
              Your commands could install updates, reboot, run a script, or anything else you decide.
              • Login at www.triggercmd.com.
              • Download and install an agent on your computer. It will prompt for the token during the install.
              • Go to the Instructions page in your triggercmd.com account, and copy the token.
              • Paste the token from the Instructions page into your agent to log it in.
              • Your computer will now show up in your www.triggercmd.com account.
              • Click Edit and add a voice trigger to your computer.
              • Add the TRIGGERcmd skill in your Alexa app.
              • Link your Alexa account to your TRIGGERcmd.com account.
              • Say: Alexa, open TRIGGERcmd.
              • Say: run Calculator on Office (use your own computer's voice trigger instead of "Office")
              • G Offline
                gauner
                @russ said in Alexa Skill in Italy:
                TRIGGERcmd è un servizio che ti permette di impartire comandi in remoto ai tuoi computer in piena sicurezza.
                Puoi installare aggiornamenti, riavviare il PC, avviare uno script o qualsiasi cosa di cui tu abbia bisogno.
                • Effettua il login su www.triggercmd.com.
                • Scarica ed installa il client sul tuo computer. Ti verrà richiesto un token durante l'installazione.
                • Vai sulla pagina Instructions del tuo account triggercmd.com e copia il token.
                • Incolla il token quando richiesto dal client per collegare il tuo account.
                • Il computer appena associato verrà mostrato nel tuo account www.triggercmd.com.
                • Clicca su Edit e aggiungi un trigger vocale al tuo computer.
                • Aggiungi la skill TRIGGERcmd alla tua app Alexa.
                • Connetti il tuo account Alexa al tuo account TRIGGERcmd.com.
                • Dici: Alexa, apri TRIGGERcmd.
                • Dici: apri Calcolatrice su nome_computer (dove nome_computer corrisponde al trigger vocale impostato nei passaggi precedenti)
